mikeschaefer
11-07-2006, 01:51 PM
Well I started her up today to take her out for the first test drive with the turbo and found that my clutch pedal feels funky. It engages when just lifting off the pedal ever so slightly. I was thinking that the hydraulic system uses vacuum like the brakes, but I was still able to drive it and it builds boost to 5 psi and drives fine so I don't think there is a vacuum problem. The brakes work just fine, and it also idles around -60 kPa, which from what I gather is pretty decent.
I just read the clutch TSB and I'm pretty sure it's never been performed on my car, but I think it's a big coincidence that it would happen right after installing the turbo.
I know I didn't damage any wires or lines during the install, and my brake/clutch fluid reservoir is full. Is there anything I could be missing or am I just going to have to take it in for the clutch TSB? (trying to maximize the amount of time before I let the dealer know I installed a turbo :p: )
Oh, and there are no strange noises either.
Also, the clutch pedal was being weird yesterday when I did an idle check after the turbo install. It went to the floor like it's doing now but after a few pumps during idle it felt like the pressure built back up and it was fine. Today, I can't get the pressure to build back up.
This problem feels exactly like what happened in my last car (civic) when I found out I had a slow leak. The master cylinder reservoir level would slowly go down over the course of a couple of weeks and I would just have to fill it back up, start the car, and pump the pedal a few times and it would be back to normal. I don't think the problem is the same but I described it because the symptoms are the same.
Thanks in advance for any input!
