Fluid4
10-29-2006, 11:46 AM
i am abt to change my rims n tyres after my 8 is reg...
but was told by the tyre shop that F1 only got 235/40...is it true?
will it affect the driving?
would prefer 225/45 as per stated in the catalog from japan....
care to advise?
thankz....
I have Kumho SPT 235/40 on my car right now... height is almost close to stock and ride is slightly changed due to the shorter sidewall.
Fluid4
10-29-2006, 09:51 PM
any side effect?
how is the driving?
can't really tell you the difference since I installed stiffer springs and sway bars the same time I mounted the tires... the ride is much stiffer than stock and I'm pretty sure the lower profile tires contribute to it but I'm not sure by how much. Also I'm runibg 38 psi of nitrogen...
mysql101
10-29-2006, 10:13 PM
they make it in other sizes. I used F1 with 19" rims...
Fluid4
10-30-2006, 11:24 AM
where u get ur sway bars?n wat spring u using?
