View Full Version : Trouble Shooting
Pages : [1] 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Grinding in 5th Gear?
  2. Surging Idle?
  3. Engine Flooding Info/Questions
  4. Rattle Behind the Dash
  5. Does your sunroof rattle?
  6. Technical Service Bulletins (TSBs) and Recalls for RX-8
  7. Discussion of Technical Service Bulletins (TSBs) for RX-8
  8. MPG Discussion / Complaints
  9. Strange "gunk" in Oil or on Dipstick - Info/Questions
  10. Engine Misfiring
  11. MT Clutch / Tranny Issues
  12. Emergency Brake and the COLD...
  13. This MPG issue is getting a wee bit silly!
  14. When your car makes a sulfer smell
  15. ECU/PCM "flash" Info/questions
  16. Say Goodbye To My Clutch
  17. post your Manufacture Date + related problems.
  18. Rough turn off
  19. Transmission NOISE + difficult 2nd GEAR
  20. J, K, L, and M Flash Explanations
  21. Cumulative Gas Mileage (Gas MPG) Thread
  22. Airbag Warning Light
  23. Free brake pads
  24. Brand New Clutch Explodes...
  25. Transmission Issues/Questions
  26. 2004 Rx-8 issues data poll
  27. clicking sound
  28. Exhaust smoke
  29. Clutch Squeak
  30. My Car dies while driving
  31. Clattering
  32. Hard starting -> Bad battery?
  33. smalled puddle of green fluid with a black puddle in the middle
  34. Help! What do all these trouble codes mean?
  35. Back Break light bulb FELL OUT
  36. HELP Please!! About Check engine light!!
  37. brakes squeaks went braking slowly
  38. steering problems?
  39. warning indicator light
  40. Gentlemen...check your grommets!
  41. AT Transmission Issues
  42. HELP!! Immobilizer system issue
  43. Gas fumes inside car
  44. Clutch smell?
  45. CEL on cold starts
  46. Minor Problem
  47. 1st to 2nd Shifting Issues
  48. Vibration on idle
  49. Service Engine Light On???
  50. horsepower lost above 6k
  51. Power Steering Failure
  52. What to do about dealerships not honoring service bulletins?
  53. CEL and Converter Conversion Code?
  54. Clutch problems
  55. Check Engine Lights
  56. Water pump replaced at 11,000 miles
  57. Mazda can't fix the noise under the hood
  58. Car Pulls Left / Right Under Acceleration
  59. Anti Theft Deterrent System Flashing, Can't start car, help? Anyone?
  60. New TSB: Rear Defroster
  61. Getting a new engine -- free
  62. help w/ power outlet in center console not working
  63. Burning Rubber Smell?
  64. slipping clutch. any advice?
  65. Air Bag Code 2-2
  66. Squeaky Shifter?
  67. Crazy Popping Noise
  68. Rattle at low RPMs Help Anyone???
  69. RX-8 vibrates too much?
  70. Cold weather and hesitating
  71. Starting problems
  72. Blinkers don't flash upon door lock
  73. For those having problems with reverse
  74. Car off, no clutch, first gear...
  75. Dead battery
  76. Disappointment in dealer + rattles
  77. No heater/no radio controls/no amp temp/no mode a/c heater controls, WTF?
  78. Cure for vibration/low frequency noise
  79. Leaking sound on startup
  80. clicking sound when i turn on the heater
  81. Car jarring while in motion
  82. COLD start anyone?
  83. Cold Start -> Stall -> No start!
  84. Parking Break/Loud pop in Reverse
  85. Flooding issue (mostly) resolved?
  86. Steering Wheel Vibration and/or road feel ...
  87. Erratic Idle
  88. E Brake Issue
  89. Rattle Noise in 3rd?
  90. New Service Bulletins 12/21/04 - Look!
  91. Running on three spark plugs...
  92. Problems Starting In Cold Weather
  93. Trouble Starting in Cold?
  94. lose throttle response on 2nd gear(AT)
  95. Shifting Into Third - Some Resistance
  96. Need Help with car......
  97. Cold weather woes
  98. Code: PO1226
  99. Car wouldn't start in cold weather??
  100. Low Oil Pressure?
  101. Another CEL story
  102. RX-8 seems to pin at 6000 RPMs
  103. Cold Weather - 26C and Throttle Loss!
  104. Ok....help?
  105. Starting Problems
  106. My 8 won't start HELP!
  107. squeeking rear window
  108. Possibly the Worst Mazda Service Experience
  109. Anyone else have these problems?
  110. Bad PCM flash ? what?!
  111. A fix for noise comming from rear view ?
  112. Car Back in the Shop...
  113. CEL ... AGAIN ... in the cold
  114. Swishing Sound
  115. 4th Gear Shift noise - Gone!?
  116. Stock battery SUCKS!!!
  117. Headlight assemblies finally replaced under warranty
  118. New car no worky anymore
  119. A/C Amplifier questions
  120. i think theres something wrong with my car
  121. tec help
  122. Rx8 Running Like Sh#%@$t!
  123. Help my 8 wont start!!
  124. 5 times to dealer still cant fix CEL!
