View Full Version : Shifting into reverse
billnvicki
10-04-2006, 07:06 PM
Is it just me but just bought a rx-8 and why is it so hard to get it into reverse..is that normal just to move it across? Had a celica before and it was never that hard to put it into reverse. Just wondering if there made that way for a safety issue. thanks
jskup1
10-04-2006, 07:11 PM
I'm assuming you have a 6speed manual. To put it in reverse, you need to push straight down on the shifter(not back), then all the way to the right, and then down.
billnvicki
10-04-2006, 07:13 PM
yeah I go all the way to the right but its hard to get it to reverse it wont go all the way and keeps ending up in 6th. I have to push it really hard over and then down into reverse. I never had a car that was that hard to get it into reverse like that>>> any suggestions???
SayNoToPistons
10-04-2006, 07:14 PM
SLow down.. first then reverse.
1stgen8
10-04-2006, 07:15 PM
I push down first then over
billnvicki
10-04-2006, 07:17 PM
But im talking about when its in park just to back up its really hard to get it into reverse I have to push it really hard over just thought it was weird...actually wife drove it today and couldnt get it into reverse at all!!! Should i get that checked out or is it me??lol
CarAndDriver
10-04-2006, 07:38 PM
You--your posts don't make any sense.
Im_DANomite
10-04-2006, 07:40 PM
push DOWN on the shifter. as in, push it down towards the ground...then move it all the way to the right and back towards the rear of the car. read the manual...
how do you buy a car without knowing how to drive it?
billnvicki
10-04-2006, 07:42 PM
I have a 6speed manual its in park im trying to reverse, I turn on the car i shift down from first all the way over to the right and then down but i end up in 6th gear...I actually have to push really hard REALLY HARD OVER to the right then down to reverse...I was just asking if thats normal that I have to push it that hard over to get it into reverse.....
lurch519
10-04-2006, 07:43 PM
push straight down, as in put your hand on top of the shifter then push like you are trying to push it down through the floor, not towards the back of the vehicle, then all the way to the right, then towards the back of the car. sometimes it is a little hard to put it into reverse if the synchros arent lined up quite right, if that is the case, try putting it into first gear, then reverse.
abbid
10-04-2006, 07:44 PM
Users manual > you
silverwolf
10-04-2006, 07:46 PM
ok listen, you push the shifter down to the ground it will sink in and then you move it over to the right and shift down. not over to the right and then down.
you are to push it to the ground then slant it to the right and then pull it down parrallel to the ground towards the rear of the 8
CarAndDriver
HELLO? Read the posts and then answer.
Detrich
10-04-2006, 07:47 PM
0. put the gear box in NEUTRAL.
1. right foot down on the brake, left foot down on the clutch.
2. key in ignition, start up the car.
3. PUSH DOWN on the shifter knob so that it's depressed. (you'll be able to feel it.).
4. gently pull the knob all the way to all the way to the right, then pull it back.
5. release the brake (right foot), and gently let up on the clutch (left foot).
if after doing all this u still don't get it, then drive (or push) the car back to the dealer and have them teach u in person how to do it.
CarAndDriver
If you don't understand this and can't answer if you are doing this, then please do us all a favor and drive an automatic Toyota Camry.
mysql101
10-04-2006, 07:48 PM
rule #1 of owning an RX-8: if you have no clue how to shift into reverse, and nothing seems to work, push A LOT HARDER and then it will work. And if that doesn't work, use a rubber mallet (because a hammer would scratch).
Im_DANomite
10-04-2006, 07:49 PM
wow...
h-khunterkiller
10-04-2006, 08:11 PM
joystick dirrections ( right, left, back, foward, you don' need up cause it will rip the joy stick out, and finally down....
so first goes down maintaine pressure as you go right then back the more you practice the better you ll get at it. look just keep trying it will be come easyer with time, hope that helps
yiksing
10-04-2006, 09:15 PM
Normally it takes 2 clicks on the gear knob to engage the reverse gear
1.3L
10-04-2006, 09:28 PM
Is it just me but just bought a rx-8 and why is it so hard to get it into reverse..is that normal just to move it across? Had a celica before and it was never that hard to put it into reverse. Just wondering if there made that way for a safety issue. thanks"R" is for Race, not Reverse. The RX-8 does not have a reverse gear.
