Will these tire fit
Old Oct 19, 2006 | 12:10 PM
turbor87's Avatar
Will these tire fit
i was wondering if 275/35r18's will fit all the way around on a 18X9 with a 38 offset
Old Oct 19, 2006 | 06:31 PM
unreal89's Avatar
I don't mind pistons
well, stock tires are 8" wide, with 225 tires. They can fit up to 245 wide tires. Your rim is 9" wide, and 275's are 3cm wider than 245. 1" = about 2.5 cm. So its like fitting 250 wide tires on the stock rim. I should work, but im not 100% sure. I know they fit 9.5's easily.
Old Oct 20, 2006 | 10:51 AM
ac3mastuh's Avatar
Got Ings?
i don't think you can fit that much tire up in the front. what are you going to be using this car for? i think there is someone on this forum who runs 275's front but i still think you are going to get some serious rubbing issues. if this is going to be a daily driver i would avoid going that big on the front. many people fit the 275 rear with offsets of about mid-30's or more so i think you will be fine there
i would also really avoid going with the absolute minimum rim width to fit that tire. unless your pressures are just right i think you are going to wear out the centers of your tread much faster than the edges
just my $.02
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
OnebaddRx8
Oct 17, 2015 10:05 PM
CMRine04
Sep 17, 2015 10:04 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
