View Full Version : Trouble Shooting
- Many issues so far, what else should I get fixed?
- Propane like odor in cab
- Flooding
- Recall Info Request
- bad motor
- Cel P0410 :(
- RX8 Evolve
- oh yes the MPG thread
- clutch chirping
- Reverse Lights Stay On??
- Stalling after getting MSP16
- Findings while investigating misfires
- Light Clunk coming from rear end
- Alternator Died!
- help..several problems..possibly connected???
- Intermittent Engine Air in the AC/Vent
- CEL on...couldn't get over 2000 RPM
- Partially Clogged oil pickup.
- Coolant Smell in Interior
- A/C blowing from cold to warm to cold; varies w/ RPM
- Found clunking issue
- Passenger Side Highbeam Not Working
- New Recall Canada
- HELP!!! REFLASH gone!! i think??
- Potential problem
- Coolant puddled on passenger side footwell
- Latest visit to the dealer check engine light
- RPMs stop at 7K
- Wrong oil??
- Mysterious power lack
- Problem with MSP16 recall
- Car stalling issue
- Wierd Rattle Sound
- Are all oil filters the same/how ofte?
- cooling down
- Diagnose problem...
- Problem continued
- need help car not starting up after sitting there for 6months
- Passenger side mirror malfunction
- the install of the nav unit
- Problem shifting into 1st
- WTF is this???
- Power loss issues, flashes, and dealership woes.
- Headlight level problems
- exhaust rattle Q
- Loss Power Gain
- radio display lighting
- Blinking CEL at 6000+ rpm
- Engine flooding
- Remotes won't program
- Warrenty ?
- Electrical system draining battery
- No torque
- belts?
- another flood promlem? i think not...
- Gotta love the reliability; to the tune of $698.00
- Catalytic Converters?? Possible source of a lot of problems?
- Homelink Button (yes i did search)
- my dear lord
- I finally Flooded it
- Steering wheel wobbling
- No Power Steering
- crazy cel??!!
- CEL Light
- faulty oil level sensor?
- HVAC/RADIO display cycling gibberish
- Rough starts, but smooth ride
- Houston Summer Heat
- k WTF?... Engine light + Now will not start
- weird problem
- clutch pedal issues
- Car keyless remote doesn't work
- Stick is wiggling
- Oil inside Intake Box!
- CELs, A/C and oil sending unit leak... :(
- cigarette lighter fuse
- HELP: I think its the fuel pump? (mazda finds nothing wrong)
- wheel key lock question
- Heater core bypass void warranty?
- Tach Visability Problem When Sunlight Hits It
- Rattling Muffler
- Help please, asap. engine problems
- oil metering pump issues
- CEL Help :(
- any help appreciated
- water in rear seats
- won't start
- Clicking noise coming from the engine
- Power steering and other issues, lemon law
- Overheating!
- Coils and plugs, recall update big mess
- Strange engine noise from 3500 5000 rpms?
- Rx8 Ac problem
- Melted O2 Sensor Connectors
- CEL after MS CAI
- 2 CEL's after Nitrous Install
- Anybody Overheating Out There? I Need To Know.
- Noise after long trips.
- Sqeaks will not go away.
- rattles rattles rattles
- Help!! Car Wont Start
- please Help Help Help
- Low profile auto ramps?
- Help, Engine revving low at idle and even dies
- stalls while @ high speeds and braking - help
- AC/Heater fan "issue"
- Violently Shaking!!!
- so much for great customer service
- Shudder when getting on and off the gas
- Cel
- Cel
- Shudder from Rear Differential
- rust "color"? on rotor discs after washing car?
- list o problems
- Engine shut-off, Need help
- Transmission noises, had it towed.
- Starting issue.. I don't think its compression related..
- Is this a fuel pump problem?
- flashing radiator light and shaking
- Turbo Timer Issue
- Need help before it gets dark!-Flooded
- Good AC then no AC now half AC...
- Cooling Light and Fan
- Hot air from vents
- Anyone need a center console lid?
- E-brake light...
- constant clunking and "some" grinding from under the car
- Optima doesnt fit?
- Seat emblem
- Clutch Problem....plz help guys...new to rotary's
- Passenger Window won't move
- Car won't start when it's hot.
