View Full Version : Trouble Shooting
- AEM Air Intake Question
- High pitched harmonic at low speeds, any clues?
- Potential Long Term Reliability
- Compression test, ¿is it correct?
- Center Console Dash Squeak.
- New to the RX-8 club, just some minor probs and questions.
- gettin my car back post Misfire CEL
- Rough idle and low power problems.. (also using 5w-30)
- Broken side view mirror, need help with wiring diagram.
- Help! Alarm issues
- Screw Clamps vs Spring Clamps?
- CEL, need help deciphering codes
- Engine Lag/Gear Lag
- I can't change into gear! : ( HELP!
- loss of all power and rattling
- oO New 2004 '8' owner, CLUTCH/TRANNY THUNK Oo
- JDM & Retractable Keyless
- Dealer ruined side flares
- not sure if my tpms is working????
- Engine Light :S
- A/C dead
- Solved the p0302
- Rev limiter on 04 MT RX-8?
- Advanced keyless card. Is it supposed to lock my doors?
- Problem with A/C compressor
- New member
- Strange stalling
- Engine sputtering + check engine light = spark plugs need replacement?
- Coolant Light
- TPS Trip
- Beeping when car starts
- Emission recall test question
- Problems closing the pass. door
- Homelink Problem
- Brake System Warning Light, ABS Warning Light and DSC Light all on at same time?
- CEL on after 15000 miles
- Help : Oil leak...
- Failed motor mount?? Need help!
- Clutch won't disengage after 20 minutes?
- Gas in the oil?
- Flashing CEL after Pulley's and Plug wires???
- Ideas?! Electrical problem after floodwater problem
- Similar Problems posted here, Can we drive it?
- warrante!!
- What is difference between flooding and other starting problems?
- Struggling to Start
- CEL: Running Too Rich problem... need help
- Remote/Reciever Problems
- sun roof noise
- lagy at low rev help need help
- MS Exhaust Issue
- Slowly destroyed mid-pipe resonator...
- Freshwater Flood
- TPMS Stays on and Beeps
- Dead Battery after only 20days.
- ran out of gas, now won't start
- 3305G and 4206F and reflash on tuesday
- Clutch Pedal Question
- Soft clutch after friend drives...
- Tough to start/rough idle
- Compression low on first Rotor
- PIE adaptor shuts off radio every 30 seconds...
- Radiator light comes on and off
- Engine/Tranny problems.
- Shifter Light problem, help needed
- Fans = Dead Battery
- AT Disappearing LED Display
- 4AT minor vibrates when shifting gear.
- Dealer says I need a new PCM - P0160
- Steering issue
- strange noise
- 27,000 mi Clutch Questions
- low comp on ONE side of the rotor? weird prob insues
- engine change
- Need new battery?
- squeak squeak
- Engine growl, hard start, and rattling...
- Engine problem, need advice
- Help! White smoke from engine.
- Squeak when clutch released
- where's the valet override button location?
- Problem with auto levelling headlights?
- I may be joining the 3rd engine club!
- B&b Midpipe+greedy sp2 exhaust
- Anything else to look forward to.
- Coil Issues?
- Any Advise
- Hesitation at partial throttle and cruise control inoperative
- HELP! car just die.
- Power loss + DSC light flashing
- Cylinder 1 Misfired
- Whats wrong with my brakes??
- Unwelcome ticking, need some help
- Stall after high speeds
- Cant pass 4000 rpm
- P0048 Turbo/SuperCharger Boost Control Solenoid Circuit High
- Red Fluid on Top of Battery
- Revs stop climbing at 7k?
- Battery or alternator or something
- Rear plate will not come off? Help!
- Messing with the clutch engangment got me a constant parking brake light?
- Weird noise after engine install
- Can Someone Help With The Steering Light?
- RX8 Knocking
- Engine Won't Start Help..
- Rough Gears!!!
- Gear Oil Leaking, Cannot See Where It's Coming From
- CEL on after some normal driving
- 8 wont start..
- trunk light fuse
- I need advice on a flooded engine
- Engine stutter from 6,000-7,000
- extreme power loss, flashing cel, muted exhaust note
- Exhuast flames on the track
- CEL light on after installing intake -CO2 sensor code?
- Question about the Nav system
- 60k service
- Slight loss of power as engine warms up
- Oil in Coolant Tank
- Drive Train Loose (NOT HESITATION)
- stall after highway driving.
- It Won't Ignite!
