View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. picked up water in fuel tank
  2. picked up water in fuel tank
  3. Flat battery because FUEL relay stays ON!
  4. weird smell after i shut car off
  5. Input shaft bearing???
  6. This might be my first rebuild...
  7. mobilize without reason
  8. Help takes a while to start
  9. Coolant light always on when in high RPM 5500 / 6000
  10. buzzing sound!
  11. Need New Engine
  12. Another 8 That Won't Start......damn!!
  13. What causes misfiring on a cold start?
  14. 6th gear grind and tough reverse
  15. Question (RB Ignition Wires)
  16. too much oil on dipstick????
  17. Water in tail Light . How many?
  18. Having problems w/a clutch pedal bracket???
  19. New engine checkout
  20. Throwout Bearing-Already searched, didn't find exact
  21. Cel
  22. Which way to turn caliper piston tool for rear brakes?
  23. misfire...after coils and plugs changed.
  24. Stock suspension Squeak?
  25. Spare tire mount
  26. Movement in the rear / feels unstable???
  27. Poor Acceleration and Stalling
  28. Transmission came apart at 60379 miles
  29. Advanced Keyless Entry Problems and other concerns
  30. Coolant light comes on during startup
  31. Help
  32. Need Major Help!!!
  33. Car Won"t Start....
  34. Heater Help - I'm desperate
  35. Intermittent Acceleration Performance
  36. Brake Issues/Noise/Heat
  37. LOW on POWER
  38. mazda says i need $11775 to repair my 8
  39. 'Lapping' noise?
  40. Stealership wins again? $700 for coils and starter?????
  41. Burning Oil
  42. Cant get good gas mileage?
  43. burning huge amounts of oil-opinions?
  44. Listing of TSB?
  45. Baseball Card in spokes?
  46. dealer can't figure out what happened, help
  47. Vibration issues - another one..
  48. Idle problems
  49. Rattling near the steering column?
  50. Spark Plug is STUCK!
  51. petrol smell? what is it?
  52. windshield wiper motor loaction on car ?
  53. Power Steering Light 1st.. now instrument cluster
  54. Sorry to bother you all...
  55. Mazdaspeed cold air intake question.
  56. How to test TPMS sensors?
  57. Rattling Sunroof
  58. Air pump function?
  59. Weird noise from wiper
  60. CEL after stall
  61. This number of problems normal?
  62. Cat-converter
  63. Failed engine and cause of failure. Need wording clarification.
  64. Mileage Problem
  65. smallest wheel size for snow tires
  66. really need help rx8 smoking real bad
  67. What the heck happened to my spark plug??
  68. CEL/Power Loss--What's Wrong with My Car?
  69. Just got my car out of the Body shop.. ABS light on WTF? Please help!
  70. Question about oil for my 8
  71. knocking while driving.
  72. Misfire!!!!arrrrgh!!
  73. a question concerning royal purple diff/trans
  74. Help with Gasket Part Number
  75. Help! car wont start will crank just changed battery
  76. Rumble and Rattle
  77. Electricity issue in my 04 Rx-8!
  78. ABS and TCS light won't go away!!!
  79. Engine Bay Smoke After Startup
  80. Cold air from vents while turning right at low speeds
  81. Loss of acceleration in boost
  82. Bye new car
  83. New Owner... engine sqeeling?
  84. Coil problem
  85. Engine kinda hiccups at idle.
  86. Expected Engine life
  87. Radio LED Display is out but Radio works fine??
  88. BIG RADIO PROBLE...I'm an idiot...help PLEASE!
  89. vacuum hose not in place
  90. New ticking/knocking sound after odd rattle on WOT run in 1st gear?!?!
  91. Questions About What is Covered Under Warranty?
  92. creaking noise from clutch pedal
  93. Fuel - What to use?
  94. Shit- Spark plug mix up!
  95. White milky substance on oil dipstick. WTF
  96. CEL - gone??? wtf??
  97. trouble cranking
  98. Coil Pack Order?
  99. Power steering dissapeared...
  100. oily smell inside cabin
  101. crank angle sensor
  102. Cold Start Auto Reving
  103. CE Light on (P0507)
  104. Couple of problems...
  105. passenger rear light side strip leds not working help!
  106. Problems from Coil/Plug/Wire change..
  107. Sick sounding engine....
  108. Mild Power Loss When Engine Fully Warm
  109. drive side door speaker
  110. Airbag Light Flashes then turns Solid! HELP!
  111. Engine Light (Bogging)
  112. Anyone able to get Mazda to pay for 2nd Flooding?
  113. Misfire and po420 error code
  114. Help me please!
  115. coolers
  116. Unknown Airbag Code
  117. lower intake removed and Holey crap!
  118. Exhaust spring bolts torque?
  119. Engine compartment light
  120. Handbrake Issue...
  121. about misfire..
