View Full Version : Drive By Wire Throttle Wiring Question
brillo
11-06-2006, 12:28 AM
looking at the service manual, it apears that there are 6 wires connecting the PCM to the Throttle Body Control. From the wiring diagram and the service manual, it appears that there are 2 wires that send the signals to the TB to control the throttle plate. the other four are grounds, power and a return signal?
When you view the info on the throttle position sensor, which ties to the TB, one of these two wires have as voltage range 0.4 to 4.095 (wire 1J) and the other has a votage range of 1.18 to 4.303 (wire 1M). Obviously there is some over lap there.
can someone help me understand why there are two wires? why the overlap?
zoom44
11-06-2006, 01:32 AM
i dont have the book in front of me. ill give you a call when i find it:)
MazdaManiac
11-06-2006, 01:49 AM
There are two throttle position sensors that act independently of each other, acting as a sort of parity check. The throttle actuator is actually a servo and runs on a PWM signal.
http://www.rx8club.com/attachment.php?attachmentid=88510&stc=1
http://www.rx8club.com/attachment.php?attachmentid=88511&stc=1
zoom44
11-06-2006, 01:50 AM
never mind:)
cajunrx8
11-06-2006, 03:31 AM
It ia a feedback potentiometer system. As the volts go up on no.1,volts go down on no.2 and vice/versa. Really not a hard system to understand if you have worked on Const. equipment, pretty much all machines use this system now.
brillo
11-06-2006, 09:45 AM
Interesting. my reason for asking is I'm trying to better understand your typical DBW system as thats the last engine related subsystem I don't know how to manipulate.
If you wanted to alter the throttle plate outside of the pcm, would you just tap the throttle actuator wires? Jeff, could label the six wires in that diagram so I know which ones are power, ground etc....?
MazdaManiac
11-06-2006, 11:36 AM
Here:
http://www.rx8club.com/attachment.php?attachmentid=88518&stc=1
ZoomZoomH
11-06-2006, 11:41 AM
ah, redundancy, makes me feel much safer about the DBW system on my 8 lol
brillo
11-06-2006, 12:00 PM
So from the pics I assume that the PCM reads the various TPS signals and then sends the voltage to the throttle body motor?
so the flow of info would look like
TPS -> PCM -> Throttle Motor / PCM reads the new TPS info -> Thottle motor etc....
The PCM is going to see that the TPS shows some minimum value at startup, and then just constantly plays a back and fourth game with motor adjustments?
My canscan always shows a min load of 17%, is that its way of showing how the throttle is always slightly open?
MazdaManiac
11-06-2006, 12:53 PM
So from the pics I assume that the PCM reads the various TPS signals and then sends the voltage to the throttle body motor?It is a pulse, not a voltage. Duty cycle determines throttle opening.
My canscan always shows a min load of 17%, is that its way of showing how the throttle is always slightly open?Yes. That is the idle %.
brillo
11-06-2006, 05:25 PM
Duty cycle? thats interesting. Not how I figured it would work. Is that more for most DBW vehicles? Any idea why they did that? I guess its similar to how the PCM treats the fuel injectors then?
MazdaManiac
11-06-2006, 06:20 PM
Exactly. Wider pulse equals more throttle opening. That is why the thing makes that "buzzing" sound.
Try putting the key in the run position without starting the motor in a quiet place and listen how the sound changes as you step on the gas. The pitch stays the same, but the timber changes from a tiny, "buzzy" sound to a rounder, more "flute" like sound as the throttle opens.
This is the pulse width going from a short duty cycle (5% or so) to a longer duration (50% or even more) while the period remains the same.
cajunrx8
11-06-2006, 07:02 PM
For a little lite reading this will give you a better idea of FBW.
http://www.picotech.com/auto/applications/electronic_throttle_control.html
brillo
11-06-2006, 07:06 PM
it seems wierd to me that they would use a duty cycle approach to the throttle motor, i understand why it makes sense for fuel injectors or ignition, but seems wierd to me to use the same methodolgy for throttle control. Maybe they do it because the stock PCM sends out so many pulse signals already, its a more cost effective setup?
back to manipulating the DBW for a minute, I know the stock pcm has some wiggle room as far as what it deems ok for idle before it throughs a CEL, what if you were able to tap the TPS wires and send the PCM a signal back that has a voltage lower that "reality"? would the PCM then try to adjust the throttle by opening the plate more thereby raising the rpm?
could you build a device that basically allows the TPS voltage to be adjusted up or down for the PCM? Hopefully my concept makes some sense.
Cajun - excellent article which I didn't see before my post, thanks.
MazdaManiac
11-06-2006, 07:10 PM
^^ You would have some "interesting" issues when driving.
