View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. No start. No crank. Nothing...
  2. Just Got An Rx8
  3. Help!!! I'm stalling...
  4. 2007 RX-8 AT stuck in 6th at low rpm
  5. Problems with non-electric seats in 2007 RX8 Sport
  6. Ignition Fuse Keeps Blowing
  7. Turbo Rx-8 won't stay running/ hard start
  8. Car will not start - think it is the starter ?
  9. Coolant overflow issue
  10. new tranny issue
  11. Chirping Noise
  12. Scary Problem After Running Amp Cable Pls Help!!! Abs/dsc
  13. Stripping Of Behind Glove Box Items
  14. new alternator
  15. Hard Braking possible problem?
  16. Sound System Cluster Removal
  17. P0455 EVAP system leak detected
  18. Trans Noise in neutral
  19. I Need Help
  20. Sway bar swap clunk?
  21. '04 4AT linkage locking up after quick shift
  22. Flashing CEL while doing 100?
  23. Oil leak - or not .....
  24. My visor broke
  25. Rythmic sounds with cluth released
  26. How to increase revs when in neutral?
  27. CEL this morning.
  28. Need advice with issue
  29. Please Help Problem after changing coolant
  30. RX8 Will Not START
  31. Runs like crap only with AC on
  32. Audio CD stack on the player.
  33. Instrument Cluster Lights
  34. My daughter needs your help!!!
  35. CX7 smartcard keyless? would it work on my 8
  36. Battery amp/hour rating--pass/fail question
  37. Driveline slip yoke seal
  38. Steering wheel lock disabled?
  39. Weird Battery Post Oxide/Corrosion Build-Up… help!
  40. Cylinder 2 Misfire???
  41. wierd bucking at 74 mph
  42. Clutch Release Issue
  43. 30,000 mile maintenance cost
  44. HELP for HID Conversion Kits
  45. Radiator fan stopped working....
  46. Clutch slave cylinder TSB help
  47. high pitch noise at freeway speeds
  48. Low speed rubbing noise?
  49. Does this mean bad ignition coil?
  50. Hitch-pitched sound sign of bearing trouble?
  51. Doesn't go into bottom gears........
  52. 9th time car wont start -- Mazda Sucks
  53. New motor mounts = Godlike
  54. Engine Check light
  55. Cat problem?
  56. Another cat problem!
  57. Engine light because of?
  58. Gearshift moving all over the place with the engine throw...
  59. So Mazda wants to replace my Wire Harness
  60. Car engine automatically dies?
  61. Smell of gaz??
  62. Choking/Clogging Noise
  63. New To Rotary...
  64. Strange stall/coolant light Situation Yesterday
  65. Power loss on long distances
  66. First CEL, now what?
  67. Knocking noise, loss of power in low rpm range
  68. Anyone with an '06 need new motor mounts?
  69. One of the HID dies...
  70. Rough riding noise from rear tires
  71. Oil lamp quick flash on expressway
  72. HID -> halogen?!?!?!?!?!
  73. OBDII Port location
  74. Temperature Sensor on Turbo
  75. car just died in the parking lot
  76. CEL problem ID'd...stuck shutter valve
  77. [Video] Fuel starvation problem - And I don't think it's the track-day related one
