View Full Version : RE-AMEMIYA's 2nd visit to S'pore
coupe07
10-16-2006, 12:48 PM
Dear All,
Staff from RE-Amemiya are coming down to do up a few projects and of course, to do the re-map of rx8 ECUs.
Due to the OVERWHELMING response we have received so far, we may not be able to cater to all members. However, we will try to satify every member of the forum who are interested.
Dates: 30th Nov and 1st Dec tentative
As for how effective and what it can do, i tink the previous thread has more than explained enough. For reference, pls refer to the last thread.
This time round, Mr ISAMI AMEMIYA, himself, is coming down to Singapore on 1st to 2nd December to meet up with all the rotary engine members.
Since 1st is a Friday, i hope to arrrange a meetup with all the rotary fans, rx7 FD n FC included, together with Mr Amemiya. Pls make urself available to meet up with the renowned "rotary god" from Japan. Magazine shoots will be arranged as well.
*For pricing details, pls refer to Monster Garage for more info.
coupe07
10-23-2006, 12:02 AM
we have 4 major projects going on during their trip here.... the amount re-mapping of ecus may be cut down to facilitate the project.
Mr Amemiya is coming down on the 2nd and 3rd, instead of 1st n 2nd. Hope to have all ur support!
lowrider
10-24-2006, 11:04 PM
Mr Amemiya is coming down on the 2nd and 3rd, instead of 1st n 2nd. Hope to have all ur support!Can I assume that its first booking/come first serve? Example: I send a request back in Sept, I assume that i am higher up the list than someone who requested in Oct?
coupe07
10-25-2006, 02:17 AM
to be fair to others who are earlier than u, the answer is yes.
To be frank, response is over whelming and as mentioned in my previous post, there are 4 major projects to be completed before we will even touch the remapping part.
Dun worry, theres still knight sports to come and do the remap. u miss this chance, theres another chance.
madmax_rx8
10-25-2006, 05:58 AM
i don't know but i think it's typical chinese thinking or perhaps just me....
RE remap is tested and done in many of for our local bros... so in a way i'm more comfortable with it
KS so far as what i knw only 1 car in singapore have done his remap by them. so i think if you ask me..... my only recommendation is
PLS PLS PLS ask RE to come again soon after this trip cause i was called for overseas exercise this time round and can't get it done.... hahaa
coupe07
10-25-2006, 06:50 AM
wats wrong with KS remap???
the remap is pretty standard for NA setup. Like i always said, theres always so much u can do for NA setup...... of cos if u wan to wait for RE, no problem. But they will only come when there is "big project", if not no point bring them here juz to do remapping.
Initially a lot of pple (u noe who u r) oso doubts RE-Amemiya remap when they came over for the first time. Its only the first few people or heroes who did, and reviewed then it became good.
Frankly speaking, if u r running on NA setup which 95% of the rx8 in spore are, these remaps are similar.
Let me noe ur view.
clarencel
10-25-2006, 07:22 AM
Let me noe ur view.
What kind of "big project" are they down for? Enlighten us a little.
clarencel
10-25-2006, 07:57 AM
Was surfing around Racing Beat's website (www.racingbeat.com) and found a section on their version of PCM Flash. I have copied and paste the intial bits of their writeup for a quick readup. There's more in their website.
Quote:-
Flash Features
There are 3 specific areas where Racing Beat modifies the PCM data:
1. We optimize the fuel maps for best power. No changes were made (or needed) below 3500 RPM, and most changes were above 8000 RPM. This is where the stock mixture goes substantially rich, wasting fuel and power. Review Dyno Chart
2. We changed the rev limiter from 9000 RPM to 9300 RPM to take advantage of the increased power available at that RPM once the mixture is changed. Testing has shown that 9300 is an acceptable RPM for the engine. Mazda chose 9000 in part because power was dropping so fast at 9000 there was no point to revving further. Now, that is not true.
3. We lowered the ON temperatures for the electric cooling fans to improve engine cooling and avoid water temperature spikes. #1 fan now turns on at 87 degrees C (stock - 97 C) and #2 fan turns on at 90 degrees C (stock - 101 C).
-Unquote.
any feed backs on that?
sqflyer
10-25-2006, 08:51 AM
From some of the testing I've done with my stock ECU vs a piggybacked ECU 8 and looking at his dyno chart, it seems that most of his power gains over my stock ECU were actually in low rpm range up to 4K rpm. So personally, I find it somewhat strange that Racing Beat claims that no changes are needed below 3500 rpm. Comments?
CoupeM
10-25-2006, 08:55 AM
I have actually hook up a lambda sensor on my rx8 and did wot runs. It is true that we are running seriously rich in the upper rpms zone.
madmax_rx8
10-25-2006, 10:08 AM
Let me noe ur view.
Bro don't get me wrong i never say KS remap no good...
I just meant that i'm a typical chinese... so many bros try RE remap already and sucessful and feed back good so i more comfortable lor.. :rollingla
regards
Kelvin Koh
coupe07
10-25-2006, 12:53 PM
regards
Kelvin Koh
hahahaha pang sim lah, bro....
its abt the same..... there are also many pple waiting for Knights sports to turn up.....
clarencel
10-26-2006, 01:31 AM
so, are the reflash figures by RE and KS the same as RacingBeat? if not what are their targeted firgures?
coupe07
10-26-2006, 02:28 AM
wat sort of figures are u looking at??? like i said for NA setup, most reflashes are similar. Even racing beat, although i dun agree on the part on low rpms becos butt feel, low rpms does feel faster n smoother.
i also do not agree on the point where they said "Mazda chose 9000 in part because power was dropping so fast at 9000 there was no point to revving further. Now, that is not true"....
its actually true, if u refer to all of the japan tuners dyno-ed charts. At very high rpm, HP began to drop. If only one tuner showed that, yes maybe wrong. ALmost all tuners' dynoed charts showed the same thing... now.. all of them wrong?? cannot be...
as for cooling temperatures... lets not tok abt wat temp the fans kicked in.... REAL experience, my watertemp is nvr more than 90 during day time driving... sometimes spirited.
