View Full Version : e-brake light
ca18detsilvia
11-06-2006, 01:00 AM
hey guys, the past few days my e-brake light has been coming on and staying on when the e-brake is fully down, the break is not draging or anything, the light is just coming on, one time it came on when i went fast around a corner, anyone know what may be causing it, its just annoying
Old Rotor
11-06-2006, 01:32 AM
There is a switch connected to the e-brake, its loose, bad or needs adjustment. Remove the cover its an easy fix or might be covered under warranty. It could be your pads, how many miles do you have?
Rhythmic
11-07-2006, 02:48 PM
I had the exact same thing happen. The light came on right after going around a corner fast. The light stayed on intermittently for about a week. It turns out I need new pads. After new pads installed the light went away for good.
>Check your pads.
zoom44
11-07-2006, 03:08 PM
yep get your pads and fluid checked
dupa12345
11-07-2006, 03:19 PM
new pads .. mazdas dumb way of telling you that