  122. Emergency Brake light stays on
  123. Compression Results. what are the chances..
  124. problem with brights
  125. WTF: Oil leak?
  126. Drivers side window wont go up with out help
  127. Do I just need to buy a whole new head unit???
  128. Help! Oil smell, smoke, and sputtering!
  129. Racing seat installed (Airbag light on!!)
  130. Limp then constant CEL + TCS
  131. PLEASE HELP! Check engine light!
  132. What do you think?
  133. power steering
  134. Engine noise
  135. Strange electrical problem after rain
  136. Suspension promblems...
  137. Need help
  138. Fuel smell
  139. Something very strange, anybody knows what's going on?
  140. Something very strange, anybody knows what's going on?
  141. Intake Valve stuck Open????
  142. Oil leak?
  143. Stock radio no longer recognizes CD Player - AudioLink at fault?
  144. steering wheel noise
  145. motor mount bracket
  146. Slight power loss - Slightly different engine note
  147. Replace Rotors and pads after 36,000 miles?
  148. Car stalls when stopping.
  149. engine rev = squeak?
  150. 2006 RX-8 steering wheel vibration?
  151. Car won't go into 5th
  152. Ignition Coils
  153. Radiator Light after storage while driving
  154. Need Ac Amplifier
  155. Car turns on and off then stalls
  156. TurboXS & Stock Cat
  157. Weird RPMs with clutch pressed and in gear
  158. Need some advice - Old 8 w/high miles
  159. Cigarette lighter rattle
  160. Catastrophic Misfire Catastrophic Cat Meltdown
  161. My RX-8 wont start - solved (ignition prob.)
  162. Stalling and power loss after long trips
  163. RX8 steering wheel emblem
  164. Spare Tire? Where to buy and What Size
  165. Odd Electrical Problem -- won't start
  166. Car wont start
  167. weird sound from exhaust
  168. Keyless entry lock confirmation?
  169. engine warning light
  170. I got a CEL Code PO456. Any suggestions?
  171. TPMS Blinking After About 20 Minutes of Driving?
  172. Weird engine activity while driving.
  173. Power Steering Help
  174. Regional Service Manager refusing Aqua Tail light mod TSB
  175. Codes
  176. Clutch Installation Problem!!!
  177. Personal write-up of my prgressive engine failure
  178. idle
  179. Question about Engine Failure
  180. cant solve a Problem on a Turbo Rx8?
  181. Gas overflows
  182. Cold Idle Issue.. huh
  183. Injection system malfunction and Misfire cylinder 2
  184. a wierd noise when i hit my breaks?
  185. Misfire CEL, dealer gave car a zoom enema and compression test, thoughts?
  186. Dealer's Line on Brake Pads
  187. Rear wheel / suspension issues
  188. Supposed Engine Failire and Dealer Run around
  189. Oil sensor is broken and leaked out all of my oil...
  190. bodyshop flooded my car!!! eerrrgggg!!!
  191. Failed PA Emissions Today
  192. P0037...Motor Threatening?
  193. Please help and tell me what I need to do to fix this (loose oil sensor) *pic*
  194. Alarm remote wont work!
  195. Is something wrong with my Tranny or ECU?
  196. engine oil leak
  197. How long does a battery recharge take?
  198. Mazsport cooling fan, where should the 2 hose clamps go to?
  199. Mazda thought they would get me a new engine!
  200. revving beyond redline
  201. A Few Issues...
  202. How to clean throttle body?
  203. 3 week old battery dead?
  204. TPMS light
  205. A/C Fan randomly starts/stops
  206. Flooding
  207. Turbo xs exhaust leak
  208. How can you TELL HID or Regular lights
  209. so i dont know what happened
  210. Oil metering pump gasket leak?
  211. Ticking noise high load above 5K Revs
  212. Idle issues and fix!
  213. Not flooding issue... Car stalls after starting.
  214. Blows ignition fuse when put in reverse
  215. CEL on...idling issues
  216. CEL because of carbon buildup?
  217. Random CEL...?
  218. oil leak...
  219. Battery light is on and then goes away
  220. inner shift boot replacement
  221. Help! Did my clutch just go out?
  222. A/c Problem
  223. Auto Levelling headlights not level
  224. Extremely weird idle
  225. Throttle is getting stuck please help if you can
  226. Rear noise
  227. STOP Fuse Keeps Blowing...
  228. Cabin Temperature/Thermostat Issue
  229. Help me fix my knob!
  230. exhaust leak...am i missing something
  231. '09 RX-8 In-Depth Changes
  232. Engine replacement poll?
  233. Possible Voltage Regulator Issue
  234. Help - my engine's a dud
  235. Advice needed - replace starter?
  236. i need to change a bulb from my fog light help
  237. P0610 - PCM fault (but my car is fine?)
  238. crunching/grinding sound when turning at slow speeds
  239. Electrical Problems
  240. Cold Start issue
  241. Tracking down mis-wired / badly done DRL conversion
  242. I know its not an 8 but its my first car....
  243. A/C & Heater Blower fan keeps stopping
  244. Weird sound after 6,000 rpm???
  245. Rough Idle Help!
  246. New to the form
  247. Multiple PCM Codes
  248. loss of all oil after oil change
  249. horn
  250. CEL possibly caused by new brake pads/rotors?
