Need Wiring info on Alarm Shock sensor upgrade. (NOT a standard install)
Old Oct 31, 2006 | 10:00 AM
toxin440's Avatar
Hello.
I recently purchased an alarm shock sensor kit from a forum member here - and unfourtunatly it didnt have the wiring harness that connects to the shock sensor itself. Turns out its impossible to get this little wire by itself without buying the whole kit.
I'd love to get this working ASAP without having to either return this to the guy I bought it from, or having to go and blow another 50 bucks on ANOTHER one just for a stupid wire. The part im missing is the little plastic (i think its 4 pin) connector that plugs into the shock unit itself.
What i need is a wiring diagram that will show me which wires go to which pins on the shock sensor to the wire taps i have to plug into the wires under my dash.
My general plan if I can know which wire to connect to which pin is to solder something up and rig it to work without having the little plastic connector
Any help (and tons of pics) is greatly appreciated.
Jeff
Old Oct 31, 2006 | 02:51 PM
Go to a Mazda dealer parts department.
They should be able to help you. (Tell them exactly where the location is, they should be able to find the wire for you, or try to find out the wire's part number(
RXeckless
Aug 16, 2015 12:52 PM
RXeckless
Aug 16, 2015 12:51 PM
MolecularConcept
Aug 5, 2015 04:43 PM
yapakanichi
Jul 20, 2015 02:17 PM