- Emission control issue, PLEASE HELP!!
- Just bought an RX8
- Replacing coils and wires
- power loss. engine noise... ideas?
- M/T going bad???
- Air leak when car shut off?
- Ideal Idle?
- Clicking Noise when AC is On
- NEED HELP WITH K&N cool air intake filter
- TPMS wont turn off after accident.
- noise while clutch pedal is pressed in
- Turbo Install Help!!!!!!
- AC belt
- brakes chattering in corners at high speeds
- Flywheel/(or) Clutch?
- Clutch Switch TSB
- It finally happened
- Wanted: Faster Acceleration
- Odd Power Steering issue..
- Need I worry about intake grommet issue?
- Found the ticking, but not the 'chirping'
- Bad Starter???
- Engine died and stange smell
- Not a good day...
- RX8 stalls while under idle?
- My ECU and starter motor has blown
- Cruise Control Works Intermittently
- CEL & DSC lights on (Won't rev)
- Cant get into 1st... Sometimes
- Difficulty engaging reverse gear
- Weirdness with all dash indicators
- So Whose got a wiring diagram?
- help weird engine rattle
- Another New Greddy Turbo Intall With Issues
- Mysterious Light coming ON and OFF
- white smoke from A/C and strange hiss from engine
- Rx8 Cel
- AC vents wet inside the car
- Squeaking Sound under 25 mph
- Alternator Voltage
- dead key fob, but new battery doesn't solve it
- Coolant in the Air Intake...WTF..!
- Idle Pulley Misaligned
- Loss of Interior power ?!
- engine whistle at 2krpm
- SSV Stuck Open? -- Greddy Turbo
- transmission
- My pedal went limp.....Uhhh... WTF...
- TCS with new rear tires
- Problem with new engine
- Caliper Piston Frozen
- Clutch Issues (Please Help)
- Question about TSB's
- Transmission problem?
- Engine Warning Light flashing.
- P0420 Cataclyst System Efficiency Below Threshold (Bank 1)
- After Market Sway Bar "Clunk/Popping" Noise
- Transmission/ Clutch issues
- New Engine or Just a Rebuild? Help.
- compression test?
- Can't hold idle
- Just an update.
- Car not starting, I think it's dead.. gah.. help ; ;
- Car turning off during a hard shift?!?!?!
- exaust pops and engine hesitates (cold start)
- strange noise!!!plz help
- Problems After Turbo Install
- drifting clutch engagement point when car is hot vs warm vs cold
- Help me Please. Engine runs Rough
- ABS / DSC light removal
- CEL blinking
- Turbo oil line. Need help
- Alternator reading
- 6th gear grind
- Compression test?
- Help! - Mazdaspeed ColdAirIntake = high RPM crackle/chatter
- I think my engine just seized. HELP!!
- alot of probsss
- Engine Seized w/ 34000 miles!!
- Dtc P2010??????
- Lost horsepower
- Air pump
- Installed Cat Back Exhaust and now I have a check engine light????
- Engine noise
- Check Engine Light
- Indication of compression loss?
- 2003 4AT facing the Noise problem,PLEASE HELP
- So my sunglass holder pee'd on me...
- engine having hard time starting (dont know if its flooding)
- Is my E-brake working properly?
- Car starts/idle when cold, as soon as warm it dies
- Help on loss of power (LOTS OF LOSS)
- suspensions clang???
- engine got no power at all
- First Check Engine Light Problem
- Help Clunking Noise When Starting
- 9 Mpg 05 Rx-8
- Warranty on AF SS?
- Advice - Ignition Coils
- Squealing Belts
- Whats going on here???
- Water Flowing Noise
- Whats wrong with my RX-8
- $#ITI start to my lonf holiday weekend.
- front brake caliper problem
- Oil Question
- Broken Air Intake connection
- Odd sound when hitting 8k-9k RPMs
- disengage clutch weird idle ..HELP
- Headlight level off
- Two stroke oil mixed with 10W30
- Rear tail light side markers
- tranny problems
- Cloudy Headlights
- wtfomgbbq weird ass electrical problem??
- Please help me figure out whats wrong with my car!!!
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
