What is the Apex seal?
Old Nov 2, 2006 | 01:07 PM
tubbee's Avatar
Hi guys and gals,
Been reading about the Apex seal, I am told this should be changed after a while. My question is, what is the apex seal? And how long before I need to change it.
Lastly, been told the beloved rotary engine doesnt last long, around 100,000km. I guess no one has reached that stage yet. My question, is this true?
Curious.
Tubbs
Old Nov 2, 2006 | 01:19 PM
yiksing's Avatar
the giant tastetickles
I wouldn't even bother to flame you, here you go http://www.rotaryengineillustrated.com/
Old Nov 2, 2006 | 03:17 PM
tubbee's Avatar
Cool thanks....
You may flame if you wish, just wanted to learn a bit more abt these engines. I am new to them!
Tks.
tubbs
Old Nov 2, 2006 | 09:19 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by tubbee
Hi guys and gals,
Curious.
Tubbs
APex seal change - after a while??? so long as u use the correct oil, there shldnt be any change "after a awhile". Whoever told u dat DO NOT know rotary engine.
Rotary engine dun last long - Myth again. if it only last 100,000km, we can throw the car away. Again, its all up to the maintenance of the car. If engine oil dun change, regular maintenance dun do, even normal piston engine car oso cun last 100,000km.
Hope this clears ur doubts.
Old Nov 2, 2006 | 10:12 PM
Silver_Z's Avatar
Coupe07,
Everytime I see the illustration of the rotary engine, it shows 1 chamber thru the 3 process of intake, ignite, exhaust. But in actual fact, all 3 chambers of the rotor is at work right? Just wanna confirm my belief that they use 1 chamber for ease of explaining. Thanks.
Sorry to hijack this thread.
Old Nov 2, 2006 | 11:05 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by Silver_Z
Coupe07,
our engine is 2 rotors, so 2 "chambers" if that's wat it is called. When engine is running, the 2 rotors are turning. Yup, 1 chamber is for illustration purpose since the 2nd one does the same thing at different timing.
2 rotors = 13B. 3 rotors = 20B.
Old Nov 2, 2006 | 11:45 PM
Silver_Z's Avatar
Sorry, mabbe I never ask correctly. What I mean was, per rotor there is 3 err... "space"/chamber. So if 1 was drawing air, the other will be at ignite stage and the last at exhaust stage. Right? Or only 1 side of the rotor(triangle) is used?
Old Nov 3, 2006 | 12:42 AM
coupe07's Avatar
SC 300HP!!
i tink this shld answer ur question.
http://www.rotaryengineillustrated.c...imation-4.html
Old Nov 3, 2006 | 03:06 AM
Silver_Z's Avatar
I seen this. Like all animation, it only shows 1 side of the rotor being used. Does that mean the other 2 sides are not in used or they omit showing it, so as not to confuse viewers. As a rotor has 3 sides, while 1 side of the rotor is igniting, are the other 2 sides releasing exhaust and drawing intake?
Old Nov 3, 2006 | 03:42 AM
mkl22's Avatar
Yup. the combustion is always in the chamber where the spark plugs are.
Old Nov 3, 2006 | 05:04 AM
sqflyer's Avatar
Heavy Machinery Operator
Yes, Silver_Z... All 3 sides of the roter are working simultaneously. While 1 side is in the intake/compression phase, 1 side is in the combustion phase and the other 1 side is in the exhaust phase all at the SAME TIME.
Naturally for ease of explaination in the animation, the phases are broken down and explained one phase at a time, but all 3 phases happen at the same time in different 'chambers' or sides of the rotor.
Old Nov 3, 2006 | 09:53 AM
yiksing's Avatar
Curious.
Tubbs
Since you are interested in reliability, search the forum for premix and don't miss any rotarygod's tech threads.
Old Nov 3, 2006 | 12:00 PM
no dice's Avatar
I bomb atomically
100,000 km is 62k miles?
I just passed 60k miles yesterday.
Old Nov 4, 2006 | 05:34 AM
tubbee's Avatar
Great info. guys!!!!
The onl reason why I asked was because I had friends telling me the previous Rx-7 generation had problems with their engines, they were breaking down prematurely.
Glad to know the newer ones are better.... with proper maintenance of course.
Thanks!!
Tubbs
Old Nov 4, 2006 | 09:57 AM
coupe07's Avatar
SC 300HP!!
Thanks!!
Tubbs
The rx7 is not problematic. It appears problematic bcos there are no proper workshop to handle the engine....
Old Nov 5, 2006 | 07:45 PM
Silver_Z's Avatar
Thx for the confirmation.
92trbolzr
May 18, 2025 09:04 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Tgiolitto100
Sep 29, 2015 10:52 AM
pjwermuth
Sep 28, 2015 11:36 PM
DG07
Sep 28, 2015 10:58 AM