- auto-revving engine??
- passenger tail light fogging
- Clutch and frozen gears
- Rained and Flooded my car
- Clutch going bad or what?
- Help! Wont start
- Ignition Coils, then Cat...
- Fuse cracked
- 8 causing trouble with the POLICE!
- Cranks but no Start. More then flooded?
- Puking Antifreeze
- limp mode under brakes - help !
- blinking check engine light?
- Oil drip
- Another Fallen Rotory
- Leaking Racing Beat Revi Cold Air Intake
- Ignition issues?
- It's the battery right?
- Ensuring a Long Life
- Major Power Lose
- Clutch is Slipping, What to do?
- New owner. Power steering, headlights, and shifting issues ('04 AT)
- Center Console Lights Flickering...
- Finally Happened to Me ***Flooded***
- 2nd Gear Syncro shot
- Cel- P0450
- problem: won't accelerate
- i need help
- Front Rubber Thingy...
- Squeaky Brake Pedal After Flushing
- Power Loss/Stalling
- strange electrical problem
- Front Tire Rubbing
- no sound in my radio I NEED help
- Compression / Power loss resolved on '07 & '08 models?
- P0456!
- blinking traction control
- Way more brake dust on rears than fronts
- cold engine squealing
- Lost heat in my car....please help
- New Service Program for 2006-2007 RX-8a
- anti roll bars
- Engine Oil Purchase
- air box engine light
- Wheres my Intake vacuum hose???
- RX-8 and Greddy turbo dissapointment
- Help. warning lights randomly turned on.
- Steer noise?
- Headlight Auto Leveling Sensor - Can it be rebuilt?
- new to the club
- Carbon Fiber Trunk Issue
- clutch gone
- Replacement headlight problem
- Soot on Rear bumper
- Airbox/Intake box clip lost
- CEL Flashed... Issue?
- Serious Issues.. need HELP.. ASAP
- rx-8 dead battery
- Senile Battery Question
- After Flooding loss of Power and strange noise
- Surging idle
- Grinding 5th gear on upshift
- Warranty Wizard???
- need help with my heater....
- I think I'm screwed....
- Flowing water sound...
- Please help!
- Heating does not work
- lifter tick on my RX-8
- Battery Drainage
- serious problem, please help
- tail light water get in......
- Massive noise coming from driver side wheel...
- Clutch problem!
- RX-8 Stalling
- Dipstick covered in yellow goo
- AFE Short Shifter Problem
- scanalyer question
- Difference in 2005+ alternator?
- My very first CEL (P2070) @ 71,000K
- Faltering at 5500 RPM
- Um... Bent Rear Axle!!
- ABS/Traction problems after stuck in some sand
- I think my 8 is flooded. Should I try myself or tow to dealer right away?
- Car doesn't turnover. Battery "seems" good.
- Poor idle then stall
- Dealer Wants to Clean Injectors at 49k miles??
- Chugging at 80mph at 4-5K RPMS
- Clicking while idle?
- So...I need a new engine...
- Heater not working
- unable to open my trunk
- HELP I have a CEL on
- Ratteling in Steering
- engine stalling (o2sensor)
- neutral switch
- Testing a Fuel Pump
- Z-Enterprises Grounding kit problem
- Help! Car won’t accelerate! Absolutely no power!
- Major Stalling!i
- Heater Issues
- sputtering idle and car dies!
- Car won't start... : (
- Got Ventilation Kit to Fix Dipstick Foam- Now Engine Light is On
- Engine Rattle between 3k and 4k rpms
- f**k, my car won't start
- Damage From Hks Hi-power
- Major Engine Problems! Help!!
- greddy turbo=apex seals gone!
- Rough Start->No Start
- Diff going out?!
- Rough Idle... solutions?
- Big Problems With Brakes!
- panel on back of steering wheel loose
- No start, Snapping sound....
- Contesting Warranty?
- Need pics: (1) secondary air inject. pump conn. & (2) eccentric shaft position sensor
- Check Engine Light, Diagnostic reads Ford code?
- Car wont start
- Difficult to feel the "end point" when screwing in the leading spark plugs
- rx8 going to shop tommorrow for sputtering should i ask for certain test?
- This every happen to anyone?
- New Oxygen Sensor.
- Alignment = Headlamp Auto Level Light
- Could too much oil + cold = no start?
- No Heat in My CAR!!!!
- CEL light scare Non mechanical Noob
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