  125. How bad is bad when it comes to gas mileage?
  126. grrrrrrrr
  127. Extended Spring Cleaning, Dead Battery, Flooded Motor
  128. Slow to start issue
  129. Condensation In Tail Lights
  130. New Flash?
  131. Determining which flash is on my 8
  132. Got my first CEL today
  133. tech bulletin interpretation, please
  134. what should i do with these problems 4
  135. Brake Squeal SB
  136. Smoky smell coming out from vents!!??
  137. Advice needed.
  138. clutch smell???
  139. 4250 RPM idle at startup in bitter cold
  140. moisture in crankcase..."normal"
  141. New Flash Is Available
  142. I Need Help!!!!
  143. Parking brake doesn't disengage completely!
  144. Only 13 Mpg In The City?
  145. Only 3000km and my Driver Door is making a squeaking noise
  146. First CEL leads to change out of Catalytic Converter
  147. Air Conditioning (AC) Complaints
  148. Grinding noise when cornering
  149. Making a turn a getting something wierd
  150. Help! Warranty information.
  151. Ticking / Clicking Sound When Warming Up
  152. Random Engine Stalls Not Due to User Error
  153. Extreme Cold No Starts
  154. Vibration at Speed in Snowy Area
  155. No Starts
  156. Break Squeal Discussion
  157. Washer Fluid Nozzle Issues
  158. Possible Cold Shut-down Solution?
  159. Water Pump Issues
  160. Shift knob looks like hell
  161. TPMS Issues
  162. Auto Trans Jerking
  163. Mazda Service Story
  164. Pedal Slap
  165. MT Reverse Won't Engage
  166. Clutch Noise: Throwout Bearing
  167. Condensation / Moisture In Lights
  168. Seatback and Seatbelt TSB
  169. Lowered my car, now DCS kicks in sooner
  170. Unlock doors with key fob - Hazard lights DO NOT blink. Do I have an old flash?
  171. 1st gear noise brand new 8
  172. Dead Battery After Storeage
  173. how do you know what flash your car is?
  174. RX8 not starting and dealer said...
  175. Repost: Advice in RX-8 purchase
  176. Engine Problems?
  177. RX-8 / 4 weeks at the dealer / japan mecanics came to "patch" the problem
  178. RX8 unable to grab revs in 5/6th!!!
  179. Clear Corner Screw Stripped
  180. Cricket sounding rattle in dash area
  181. Whirring noise on deceleration?
  182. 3 or 4 days for a spark plug?!?!?!
  183. Help! Weird grinding noise with rear right wheel
  184. Warranty issues? & Other complaint/s
  185. Service Bulletin N3Z2-18-881M
  186. Exhuast Issues
  187. Spark Plugs Fouled
  188. DSC Light on after Bad Curbing
  189. Cant play "home made" CDs help
  190. Have An 05's Flooded?
  191. Speedometer Inaccuracy
  192. Arming Alarm Doesn't Blink Tail Lights (Trunk is NOT Open)
  193. Engine Noise
  194. Tranny question...
  195. winter storage, sever misfire, and rotten egg smell
  196. High Catalyst Temperature
  197. Engine Noise Between 5K RPM and 6.5K RPM
  198. Up-to-date TSBs/flash
  199. I did the "Try Lower Octane, Get more MPG" test...
  200. Blue smoke coming from exhaust?
  201. Engine break in
  202. Burning Smell....
  203. Rough And Hesitent Idle
  204. My Car IS Smoking!
  205. TSB Spreadsheet
  206. Oil light?
  207. Gas Mileage Ruminations
  208. Shift knob shakes?
  209. Got a CEL.
  210. N-Flash Discussion
  211. Strange Sound...Any Idea?
  212. How to Improve Gas Mileage???
  213. Engine Breaking and Brakes Squeaking
  214. Flashing dash lights
  215. Clutch Problem Discussion
  216. Burning Oil and the foam at the bottom of engine
  217. difficulty starting my 05.
  218. Battery Problems After Storage?
  219. New owner - throttle/gas delay?
  220. Starting a Flooded Engine (De Flooding or Un Flooding)
  221. Wow What a story to tell
  222. Battery Questions / Complaints
  223. Just Got "Recalled" for the N Flash--Good Idea?
  224. Foggy Fogger
  225. Get Mazda to change their air conditioner settings
  226. my dealership doesnt have the N ??
  227. obd2 READER NOT READING- INTERMITTANT cel
  228. rattle in the door?
  229. Oil change necessary after engine was flooded?
  230. Someone Tell Me If This Is BS....05 Flash
  231. Flooded, second time on M flash
  232. RX-8 Issues-Automatic Stalling at Idle
  233. Oil in Intake / Air Filter
  234. Effects of Gear Grinding
  235. dead engine, help
  236. Broken E-Brake
  237. Automatic jarring solution: Keep revs high early?
  238. what should i do (dealer trouble)
  239. Horsepower Issue !Is this TRUE?!?!
  240. sssshhhhhttt noise I hear
  241. Code p2097
  242. Engine Knock
  243. Appearance Package Isn't Attached Very Well
  244. Check your cars for this..... if you have a manual transmission
  245. Clutch not fully disengaged? Normal or problem?
  246. Jerkiness when you take your foot off gas
  247. In for service
  248. Anyone else have axle whine?
  249. Ringing noise
  250. Official RX8 Noise Description Thread
