View Full Version : Cast or Forged Rims?
seraph 10-08-2006, 11:58 AM Hello all
In a little dilemma.. Should I get forged rims or cast ones GIVEN a S$1500 difference in price? Both rims are 18" and would be fitted on a 6AT.
The forged rims in question are about 8kg a piece and the cast ones weighing in at about 10kg a piece.
Can the extra $1500 be spent on mods which would make up for the extra weight? Thanks for all the help.
dollygrrrl 10-08-2006, 12:21 PM U still thinking about it dude??!!
I thought u've already decided..
morganoh 10-08-2006, 12:23 PM Cast Rims has a longer life span.
Example
1) When you drove over a hole accidentally? the car will sink in for a moment and will be out of the hole immediately. But this in and our vertical movement may or will cost the Rims to be out of shape. cos the forge wheels are quite SOFT.
2) everytime u change tire, dent markes will appear to be more promp then Cast rims cos Cos is softer.
Go for forged...its alot better than cast rims...unless ur cast rims r from advan...
coz apparently, the casting technology of advan is comparable to forged...
at least thats wat i was told?
Anyway, i'm using advan rims...think its quite light...ard 7-8kg if i'm not wrong?
At least lighter than the stock rims lah...heehee... :mdrmed:
coupe07 10-08-2006, 02:27 PM Cast Rims has a longer life span.
Example
forged rims are supposed to be much stronger (and of cos, lighter) than cast rims.
morganoh 10-08-2006, 06:31 PM forged rims are supposed to be much stronger (and of cos, lighter) than cast rims.
Forged Stronger.. YES, less likely to crack but will deformed more easily compare to Cast.
Forged Process - The material are heated and are hammer to its shape. during this process the molecules are hammer closer together to make the bonding between the molecules stronger. as a result the rims are not easily crack.
(just like the same process those ancient chinese used to made swords)
But they are usually make of softer material so that the rims are lighter.
So Forged Rims may not get cracks as easily like Cast rims, but there are more likely to be deformed due to it lighter and softer material used.
But u cant compare a $2000 Forged rims to a $100 cast rims.
got to compare those expensive cast rims with those forged rims around the same price, cos there are cast rims make from very good material as well.
seraph 10-09-2006, 04:28 AM Ok.. maybe its easier to tell you what the rims in question are; Forged - TE37 and Cast - Work Emotion CR Kai.
For $1500, i could probably get an after market exhaust for a couple of hundreds more, but would the gains from such a mod make up for the extra weights from the cast CR Kai?
I'm sorry if this is a stupid question, but haven't been able to find anything on this topic.
morganoh 10-09-2006, 06:48 AM Ok.. maybe its easier to tell you what the rims in question are; Forged - TE37 and Cast - Work Emotion CR Kai.
It would take a "Very Sensitive Guy or Girl" to be able to tell the diff between both rims.
We are talking about around 1.5kg differences between one rim right? so ask your self can u tell the diff when your rims are 1.5x4=6kg more? if not , dont waste the money on the forged rim.
Unless u really love the design and looks of the forged rim so much that u have to buy them, then thats another case. (its not about the looks but not the money)
Hi
Urs is an AT car. I may be slammed here but we know AT car has less power than manual. If u have the $$$, u shld get as light a rim as possible. This is concerning unsprung weight. Other bro can help here.
I did not specify cast or forged cos some cast rims can be very light as well (Advan comes to mind). Forged rims does indeed exhibit more flex but it depends on where u drive and how u drive.
Since rims is a personal thing, u may like the look of cast rims and prepare to sacrifice on performance. Then go for the cast one. Only u know.
Cheers
Emperor 10-09-2006, 09:52 AM I got forged 17". Its way lighter than the stock 16". Definately better in accel, stop and handling.
1.5kg is not alot. But when you consider the reduced rotating mass. 1.5kg is actually alot. Plus its unsprung.
Casts ones are heavier because of the minute imperfections so rims makers have to use more metal. Personally, i know at least 2 people who had sheared cast rims. One is on a kia rio ferrying 4 people going over a hump. So is it a wise investment on the rx8 especially people who track? I rather err on the side of caution and spend that little more.
sqflyer 10-09-2006, 02:58 PM so ask your self can u tell the diff when your rims are 1.5x4=6kg more?6kgs may not sound like much, but like Emperor pointed out, the majority of the 6kgs are rotational mass as well as unsprung weight. There was some study done (but I have no reference to it) that unsprung weight is equivalent to 4x normal weight. So lugging 6kgs of unsprung weight has the equivalent effect of lugging 24kgs of the car's bodyweight around. I can't verify it so please take it with a pinch of salt.