Most of ur queries are answered in previous thread. As for wat sort of figures, u have to let us noe wat u r looking at.
clarencel
10-26-2006, 04:12 AM
My apologies for being vague.
I'm not looking for a particular figure or figures. It's just that after reading the RacingBeat article, I was just wondering what figures are RE and KS working on.
I can appreciate that u're getting good temps below 90 for cooling temps. And I do agree it's a good temp.
I queried for figures mainly to gain some knowledge and have some numbers to compare between tuners. And I'm thinking it's a nice-to-know facts if one were to think about investing in reflashing their ECUs
Thanks for the feedback.
raven12
10-27-2006, 02:05 AM
Bro,
I am in for the re-map....need to upgrade my software.....its like running on window 95 now lor
virus
lowrider
10-27-2006, 04:09 AM
Virus... what is Window 95? When I boot-up, my computer says its Window 3.2.
Is yours the latest version of Windows? I want it.
raven12
10-27-2006, 05:54 AM
secret ....dun tell u....
virus
Boykichap
10-28-2006, 04:47 AM
Window 3.2 is still ok.... mine still running on DOS system....
blackjack
10-28-2006, 10:57 AM
i totally have no windows
Rotor Kreuzer
10-30-2006, 08:41 AM
Ivan
Have sent a couple of e-mails to monsterg with regards to shipping you my ECU for the re-map the past week. Appreciate any feedback as soon as youre able. Thanks.
Ray
Rotary_Addict
11-15-2006, 07:27 AM
Coupe07
You gotta let us know if we can send our ECU to you?
Is there any more slots etc etc....if theres no more slot then we wont have to wonder....appreciate if you can update us here
Cheers
coupe07
11-15-2006, 08:26 AM
Coupe07
Cheers
how many ECUs do you intend to send over?
Of course on our end, we will try to fulfill everyone's wish to remap. However like i mentioned, there is an overwhelming response. There a few from malaysia. One from brunei is on the way. And the number of singaporeans wanting to this. besides all these, there are the bigger projects.
Let me know ur figures and i will revert according.
Zero_Rotary
11-16-2006, 10:36 AM
Bro Coupe07..
I might be coming down to Singapore that weekend bringing an ECU, count me in!
kennyyeo
11-22-2006, 08:19 PM
Guys,,need yours help......
Do you guys know any good and cheap hotel near monster garage which has a good and secure car park ?
Need to stay one nite in Sg for the RE remap thingy...
oh i am from KL
thanks
INXS
11-22-2006, 09:16 PM
Wahahahhahaaha
CoupeM
11-22-2006, 09:22 PM
Stay at INXS hotel...see he laugh so hard..must be alot of ppl stay there
Mugo
11-23-2006, 12:36 AM
Original injectors maxed out.
It is limited only by eccentric shaft warping / resonating at v. high frequencies... :eek:
kennyyeo
11-23-2006, 12:37 AM
huh INXs has a hotel there?
INXS
11-23-2006, 01:59 AM
Wahahahahahahhaaaah!!
whiteX
11-23-2006, 04:15 AM
yeah. heard of hotel 81? inxs is e boss
lennon
11-23-2006, 04:29 AM
Hmmm ....... Room rate?? View?? Safety?? Service??
Zero_Rotary
11-23-2006, 05:27 AM
Coupe07...
I will be in Singapore on the 3rd afternoon...would that be still in time to hand in an ECU?
xacidx
11-23-2006, 08:26 AM
eh bro...in sg very safe 1 la...no worries. cna get cheap hotel from 50-60bucks i think
coupe07
11-23-2006, 10:44 AM
Coupe07...
too late, they all packing bag to go home oredi
Zero_Rotary
11-23-2006, 12:29 PM
Coupe07...
When would be the latest acceptable time and date?
lennon
11-23-2006, 08:09 PM
I know it's safe, but still have to know abit mah... :)
coupe07
11-23-2006, 11:14 PM
Coupe07...
1st is last date, however we are not accepting anymore... Wait for the next round when knight sports comes around. WIll keep all informed.
Boykichap
11-24-2006, 07:08 AM
Hotel 81 suck man......
INXS
11-24-2006, 01:12 PM
You must have opted for the storeroom ... 1 cent money, 1 cent goods.
woodtcb
11-28-2006, 10:05 PM
may i have the MG address please......
coupe07
11-29-2006, 01:00 PM
blk 3014 ubi rd 1 #01-310
mandotcom
11-29-2006, 08:41 PM
hi,
very happy after remap.
the drive is real smoooooooth now.
MDC
coupe07
11-30-2006, 04:45 AM
Good news.
There is still room for remap. Those who are interested, pls make an appointment and dropby.
morganoh
11-30-2006, 04:57 AM
Good news.
May I ask a questions, If I send for remaping at your place and I send in for servicing at Mazda Motor and if they happen to have an update maps and they do it automatically for me without asking the owner 1st,
Would this happen?
coupe07
11-30-2006, 05:08 AM
Would this happen?
yes it will happen. either u dun go back, or u specifically tell them dun update.
Zero_Rotary
11-30-2006, 06:57 AM
Coupe07...
Ru only accepting re-map for tomorrow only?
CoupeM
11-30-2006, 10:23 AM
i thot no more slot already
coupe07
11-30-2006, 10:33 AM
not too many. Only on appointment basis. Walk-in will be rejected, so pls make an appointment.
