How does TPMS work? Wireless?
Old Nov 20, 2006 | 01:54 PM
CosmosMpower's Avatar
1935 lbs. FTW!
I was thinking about the TPMS system in our 8's. I know they're part of the valve stem between the wheel and tire but how does it actually transmit information to the car computer when your tire is too low? There obviously can't be any wires since the wheel needs to spin freely. Do they have a wireless system to communicate with the ECU, are there batteries that ever need to be changed?
Old Nov 20, 2006 | 03:59 PM
BlueRenesis82's Avatar
Registered Tracker
yep, because if you want to reset the sensor, if you have winter wheels for example, you can leave the wheels in the garage and they will communicate with the car.
Old Nov 20, 2006 | 04:28 PM
sensors dont start to work till tire starts to spin.
Old Nov 20, 2006 | 04:34 PM
Registered Tracker
you sure? I have had my tire sensors go off once I moved the tires back into the garage....
Old Nov 20, 2006 | 05:15 PM
1935 lbs. FTW!
Wow that's pretty cool, I didn't see anything about that in the manual. So if you have a set of wheels that don't have TPMS like track wheels then it will blink with that set on but if you put the OEM set of wheels/tirse back on then it will sense them again and turn off?
Old Nov 20, 2006 | 05:26 PM
yep,
supposed to start working with centrifugal force.....
but you never know..
Old Nov 20, 2006 | 09:01 PM
Registered Tracker
yep, or if you have the wheels with the tires on in a close proximity to the car
Old Nov 21, 2006 | 12:26 AM
all i can say is someone put 4 sensors in a pressurised tube to have the same effect...
did not work..
Old Nov 21, 2006 | 12:51 AM
Mazdaspeed RX8 ver2's Avatar
i got to agree with swoope on this one, it starts working with cetrifugal force.
Old Nov 21, 2006 | 10:36 AM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
The shop manual says they start to work at 16mph.
Old Dec 4, 2006 | 08:58 PM
StewyRX8's Avatar
Bet Like a Champion Today
I know, im reviving an old thread here, but mine does the same thing, but goes away soon after...
Old Dec 5, 2006 | 10:09 PM
StewyRX8's Avatar
Thanks abbid!
Old Dec 6, 2006 | 01:51 AM
BigOLundh's Avatar
#1 Legend
so why does it go off when you start hte car and the car is still??
also, nobody ever answered how it communicates to the factory computer.
-hS
Old Dec 6, 2006 | 10:14 AM
zenmoused's Avatar
the stig is my hero
they work via rf and communicate with a central receiver, which in turn talks to the computer. I would have to agree that they are on when the car is started, as there would otherwise be no way for the car to produce that tpms light sometimes but not others. I would probably guess they turn off after a period of inactivity (motion stops), but receive a turn-on signal from the receiver when you switch on the car's computer.
Old Dec 6, 2006 | 11:57 AM
They must work as soon as the car is started because a month ago, that's what happened to me. I hadn't driven the car in 2 days, turned it on and immediately got the low pressure light. (one tire was almost completely flat)
Warrior777
Jun 24, 2019 04:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
TeslaMSI
Dec 10, 2015 01:10 AM
michaelsk8er
Nov 9, 2015 07:06 AM
ShadowDragon78
Aug 21, 2015 03:29 PM