1.3L
'87 Turbo II
10-04-2006, 09:48 PM
Look what more do you want us to tell you? "No it's not normal."? Go to a dealer and MAYBE you'll have a faulty gearbox or maybe,, just maybe, they will teach you.
ChinkBoy2Fine
10-04-2006, 09:49 PM
yea thats what I do too...Push it down and then all the way to the right
beachdog
10-04-2006, 10:10 PM
1. there are no adjustments on the shifter. the dealer can only hope to correct operator error
2. those of us who have had the shifter out know that you only have to press downward before moving the lever to the right. once the lever is down and to the right, the tang on the shaft is under the lockout plate and you don't have to apply downward pressure anymore, just pull rearward.
NgoRX8
10-04-2006, 10:11 PM
^ what he said.
Xantium
10-04-2006, 10:14 PM
Sometimes it doesn't go all the way into reverse and when i let the clutch out it just grinds, I've found that if i keep pulling back while letting the clutch out it will pop into gear.
Does that sound like a bent shift fork? I've been wondering about that becuase I have to be pretty concentrated on my 1-2 shifts to avoid grinds... i have an 06 so that 04' tsb means nothing to me :(
dtorre
10-04-2006, 10:32 PM
Ok you guys don't have to be asses...the thing is hard to get into reverse sometimes no matter how hard I push now the damn thing won't go into reverse without my "trick" otherwise I get the grinding noise that lets you know its not engaged....
If you try to put the car in reverse and it doesn't feel like its completely set....then hold the clutch in and keep pressing the shifter down and back...slowly let the clutch out while still pressing the knob down and back and it will pop right into place...no more grinds annd easy as pie...
JCTarheel82
10-05-2006, 03:19 AM
haha this thread cracks me up
RX8babe
10-05-2006, 03:27 AM
+1
zoned
10-05-2006, 09:19 AM
so, you push downward on the shifter?
MadDashRX8
10-05-2006, 11:47 AM
I have a 6speed manual its in park im trying to reverse...
I'm still trying to figure out how to get my 6speed manual INTO park. Maybe you can help me out with that one. :rock:
Seriously, though, sometimes I have to release and depress the clutch again before the stick'll go into reverse. I'm sure you've tried that, and every other "suggestion" in this thread already. Good luck with getting this bug worked out.
MD
TomAssBender
10-05-2006, 01:08 PM
MD
actually, it sounds like he is missing the suggestions on this thread. i never thought it would be so funny to read 7 posts of the same exact thing.
I think he is misunderstanding "pushing down" on the shifter?
i was going to write more but realize the innate idiocy in another attempt at instruction
Smokin_LaLa
10-05-2006, 01:33 PM
ya push down on the shifter like as if it is a button then shift to reverse, trust me i had problems with this when i first drove my car once u get used to it it should be ok, iam also assuming that he figured out this as he is not responding back anymore
deamicls
10-05-2006, 02:46 PM
I think that he's laughing his ass off at all the people trying to explain such a simple task on an online forum.
I'll admit that I had trouble getting it in reverse the first time. After figuring out that I had actually put it in 6th i realized that you had to do something else to get into reverse.
Rems31
10-05-2006, 02:52 PM
I'd like to hear back to see if this was the problem or if was actually something mechanically wrong with the 8. Cuz first time I tried to reverse I went forward. I got out the manual and looked up "reverse" and read how to do it.
mid-life crisis
10-05-2006, 03:11 PM
HELP I can't find park on my 6 speed either - LOL
deee
10-05-2006, 03:22 PM
jeebus guys you got it all wrong. Its up up down down left right left right b a start. It's that easy.