PWM is just a more accurate way to control a positional motor. This is the way it is done in robotics and aeronautical endeavors. If you just feed a motor DC until it is in position, it will drift. By having a stepper motor referenced to a pulse, it will always be in an exact position each time it is commanded by that pulse.
brillo
11-06-2006, 07:18 PM
Are there relatively simple was to adjust PWM? my limit EE knowledge doesn't stretch that far.
cajunrx8
11-06-2006, 07:39 PM
Well the pulse signal will index the motor 1 degree per pulse, as duty cycle is increased, the pulse is longer and the motor travels more degree's per pulse.
This is a stepper motor, the output shaft moves in steps as a driver signal is sent to the motor, is also reversable by flipping the A-B motor wire polarity.
Yes you can/could tap the signal and change the readings, however if you get above below the preset values in the ECM it will spit a code and the second TPS will have to be manipulated also otherwise the 2 values won't match
Why do you want to attempt this?? The system is redundant to prevent throttle motor from going full open or closed due to a short or broken wire. Tapping into the harnesses is not really good to do in this system. Any resistance introduced in the system can cause it to go into limp home mode if the feedback signals are out of range.
Hope this helps, Steve
brillo
11-06-2006, 07:51 PM
I'm curious about all this as I've got a good idea how to manipulate nearly all the engine functions with a standalone except throttle control. Its a subject that I'm trying to learn more about as obviously DBW is hear to stay.
in addition, I would like to be able to make some small idle adjustments for smoothness. I believe the changes I would need to make are small enough not to be noticed by the pcm as they fit in their margin for error.
olddragger
11-06-2006, 08:03 PM
dont mess around and get a run a way--its not purty.
OD
brillo
11-06-2006, 08:11 PM
OD
hence my questioning before I even really consider anything :D:
TeamRX8
11-06-2006, 09:21 PM
several japanese tuners offer an electronic throttle control modifier, as I understand it you can change the rate at which the throttle body responds relative to gas pedal position change, not sure if it works on US models, don't know that anyone has ever tried it or not
brillo
11-06-2006, 09:33 PM
I looked at Greddy, HKS and RE Amemiya didn't see anything, you don't recall who made one do you?
Gomez
11-06-2006, 09:34 PM
BTW, you get full throttle well before the pedal hits the floor.
MazdaManiac
11-06-2006, 09:51 PM
Actually, you get all you're gonna get around 80% of pedal travel, which is about 90% of WOT.
The PCM doesn't do WOT for some reason.
Gomez
11-06-2006, 10:04 PM
100% of 90% at 80%.....that's pretty good.
Gotta be happy with that!!
MazdaManiac
11-06-2006, 10:10 PM
I suppose. I imagine Mazda found max power at something less than WOT.
TeamRX8
11-06-2006, 10:19 PM
A-RF sells one, good luck, classic f'd up japanese site:
http://www.a-rf.com/PC/PartsList/CarTypeParts/SE3P/EcuParts/index.html
zoom44
11-07-2006, 11:40 AM
brillo if you want to change your idle why not just drill a small hole in the throttle plate:)
brillo
11-07-2006, 12:14 PM
I could do that (not sure if it would work) but I really want to understand how to manipulate the DBW system. I've learned how to basically through a standalone ECU on virtually any car now thanks to my experiments with the megasquirt and Interceptor, but neither of those can control DBW.
I'd like to be able to know if necessary how to defeat DBW should I find myself looking at another car wanting to modify/tweak it.
dsmdriver
11-07-2006, 07:20 PM
Why aren't you trying to mess with the throttle pedal instead of the throttle plate?
I don't think the car will be happy if you open up the throttle plate without the ECU asking for it. It's really easy to just mess with the resistance at the throttle pedal and let the ECU do whatever it wants based on that.
cajunrx8
11-07-2006, 08:45 PM
I would be willing to bet you that the fault tolerance in this system is less than 1/2 a percent. Therefore any changes you make will be seen by the PCM, if they are not seen it will not effect any noticeable change.
As for idle adjustments, what are you looking to really do? Is it an issue with smoothness at a perticular idle speed or more with loading at certain speeds.
These issues might be better addressed with fuel mapping.
My 0.02
dsmdriver
11-07-2006, 09:44 PM
Also, it sounds like Cobb and others are about to let us change a whole bunch of stuff in our ECU's very soon. Waiting to do that and tweaking the code is probably going to be the best option out there.
brillo
11-08-2006, 11:40 AM
Hopefully Cobb will be able to alter and flash all parts of the PCM. Racing Beat, the only company to have sucess with flashing to date, was not able to alter the DBW settings as they were stored in a seperate part of the PCM they could not access. That doesn't mean Cobb won't have better luck, but its obivously not a easy process.