I also hear something like that but cannot remember where.... total abt 4 time savings.
Dont quote me oso, I fail my science hehehe
sandman369 10-09-2006, 09:34 PM I also hear something like that but cannot remember where.... total abt 4 time savings.
it's called rotational inertia. a function of k * Mass * Radius^2. it's generally true if wheel radius is the same with reduction in weight.
however, do note that an increase in radius plus a reduction of mass does not always mean improvement, given the Radius^2 factor.
seraph 10-10-2006, 09:04 AM Thanks for all the responses people. I've decided to get the TE37s.
So my next question is which tyre profile, rim width and offset to take.
For the rims, I'm undecided on 18 x 7.5 or 18 x 8.5 and the offset +30 or +40. Stock should be +50 if i'm not wrong, but I would prefer my wheels to be slightly protruding out. Would +30 be too much and rub the fender? I don't intend to change suspension or get lowering springs for the moment.
For the tyres, whats a good profile? 235/40/18? Stock is 225 right? I remember reading somewhere that for street use, getting a rim width which is 90% of the thread width is optimum.
Would appreciate any type of advice or opinion on the above matter. Thanks! By the way, specs for the TE37 can be found at: http://www.rayswheels.co.jp/cgi-bin/cgi2/english/sizeGuide.cgi?modelName=TE37
Hi
Next to the specs of rim, VR also recommends wat the configuration for diff cars.
For 18", u can see below for RX8. U can also check other sizes (17" or 19"). They recommend staggered for RX8.
http://www.rayswheels.co.jp/cgi-bin/cgi2/matching.cgi?modelName=TE37&inchIndex=5
If I were you, I'll consider 17" as it is an auto car.
Cheers
Low rider 10-11-2006, 12:58 AM ... and bigger rims (on auto) does not mean that it will make the car slower. Thought we had proven that already.
coupe07 10-11-2006, 01:05 AM ... and bigger rims (on auto) does not mean that it will make the car slower. Thought we had proven that already.
sart lor...... 19" rims but outrun others on smaller rims lor.....
seraph 10-11-2006, 05:55 AM Ok.. but i'm not intending to use staggered..
would an offset of +30 be too wide for the car and rub fender? Anybody has +30 offset?
What do you guys think of this setup?
18x8.5, offset +30 and 235/40/18 all round?
coupe07 10-11-2006, 06:34 AM Ok.. but i'm not intending to use staggered..
8.5 +30 may rub... if 8.0 +30 shld be no issue. Check with ur rims/tyre supplier
sandman369 10-11-2006, 07:31 AM Ok.. but i'm not intending to use staggered..
not sure if it fits but you may want to know that your setup equates to 26mm additional outward protrusion compared with stock 18". sounds agressive and may affect handling. on rubbing of fender, etc, i supposed it's ok for the back but not sure if it's ok for the front wheels.
why not stick to volks' recommendation? 8.5 w 40 offset for the front (16mm additional protrusion compared with stock 18")?
Sorry u mean same driver, same car, same type of rims, same type of tyre, just diff rim and tyre size and bigger rims will not lose out??
Weight doesnt count??
nex100 10-11-2006, 11:01 AM the question shld not be the size of the rim but the amount of contact your tyre have with the road surface. tyre with larger width (usually comes with bigger rims) need more frictional force to run the same distance hence acceleration and fc performance will be less than the same car running smaller rims.
Emperor 10-12-2006, 01:30 AM Did anyone notice why race cars usually run 17" and some 18" but never 19"?
Weight does matter. If 10 nm of force moves 2 kg 10 metres. This same amount of force may only move 4kg 5 metres. If speed is constant. So logic says if the torque stays the same then if weight is increase, it should take longer to accel, deccel over the same distance.
And then theres the overall size of the wheel. Big wheels turn slower than small wheels; equates to less torque transmitted. Maybe thats why lorries have small rear wheels.
Low rider 10-12-2006, 01:59 AM Sorry u mean same driver, same car, same type of rims, same type of tyre, just diff rim and tyre size and bigger rims will not lose out??
