View Full Version : throttle body bypass mod
Fluid4
10-10-2006, 12:27 PM
any idea wat mod is tis?
dmp
10-10-2006, 12:29 PM
One removes, and plugs, the engine-coolant from entering the Throttle Body...supposed to help keep the incoming air cooler.
Fluid4
10-10-2006, 02:00 PM
eerrrr.....meaning?
the line from the engine to the air intake?block it?
Russell
10-10-2006, 02:04 PM
search.
lennon
10-10-2006, 03:14 PM
Another word is put on an oil catch tank or tiny K&N filter.....
StealthTL
10-10-2006, 03:24 PM
For all our search-impaired readers -
There is a coolant line that runs from the block to the drive-by-wire throttle body, and back. It is possible to get some ice buildup at the plate in certain conditions.
The bypass mod blocks off the flow of hot liquid, in hopes of keeping the intake charge a little cooler.
S
Emperor
10-11-2006, 12:24 AM
Good mod! Useful when the next ice age hits the FAR EAST.
Seriously this is a good diy for us in hot humid SG.
Fluid4
10-11-2006, 05:52 AM
oic.....like that i noe liao....
heheheee
but i see that there 3 inlet at the intake piping....which is the one?
lennon
10-11-2006, 06:03 AM
heheheee
The one connected to Engine oil chamber...
Goober8
10-11-2006, 11:25 AM
Fluid 4,
Are you referring to the mod which bypasses the coolant from the throttle body? You can refer to this link. It's in the DIY section. I've also done it on mine. Don't really feel much difference.
http://www.rx8club.com/showthread.php?t=36389
Fluid4
10-12-2006, 01:35 AM
okie...thankz...
Fluid4
10-12-2006, 01:39 AM
Fluid 4,
Thankz for the great info dude!
FastRX8
10-26-2006, 04:40 PM
Another word is put on an oil catch tank or tiny K&N filter.....Actually, the oil catch can is totally different.
There is also a DIY for the oil catch can here http://www.rx8club.com/showthread.php?t=100635
That goes between the line from the engine oil fill tube and the intake.
The throttle body bypass mod, eliminates the coolant that runs through the throttle body.
http://www.rx8club.com/showthread.php?t=36389.html
