Engine Noise with P.I.E. MAZ/PC-ALP Aux Input Converter
Old Oct 15, 2006 | 08:00 PM
Lucky14u's Avatar
Lucky1
Has anyone used the PIE converter, did you get engine noise and if so how did you get rid of it.
Thanks in advance.
Lucky1
Old Oct 15, 2006 | 10:44 PM
Tamas's Avatar
Registered Lunatic
Ground loop isolator - or try to re-route your wires.
Old Oct 16, 2006 | 12:43 AM
PeteC's Avatar
I tried a GLI and it really didn't help. Make sure all the connections are tight. Personally I'm going to try and run a seperate ground to the Sirius unit I'm using the PIE for.
Old Oct 16, 2006 | 10:58 AM
hitman408's Avatar
Ground loop isolator worked for about month then engine noise came back. All the wires connections are tight so I don't understand why noise came back.
Old Oct 16, 2006 | 11:19 AM
calaloco's Avatar
Mine is working fine with XM Radio and Sansa MP3, I'm using the PIE MAZ/PC-ALP with the cable ALP/M-3.5M and the power of my XM radio is connected in the front 12v plug, I heard there is a problem withe the back 12v plug.
vapor2
Nov 3, 2020 03:38 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
cschoeps
Aug 6, 2015 12:44 PM
ion_four
Jul 30, 2015 09:48 PM
Belalnabi
Jul 17, 2015 07:48 PM