We had tried the following :
1) Same Car (same set-up)
2) Once on 19" (F 245 / R 275) and another on 16" (stock) on a different day
3) Same driver
Conclusion is the tyres play a big part in the test where 19" using conti sc2 for front and michelin ps2 for the rear, 16" on totally "wan chng" RE040.
:kiss:
Low rider 10-12-2006, 02:09 AM Did anyone notice why race cars usually run 17" and some 18" but never 19"?
Sorry, I don't know if race cars uses 17" but i know u are .. :Peace:
....not mathematically inclined enough to reply your weight x force + accel - torque question. :Freak_ani sorry .........
:nono: why are we on lorries wheels ?
End of the day, wheels are quite personal and voice down to the purpose of performance or show car look only. Yes, i do love to have the 22" bling bling wheels :kiss:
Low rider 10-12-2006, 02:30 AM the question shld not be the size of the rim but the amount of contact your tyre have with the road surface. tyre with larger width (usually comes with bigger rims) need more frictional force to run the same distance hence acceleration and fc performance will be less than the same car running smaller rims.
Agree that tyres make lots of difference on the car. Regardless cast or forged, go for rims that fit yourself and make sure it doesn't rub your fenders..
FC wise is highly dependable on your driving style. :dunno:
Enjoy your rims hunting experience.
coupe07 10-12-2006, 02:59 AM Sorry, I don't know if race cars uses 17" but i know u are .. :Peace:
u mean emperor car = race car??? can run fast fast, since he using 17"
sqflyer 10-12-2006, 03:14 AM Alamak, liddat must post my new 18" rims in lelong thread and look for some 14" rims liao... sure win races coz the competition all die laughing. :rofl:
Emperor 10-12-2006, 05:20 AM Wah. Aim me. I only say race cars usually do not use oversized rims.
Ditch the 18s. get chrome 22s. Sure win race too, bling the competition to death. Cant outrun them. Bling them.
sandman369 10-12-2006, 07:23 AM big wheel, small wheel, big rim small rim. it's the balance one needs to strike.
generally, for the same one round made, bigger wheel give you more distance (ie more speed). however it MAY take more effort to turn that one round since material used MAY be heavier to construct that wheel.
going into details and following specs from initial discussion, ie assuming wheel radius (rim radius plus tire height) and tire width are constant, one cannot be sure bigger lighter rims will be better than the smaller heavier rim. since the effort (force) to turn the weight one round depends on rotational inertia (weight * radius^2, where radius is meadsure from centre of wheel to centre of gravity of weight of materials). ie, the more weight is distributed to the edge, more effort is required to turn the wheel. the force required to turn the wheel is heavily punished by the distance away from centre, given the power of 2 effect, compared to a reduction of weight (which may be insignificant due to redistribution of weight to outer edge).
for race cars, why they dont use oversize rims, i beleive it's abt striking a right balance. based on the above discussion, it would appear than small rim is better. but higher tire wall means poorer handling (and energy transfer) since rubber flexes more than metal. so a compromise is made (between rotational inertia and handling), smaller (or not oversized) rims compensated by stiffer rubber tire walls.
sqflyer 10-12-2006, 07:45 AM Nicely put, sandman... Indeed, it's a matter of balance and what you are modding your car to achieve.
3) Same driver
:kiss:
OK noted. We all know tyres make the most diff. Just look at F1 race....
sandman369 10-12-2006, 10:08 AM Nicely put, sandman... Indeed, it's a matter of balance and what you are modding your car to achieve.
and for most of us, as long as:
- reputed rims;
- lighter than stock
- and most importantly, BIG rims LOW profile tyres. :ylsuper:
Hehe for me
1. Reputed rim (a bit of reputation lah...)
2. Lighter than stock.. (unlikely although i didnt weigh but 255 rear tyres doesnt make light combo...)
3. Looks good .... (to me)
Cheers
sandman369 10-12-2006, 11:33 AM ya looking good is VERY important, forgot abt this.
coupe07 10-12-2006, 02:12 PM ya looking good is VERY important, forgot abt this.
sporeans are like that:
1. ai hiao
2. ai gui
3. ai hao lian
4. ai pi lang swee
5. ai branded
hehehehehe....
sandman369 10-12-2006, 09:03 PM sporeans are like that:
1. ai hiao
2. ai gui
3. ai hao lian
4. ai pi lang swee
5. ai branded
hehehehehe....
that would make singaporeans a loving ("ai") bunch of people...:)
Emperor 10-12-2006, 11:49 PM Sandman & coupe: Well said.
