View Full Version : 2K3 BUGS.....and Im not talking about computers!
RX8-TX
09-02-2003, 01:08 AM
http://www-odi.nhtsa.dot.gov/cars/problems/tsb/results.cfm
Just run a search on '03 Nissan 350Z model....or read below:
Technical Service Bulletins - Search Results
Report Date : September 2, 2003 at 02:02 AM
TYPE : VEHICLE
YEAR : 2003
MAKE : NISSAN
MODEL : 350Z
Make : NISSAN Model : 350Z Year : 2003
Service Bulletin Num : 02120A Date of Bulletin: JUL 07, 2003
Component: SERVICE BRAKES, HYDRAULIC:ANTILOCK
Summary:
VEHICLE MAY EXHIBIT ANTILOCK BRAKING SYSTEM (ABS) LIGHT ON AND / OR DIAGNOSTIC TROUBLE CODE FOR ABS WHEEL SPEED SENSOR. VARIOUS MODELS INCLUDING THE 2004 QUEST AND MAXIMA. *TT
Service Bulletin Num : 03046 Date of Bulletin: APR 25, 2003
Component: SUSPENSION
Summary:
STEERING DRIFT TO THE RIGHT. *TT
Service Bulletin Num : 03029 Date of Bulletin: APR 02, 2003
Component: VISIBILITY:GLASS, SIDE/REAR
Summary:
GREASE MARK OR STREAK ON INSIDE OF DOOR GLASS AFTER THE WINDOW HAS BEEN LOWERED AND THEN RAISED. *TT
Service Bulletin Num : NTB02101A Date of Bulletin: FEB 05, 2003
Component: ENGINE AND ENGINE COOLING:ENGINE
Summary:
ON SOME VEHICLE'S THE ENGINE WILL NOT START. *JB
Service Bulletin Num : NTB02070A Date of Bulletin: FEB 05, 2003
Component: TIRES:PRESSURE MONITORING AND REGULATING SYSTEMS
Summary:
INFORMATION ON LOW TIRE PRESSURE MONITOR SYSTEM. *JB
Service Bulletin Num : 03006 Date of Bulletin: JAN 23, 2003
Summary:
TIRE ROAD NOISE WHEN BRAKING. *TT
Service Bulletin Num : 03001 Date of Bulletin: JAN 09, 2003
Component: INTERIOR LIGHTING
Summary:
INTERIOR COURTESY LAMPS INOPERATIVE. *TT
Service Bulletin Num : 02120 Date of Bulletin: DEC 05, 2002
Summary:
VEHICLE MAY EXHIBIT ANTILOCK BRAKING SYSTEM (ABS) LIGHT ON AND / OR DIAGNOSTIC TROUBLE CODE FOR ABS WHEEL SPEED SENSOR. *TT
Service Bulletin Num : 02115 Date of Bulletin: OCT 25, 2002
Summary:
MALFUNCTION INDICATOR LAMP ON WITH DIAGNOSTIC TROUBLE CODE P0442 (EVAP SMALL LEAK) IN SELF DIAGNOSIS RESULTS. *TT
Service Bulletin Num : 02102 Date of Bulletin: OCT 09, 2002
Component: POWER TRAIN:MANUAL TRANSMISSION
Summary:
MANUAL TRANSMISSION SHIFT KNOB NOT STRAIGHT. *TT
Service Bulletin Num : 02101 Date of Bulletin: OCT 03, 2002
Summary:
ENGINE WON'T START, KEY FOB INOPERATIVE AFTER BODY CONTROL MODULE (BCM) REPLACEMENT. *TT
Service Bulletin Num : 02100 Date of Bulletin: OCT 02, 2002
Summary:
TIRE PRESSURE MONITOR SYSTEM (TPMS) WARNING LIGHT FLASHES OR STAYS ON. *TT
Service Bulletin Num : 02097 Date of Bulletin: OCT 01, 2002
Component: EQUIPMENT:ELECTRICAL:AIR CONDITIONER
Summary:
BUZZ OR GROWL TYPE NOISE FROM ENGINE AREA WITH AIR CONDITIONER ON. *TT
Service Bulletin Num : NTB02097 Date of Bulletin: OCT 01, 2002
Component: ENGINE AND ENGINE COOLING:ENGINE:GASOLINE
Summary:
INFORMATION ON DIAGNOSING NOISE FROM THE ENGINE AREA WITH THE AIR CONDITIONER ON. *TT
Service Bulletin Num : 02098 Date of Bulletin: SEP 26, 2002
Component: VISIBILITY:WINDSHIELD WIPER/WASHER
Summary:
WINDSHIELD WASHER FLUID SEEPAGE. *TT
Service Bulletin Num : NTB02098 Date of Bulletin: SEP 26, 2002
Summary:
INFORMATION ON VEHICLES EXHBITING WINDSHIELD WASHER FLUID SEEPING FROM UNDER THE RIGHT FRONT AREA ESPECIALLY AFTER REFILLING THE WASHER FLUID RESERVOIR. *TT
Service Bulletin Num : NTB02077 Date of Bulletin: AUG 01, 2002
Component: OTHER
Summary:
SUBJECT REGARDING ESSENTIAL TOOL: TIRE PRESSURE MONITOR SYSTEM INITIALIZATION TOOL. *JG
Service Bulletin Num : NTB02075 Date of Bulletin: JUL 17, 2002
Component: POWER TRAIN:AUTOMATIC TRANSMISSION
Summary:
SUBJECT REGARDING SPECIAL AUTOMATIC TRANSMISSION FLUID REQUIREMENTS. *JG
Service Bulletin Num : NTB02071 Date of Bulletin: JUL 15, 2002
Summary:
SUBJECT REGARDING ENGINE NOT STARTING OR NVIS/NATS SYSTEM DESCRIPTION AND KEY REGISTRATION. *JG
Service Bulletin Num : NTB02070 Date of Bulletin: JUL 15, 2002
Component: TIRES
Summary:
SUBJECT REGARDING LOW TIRE PRESSURE MONITOR SYSTEM. *JG
Service Bulletin Num : NTB02072 Date of Bulletin: JUL 15, 2002
Component: ELECTRICAL SYSTEM:BATTERY
Summary:
SUBJECT REGARDING BATTERY SERVICE PRECAUTIONS. *JG
Excellent....Nissan quality! (seems Jap engineers have something in common, don't they?)
RX8-TX
09-02-2003, 01:16 AM
Ehhhh...could a moderator close this thread....I didn't intend to create a new thread. SORRY!
:D
ToRX-8orToZ
09-02-2003, 02:02 AM
Yet the RX-8 has had many more serious problems at launch... really puts things into perspective.
Spin9k
09-02-2003, 04:50 AM
OK ToRX-8orToZ I'll bite - please list these 21+ "more serious problems", you speak of, can you???
While you are at it, also explain why there are no complaints, no defect investigations, no service bulletins, no recalls whatsoever for the RX-8 on the NHTSA site? Must be a government conspiracy to help Mazda, right?
I think THAT puts YOU into perspective. Yes? :D
