Proper tire pressure for 17'' tire?
Old Oct 9, 2006 | 09:20 AM
Rotor8's Avatar
The recommended tire pressure for stock 18'' tires is 32psi, but does it applies to 17'' tires as well? I just bought 17'' tires for winter driving. The tire dealer said that for smaller tires, it's better to increase the tire pressure by at least 2psi per inch. So I should have 34 psi of pressure in each tire. When I check the tire pressures the next morning, it was 41psi on each tire!
Old Oct 9, 2006 | 10:08 PM
NotAPreppie's Avatar
What am I doing here?
Since there would be more surface area for the air to push out on (given the same tread width) on a 17" versus an 18", a 17" tire would need less air pressure.
I'd think, depending on conditions, anywhere between 32 and 40 psi would be safe.
RevMeHarder
Jun 1, 2026 02:30 PM
hppy4u
Gulf For Sale/Wanted
9
Dec 3, 2015 09:11 PM
CMRine04
Sep 17, 2015 10:04 AM
teamdipngo
Sep 14, 2015 02:47 PM
