ATF OIL info
Old Oct 25, 2006 | 09:00 AM
madmax_rx8's Avatar
ATF OIL info
Hi all,
I would like to ask a few question.
1. How many liters do we need if we going to change our ATF oil.
a. Any ppl knw where i can get reasonable price of RED LINE ATF oil...
2) The LSD at the rear uses what sort of oil... is it the same as the ATF oil that we using for our gear box?? if it is not what oil do we normally use...
regards
Kelvin Koh
Old Oct 25, 2006 | 09:18 AM
StealthTL's Avatar
Metatron
Cool
Sorry, can't answer the ATF questions, but the rear end LSD uses "GL5" 75W90 oil.
Redline's GL5 oil is very good.
S
Old Oct 25, 2006 | 09:42 AM
foo77's Avatar
4th batch : Apr 03'
you can find many threads about it.. anyway,i'm just in good mood today,so lets me help you here's the website where i ordered the RP ATF Dexron III:
http://www.mxtradings.com/
FYI you might need 9-12 liters on ATF
Old Oct 25, 2006 | 10:34 AM
theboy's Avatar
RX8 newbie!
how to change LSD oil?
Old Oct 25, 2006 | 12:13 PM
coupe07's Avatar
SC 300HP!!
Originally Posted by madmax_rx8
Hi all,
regards
Kelvin Koh
LSD using either 75W90 or 80W90 gear oil. u cannot use gearbox oil as ATF oil... different.
ATF using dexron 3 for our car.
Old Oct 25, 2006 | 05:17 PM
foo77's Avatar
4th batch : Apr 03'
^ what coupe said you only can use 75W90 for both transmission and differential when your car is manual as for auto you just need 75W90 for gear and ATF Dexron III for transmission
theboy you can change the LSD oil at the rear,you can find it easily
Old Oct 26, 2006 | 04:45 AM
madmax_rx8's Avatar
Hi all thanks for the knowledge sharing at least now i knw tks alot
Old Oct 28, 2006 | 05:46 AM
madmax_rx8's Avatar
Hi guys last questions before i close this thread
How many liters of ATF oil and LSD oil do i need if i going to to change my current oil
tks
Old Oct 28, 2006 | 09:52 AM
Rotor Kreuzer's Avatar
The 8th Deadly Sin
The manual says ~9l for ATF, and ~2l for the gear oil. If you look through some of the threads, some are saying 12-13l for a complete flush of the ATF.
Old Oct 28, 2006 | 08:42 PM
theboy's Avatar
RX8 newbie!
wayloco
Sep 1, 2015 09:03 PM
Sifu
Aug 30, 2015 10:51 PM
MolecularConcept
Aug 5, 2015 04:43 PM
