Cut Engine at 300RPM - Helps Something?
Old Oct 18, 2006 | 11:34 AM
danhilde's Avatar
Cut Engine at 3000RPM - Helps Something?
I'd like to verify that something I do in my 8 is, in fact, useful. This may or may not be related to flooding. I searched on 'gun engine' and have not seen this particular one.
When I am about to turn off my engine, I "gun" the engine slightly and turn the key off when it is at about 3000 RPM.
Does this help to clear the so called chamber?
I live in Arizona where we don't have too much in the way of cold temps so flooding may simply not be a risk here.
Thanks ...
danH
Old Oct 18, 2006 | 11:38 AM
expo1's Avatar
He's as bad as Can
You really only need to do that when turning off a COLD engine. I have over 77,000 and never flooded and only do the 3,000 RPM thing when the engine is cold.
Old Oct 18, 2006 | 11:44 AM
danhilde's Avatar
Ok, that's good information. Maybe it can serve to help folks who are in colder climates with the flooding issue. Thanks.
Old Oct 18, 2006 | 11:47 AM
Huey52's Avatar
Registered Zoom Zoomer
Hold at 3,000 rpm for ten seconds per the manual, and as cited, only when cold.
Old Oct 18, 2006 | 11:53 AM
RotrDoc's Avatar
From: I've shaken off the sands of SouthWest Asia and returned to Houston and Gulfport, MS
Change the title of this thread (300 rpm??)
Old Oct 18, 2006 | 12:44 PM
danhilde's Avatar
Thanks RotrDoc; I did edit the Title. Isn't showing yet; must have to be approved by a moderator I'm guessing.
Old Oct 18, 2006 | 01:23 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
When the car is warm it is largely up to the individual whether they want to spin the engine above 3K and shut it off as it's revving down.
I did it at first then stopped. However, the warranty flash and changes has made my car fire up a tad bit slower at times then before so I'm going to start doing it again just in case.
Old Oct 18, 2006 | 01:34 PM
Rhythmic's Avatar
Laid back in the pocket
Should you hold at 3k, let off, while revs drop kill ignition? Or, wait until engine reaches idle? I heard from a buddy that has 200k mi. + on rotaries say that it's not good to cut ignition while revs are still up? Is this true?
Old Oct 18, 2006 | 01:42 PM
Huey52's Avatar
Turn off the ignition key as you take your foot off the accelerator. Therefore, while it is still at relatively high rpm. The whole point of this procedure is to expunge excess fuel from the rotor combustion chambers.
Audio Concepts ATL
Sep 26, 2021 01:59 PM
vapor2
Nov 3, 2020 03:38 PM
escapedan
RX-8 Racing
58
Feb 10, 2020 06:11 PM
Pelleilee
Sep 29, 2019 10:07 AM
Ajmurphy85
Jul 30, 2015 07:51 AM