Rx8member
10-05-2006, 03:53 PM
That is from the Turtles Original Gameboy game. I know that one. Forgot the title though.
deamicls
10-05-2006, 03:56 PM
actually its most known for being used in Contra.
edit: I forgot that this code is used in most konami games during that time period.
moRotorMotor
10-05-2006, 04:02 PM
He doesn't state if his is new or used. If it is used, it might have the AFE short shifter. That shifter is slightly harder to get into reverse than the stock shifter. In some rare cases, the end user had to slightly file the lockout tab on the shifter to get it to clear the metal tab. It's funny how something so simple is driving so many members on this board to lose their mind. For all I know, it sounds so trivial, I am starting to think he is a troll. His responses don't even reflect that he have read any of the responses. He still doesn't say that he have pressed the shifter vertically downwards and then to the right and into reverse.
Romeo
10-05-2006, 05:56 PM
Q: How to I get my car to start, I put the key in and turn but it doesent seem to start... I turn turn and turn with full force... My wife was trying to get it to start and she almost broke the key, could it be that I have a bad starter?
A: You have to push the clutch when starting the car...
n00bs 101.
-RoMeO
Romeo
10-05-2006, 05:57 PM
Theres nothing hard about the rx-8 at all, its all about "Knowing" what the F___ your doing.
Dont mean to sound like a dick, but the manual has all your answers... and if not... go ahead and take it to a dealer and have them walk you through it.
-RoMeO
mac11
10-05-2006, 06:07 PM
jeebus guys you got it all wrong. Its up up down down left right left right b a select start. It's that easy.
fixed.
Crazy Rx-8 Driver
10-05-2006, 06:53 PM
Go down on the Z-Axis.. then move over to the right ont he X-Axis.. then proceed down on the Y-Axis...
did that make sense? lol
I think he has a faulty Ring in the Reverse gate. Mine kept popping out of gear so i brought it in and got a refurb tranny under warranty.
CarAndDriver
10-06-2006, 01:33 AM
Hasn't even bothered to reply. :icon_tdow
zenmoused
10-06-2006, 01:55 AM
This is why only real men are allowed to order the AFE shifter. Unfortunately, it seems punyboy here has somehow received a MAN's car. :mdrmed:
silverwolf
10-06-2006, 07:49 AM
well if you have tried all that w have said... then i suggest taking a quick drive to the dealer. All these tricks and normal ways of shifting into reerse are all tried and true. Go get it checked out.
billnvicki
10-06-2006, 08:23 AM
Thanks guys for this....I got it I didnt know you supposed to push down towards the ground then over........SEE THAT WASNT TOO HARD..LMFAO...TAKE CARE...
rotary crazy
10-06-2006, 08:41 AM
AMAZING
get ready another TSB is coming out of this :yelrotflm
enjoy your car man, is a great ride
mac11
10-06-2006, 08:57 AM
you've never heard of reverse lockout?
CarAndDriver
10-06-2006, 10:35 AM
I guess opening the manual was too hard. Someone better avoid ever buying his RX-8. Glad that the "problem" was solved. :Eyecrazy:
beachdog
10-06-2006, 01:19 PM
Now that that's all settled, this is a shifter and gearbox that responds better to finesse than force. No need to slam throught the gears.
CarAndDriver
10-06-2006, 02:06 PM
Finesse second. Actually learning how the reverse mechanism works--priceless.
mac11
10-06-2006, 02:42 PM
reverse lockout owned this guy
Krankor
10-07-2006, 02:19 AM
Well, if reverse weren't so hard to find then nobody would ever discover just how easily the 8 pulls from a stop in 6th. (I sure wouldn't have!)
zenmoused
10-09-2006, 11:29 AM
Mazda actually refers to that as the "child safety lock" :mdrmed:
wisconsinben
10-10-2006, 08:22 AM
I can't believe this thread is 4 pages long and still alive! :lol:
