Hear Spinning sound at the rear (interior) when drive slow
Old Nov 20, 2006 | 06:16 PM
theboy's Avatar
RX8 newbie!
one of the member here have this problem, it only happen ocassionally. hear spinning sound from the rear inside the car. even sometimes when the car stop or drive slow. what would the problem be?
Old Nov 20, 2006 | 07:25 PM
theboy's Avatar
RX8 newbie!
could this be due to alignment? LSD Oil ran out? other?
Old Nov 20, 2006 | 11:36 PM
tiltmode43's Avatar
OMGITM!
Spinning almost like a whining?
Old Nov 21, 2006 | 03:15 AM
theboy's Avatar
RX8 newbie!
nope i dun have navi.
its a spinning sound like Mobile phone vibration and electronic toy cars engine sound.
it normally appear 5 seconds + -
Old Nov 21, 2006 | 03:31 AM
BoosTED's Avatar
Spinners?
Old Nov 21, 2006 | 04:29 AM
theboy's Avatar
RX8 newbie!
????? not my car
thats all i hear when i was in the car.
Old Nov 21, 2006 | 04:48 AM
tiltmode43's Avatar
OMGITM!
Hmm, its not a slight shudder, is it? I'm curious as to what this is.
Old Nov 21, 2006 | 05:40 AM
Go48's Avatar
Fuel pump? Headlight leveling?
Old Nov 21, 2006 | 06:19 AM
theboy's Avatar
RX8 newbie!
definitely not a shudder, we were only manage to hear that sound after driving around for hours, and it only came out for less than 5 seconds.
i also suspect Fuel pump before, but why it was not there before and sound louder now? any idea bro?
Old Nov 21, 2006 | 08:06 AM
bsteimel's Avatar
Nice !!!
do you have a manual? Is it your synchros and transmission spinning? If so it would be clearly audible when switching to first or second gears.
Old Nov 21, 2006 | 08:18 AM
Atrain's Avatar
^^^ What he said. First thing I thought of was the sound the transmission makes when you're slowing down to stop at a light or whatnot and try to put it in first before you've stoped.
Old Nov 21, 2006 | 08:23 AM
theboy's Avatar
RX8 newbie!
sorry but i am not a tech guy. what is synchros?
its not audible at any gear, it will appear when ever it want to.
Old Nov 21, 2006 | 08:25 AM
theboy's Avatar
RX8 newbie!
Nope thats not the sound, its more obvious, clear and louder.
Old Nov 21, 2006 | 09:07 AM
mysql101's Avatar
make an audio recording, otherwise all we can do is guess ..
Old Nov 21, 2006 | 12:16 PM
BoosTED's Avatar
Synchronizers
Manual transmissions in modern passenger cars use synchronizers to eliminate the need for double-clutching. A synchro's purpose is to allow the collar and the gear to make frictional contact before the dog teeth make contact. This lets the collar and the gear synchronize their speeds before the teeth need to engage, like this:
http://www.howstuffworks.com/transmission.htm
When pushing the clutch in and going to a lower gear when coasting you will hear the synchros working to speed up to the proper RPM before they actually engage the gear to the drive shaft.
Old Nov 21, 2006 | 03:26 PM
Spok's Avatar
It might be this: Secondary air injection pump. It provides air to the catalyst to limit emissions. It sounds as though it is located in the rear but it is actually under the hood (bonnet). When it starts to go, it makes a high pitched buzzing or whirring sound that sort of comes and goes.
Old Nov 21, 2006 | 06:12 PM
theboy's Avatar
RX8 newbie!
Originally Posted by 4 years to Supercharge
Synchronizers
Bro its an Auto.
Old Nov 21, 2006 | 06:13 PM
theboy's Avatar
RX8 newbie!
Does this mean its ok?
Old Nov 21, 2006 | 06:37 PM
Spok's Avatar
It means that the next time you're in for servicing, tell the service writer about it. If I'm correct in identifying the sound, it's non-critical; just means it will take your catalytic converter a little longer to get to operating temperature. But then, I'm not an automotive technician and I'm not there to hear the actual noise.
Old Nov 21, 2006 | 07:02 PM
theboy's Avatar
RX8 newbie!
thanks bro. i think i found the problem. it might be air inside fuel pump.
Old Nov 21, 2006 | 07:12 PM
mikeschaefer's Avatar
I wanna rock! Rock!
It would only take longer if his air pump stopped working all together, not if it came on randomly after the car is warmed up.
Old Nov 21, 2006 | 09:01 PM
theboy's Avatar
RX8 newbie!
due to our oil pump is a in tank pump, so when low fuel, during cornerings, air would get into pump and make this noise. also at bumpy rides when fuel is not low. make sense cause the car was driven to a bumpy long distance road the same day. my question is why it happened to suck air after that? due to new fuel fomular that just been introduced?
Old Nov 24, 2006 | 10:22 AM
The air pump only runs when the car is started cold...so it won't likely be that.
I would think in an Auto tranny uyou should let them have a look at it. There are a lot of valves and crap in there that can make noises.....
Old Nov 26, 2006 | 09:11 AM
Philip_SA's Avatar
Rotary lover
I also suspected the fuel pump, mine did the same, with full fuel or not,if you close windows and listen even when idle and you hear the spinning nearly as if it vibrates into the car body.
Then make ready for a soon to be replacing expensive fuel pump, it happened to me at only about 25000 miles
If it makes that noise in low fuel, i dont think its right, the pump casing or basket around it holds about a liter of fuel on its own if i am correct, so keep listening to the pump for a while, just in case.
Philip
Old Nov 29, 2006 | 02:35 PM
dynamho's Avatar
It's probably the transmission. When you're driving slow, you gear less road/wind noise, your lower gears spin relatively fast and you hear it, not unlike the tranny sound when you reverse, no?
Billy Marcial
Mar 1, 2018 06:50 AM
Dokuji
Nov 1, 2016 02:51 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
AussieGray
Jul 16, 2015 03:58 AM
