View Full Version : RPM related changes and HP implications
Edge
08-31-2003, 11:58 PM
If you've dug into your books, you can see a lot of stuff happens at various RPM ranges. Figured I'd collect it in one place:
RPM SYSTEM WHAT
3750 Fuel Injectors #2 primary and secondary injector start
controlled by ECU fuel maps
(All in use during WOT!?!)
3750 SDAIS #2 primary intake ports open
5500 SDAIS VFAD may open (Yamaguchi p 115)
6250 SDAIS Auxilary intake ports open
7250 SDAIS Primary intake ports interconnnect
adds a second shorter path
7250 SDAIS VFAD opens on WOT
NOTE: all of the SDAIS changes presume WOT, don't know what happens if it's not WOT. I'd guess the ECU makes the decision.
Please add things I've missed
Now, what does the above imply, how does it compare to driving experience, and how does it relate to observed hp and torque curves. I'm not highly educated on this stuff, so please step in and correct my errors or stupidity.
If you're not WOT, some or all of the above may not happen. I'm not used to just hammering the pedal to the floor, I'm used to putting it down to the point I interpret as max accel for a given RPM. Since this is fly by wire, not putting the pedal to the floor does not tell the computer exactly what I want: max speed now! Kind of like the change from standard brakes to ABS.
I was experiencing stutter/power loss above 6K. My car is now over 3K miles and combined with a new attitude on the throttle, that hesitation is gone. Accel levels off a little around 7K, then picks up again past 7.5K. (all on butt dyno here)
What about the dynos? My observed (butt dyno again) driving experience has some implications for this. Assuming the current dynos are fairly quick pulls, I can see where there will be a fall off above 7K. At about 7250 the VFAD opens (might happen earlier too, but it for sure happens here) and an interconnect between the primaries also opens. I think I observe this as a leveling off around 7000-7500 RPM. After 7500 RPM (or a couple second count), the car seems to get a second wind and pull harder. My guess is it takes a little while for the changes to settle down and actually have good impact. So what?
If a dyno run doesn't allow the engine to settle in above 7500, it may never get the real power from the VFAD and extra cross-connect because it's over too fast. Things happen incredibly fast between 6250 and 9000 in second and third. It'd be interesting to compare runs from third through sixth to see if longer time at high RPMs results in a better curve.
Mark
09-01-2003, 05:09 PM
This is starting to make some sense. I love my 8 and will make a decision after break in (200 more miles). I plan to keep it assuming all is well with above 6k acceleration. Your observations are very helpful. It seems the loud pedal needs to pe pushed and not pussyfooted. This can't help mpg however. Frankly, it probably won't hurt much either. I got 16 my first tank we'll see on the next. I am going to the USGP at Indy and will drive the 8 which will be the real test to determine if I keep it.
Velovity Red, r/b,6spd, GT, 6disc
Digisan
09-01-2003, 06:34 PM
I hope you don't try to race JPM in a 1 series, I don't think the 8 could keep up!
I had plans to go to the USGP, but due to work I can't make it this year :( .
