Spark Plug Choice with Turbo
Old Oct 16, 2006 | 07:33 PM
sprootz's Avatar
I have heard horror story of using The NGK EIX range (BR 9-EIX) due to the fragile tip snap causing catastohic disaster
BR9-EV & BR9 EGV, BUR-9EQ is also an option ( NGK Brand BTW)
Apparently non resistor plug is good also ??
Any thought ?
Old Oct 16, 2006 | 07:36 PM
mysql101's Avatar
http://store.summitracing.com/partde...?part=ngk-5255
(stock photo, doesn't look like the actual plug)
Old Oct 16, 2006 | 08:44 PM
sprootz's Avatar
Thanks very much
Do you use the plugs in the leadding and the trailing or do you use a 7 in the leading .
Sorry another question , If you have the 7 L and 9 T can you safely use 15psi or do you need to run colder say 9L & 10Trailing
Thanks for helping
Old Oct 16, 2006 | 08:50 PM
mysql101's Avatar
I am using it for leading and trailing. Mazsport recommended this type of plug, and others here are running them on FI.
Old Oct 16, 2006 | 09:03 PM
Anyone try Denso?
Old Oct 16, 2006 | 09:23 PM
OfficerFarva's Avatar
I used the densos.
Old Oct 16, 2006 | 09:33 PM
Where did you buy them?
I couldn't find any place out here so I sent an Email to Denso and they never replied back.
they list Autozone as a dealer, however they don't carry them and refuse to special order them!
Old Oct 16, 2006 | 09:41 PM
sprootz's Avatar
Heres a quote from a perforance guy specialising in RX7's
BUR 9EQP Causes rotor housings to crack around ther firing end of their locations due to localised overheating of the surrounding alloy
Is this a fair comment ?
Has anyone used B9 EGV ?
Old Oct 16, 2006 | 10:40 PM
www.sparkplugs.com
The Densos are definitely pricey but are worth it. I checked at an Advanced auto parts before I bought mine and all they carry or could order I think were the NGK plugs. I have never heard of anyone on the forum using the B9 EGV.
Old Oct 16, 2006 | 10:53 PM
kartweb's Avatar
Any thought ?
NGK's don't hold up very well to detonation, the bottom electrodes tend to break off.
Old Oct 17, 2006 | 03:31 AM
Fanman's Avatar
I use the RE8A-L NGK's (1 heat range colder than stock) for the leading units. I tried the Densos for both the leading & trailing. Car ran a bit rougher than when I had the NGK units.
Old Oct 17, 2006 | 07:50 AM
MadDog's Avatar
Consiglieri
I had the Denso Iridium plugs at first. Then I switched back to stock. I don't think colder plugs are necessary unless you are trying to stop a known detonation issue caused by the plugs . I haven't had any detonation with the stock plugs so there they'll stay.
Old Oct 17, 2006 | 08:13 AM
sprootz's Avatar
Will Standard plugs (7L, 9T) Handle 15psi ??
Old Oct 17, 2006 | 09:37 AM
MadDog's Avatar
Consiglieri
The real question here is how you're going to get 15psi. The GReddy turbo isn't going to get you there. If you have a larger turbo, you aren't going to be running 15psi, either. Not because you can't, but because the power output would be putting you into uncharted territory.
15psi is not realistic. Stop worrying about your plugs.
Old Oct 17, 2006 | 11:46 AM
howardteets's Avatar
http://www.densoaftermarket.com/cata...ZDA&model=RX-8
Click on the part number. A window will pop up with a spot to enter your zip code it will list local dealers to you or there's a link to order on-line.
Old Oct 18, 2006 | 05:39 PM
sprootz's Avatar
I am NOT using a Greddy .What let you to that assumption
I have a GT35 style custom turbo that blowing 13psi NOW
My question was specific to plugs because I am using a Motor cycle style one( BR 10-EIX ) that has been said the tip will drop off .
I hear many story about plug so I ask question .
I think this reoson to worry ,Sorry to offend but i dont want pieces of plug destroying the engine .
Old Oct 18, 2006 | 07:25 PM
MadDog's Avatar
Consiglieri
If you have a GT35R running at 13psi, it seems like you'd have one of the most powerful Renesis engines to date. Any numbers to back that up?
Old Oct 18, 2006 | 08:47 PM
sprootz's Avatar
12.7 quarter mile with wheelspin
Ill post something when I go back to the track
Old Oct 18, 2006 | 08:55 PM
sprootz's Avatar
I believe the PR guys were putting more power more than 1 year ago .And they use a 35/40 turbo.
Manuel's car ,I think put nearly 400 hp .My car is not this powerful
Old Oct 18, 2006 | 10:56 PM
I thought the PR guys are using 20b ?
Old Oct 18, 2006 | 11:23 PM
sprootz's Avatar
Manuel started with the Greddy ,then the custom setup I was talking about then 20 b Monstor
I think it look like I might go 20B as well .Just need more money
Wife say
Old Oct 18, 2006 | 11:43 PM
Sounds like u need sum wide tires and wheels in the back and u could be makin sum pretty good times.
Old Nov 4, 2006 | 09:57 PM
Bart!'s Avatar
RAWR!@#
Do your bur9eq's have the p at the end of the model on the plug its self, or does it just say bur9eq?
Old Nov 5, 2006 | 05:43 PM
sprootz's Avatar
Just answered otherthread sorry
Is there any different platinum or not besides longer life ..better spark too ??
Old Nov 6, 2006 | 09:26 AM
slavearm's Avatar
Boost Junkie
Supposedly the platinums have less debris due to a different manufacturing process that decreases the amount of energy required for the spark to jump... meh who knows if it really makes a difference....
Oh... I have seen 14PSI.... just waiting for my ingition upgrade to keep up.