  78. Cusco LSD Problem PLEASE HELP
  79. Broken Shift Knob
  80. quick question on the fan
  81. Mazda Denies Engine Replacement
  82. Blinking Lights Problems
  83. Need Help! RX8 died on me!
  84. Stipped hex insert in rear endlink! Help needed...
  85. How many miles on RX-8, and whos had their engine replaced and Why
  86. Bumpy Ride...
  87. Mazda Caught MY RX8 on FIRE!!
  88. misfire cylinder 1
  89. clutch problem
  90. Nasty sound on cold starts
  91. Battery box not flush with airbox or ecu.
  92. Can no longer maintain ~75mph while on a slight grade.
  93. wiper fluid pressure
  94. Engine whine video
  95. Please Help, "Bracket that secures Clutch Pedal Assembly"
  96. Headlight issues-photo request
  97. Why "Do" Rx-8 engines fail?
  98. Reverse switch oil leak
  99. 5th / 6th Gear Grinding
  100. Grinding gears/ canada warranty issues
  101. sputter, flash no sputter, 3 hours sputter
  102. Can't go up hills...clanking sound in 1st
  103. Bad vibration with noticable knocking in the transmission/shifter
  104. temperature gauge indicator problem
  105. 04 33k Miles Engine Stalls Exhaust Pipes Shake and Putter
  106. Diagnostic shows: Problem with COIL A & C
  107. CEL water pump.
  108. CEL P0411 thrown after full exhaust done
  109. Low power at low rpm. #1 Coil bad
  110. Replacement engine longevity
  111. Engine Vibration During Cold Reving
  112. Possiable tranny problem?
  113. Car runs rough at idle when brake is released?!?!
  114. Challenge! - Diagnose my 8... R U smarter than my service center?
  115. Question?
  116. Surge while crusing at 45mph!
  117. My 8 Stalling
  118. Water in exhaust!!
  119. Tranny noise sounds like its blending rocks
  120. Weird transmission feel/sound
  121. Power loss power loss
  122. Sudden Power Loss at 60mph
  123. TPMS light malfunction/problem
  124. Car "rocks back and fourth" during 1-2 shift
  125. Sputtering
  126. clutch problem
  127. B pillars purpose?
  128. Are 'rattles' a valid warranty claim and dealership visit?
  129. LOTS of smoke coming on start up
  130. No Heat....
  131. Need some help - Engine surging
  132. battery always dead needs charge
  133. Looking at buying a rx-8
  134. Power door lock problems
  135. Problems with rattles.....
  136. HELP! I need advice on what to do
  137. Transmission Failure
  138. Broken intake mesh screen
  139. transmission issue....
  140. Transmission issue (but what exactly is it?)
  141. ABS Test Clunk during driving
  142. Front Headlights dry huminity
  143. Very Rough Idle - Video Attached!
  144. uhm..... wth is with my stereo?!
  145. Problems with MS Cai
  146. ok to teach on an 8?
  147. strange clunk when turning right
  148. car won't start, all gauge lights 'flicker'
  149. true they burn oil?
  150. new to site.How reliable is the rx8
  151. Engine Pinging after extended trip
  152. Did this happen to anybody ?
  153. Creaking from shifter area
  154. how do i remove the o2 Sensor?
  155. Gas smell in cabin? And P0301 CEL
  156. *NEW* 2007 RX8 GT, Tire thumping. Any Advice?
  157. noisey gearbox on my rx8
  158. Engine fan remained on after shutting engine off
  159. CEL Under WOT in 4th Gear with Passenger
  160. A/C leaking water on passenger floorboard
  161. Car hesitates when cold - CEL p0301
  162. Problems at Startup
  163. Ping during cold start.
  164. a/c belt squealing on startup??
  165. Slow start up fixed
  166. Engine/Exhaust Probs
  167. tire pressure light blinks..and blinks..
  168. Battery keeps dying
  169. Strange thing happened this morning
  170. Bank1 Sensor 2 Cel
  171. Potentially joining the new motor/tranny club....
  172. How to maintani a Rx'8
  173. Power loss at 3rd gear
  174. Pulling Issue.
  175. Very low air fuel ratio, low 11s
  176. trans grind after royal purple, ordered redline shockproof....
  177. Parking brake replacement instructions?
  178. Idle problem / Mazsport cooling mod / fan issue / problem found?
  179. oil soaked air filter!!
  180. help with exhaust
  181. New Guy, Just Joined
  182. Steering Wheel Locked While Driving
  183. Town North Mazda; Richardson, TX = Not good.
  184. Power Steering Malfunction Indicator Light appears every few days now
  185. Any cause to worry?
  186. idle issues
  187. Worried about my 05'
  188. Engine losing oil!
  189. Metallic rattle at idle after warm up...(New Marbles in a Can?)
  190. computer problems
  191. Motor mounts replaced have a question.
  192. MoonRoof wont open!!
  193. Freaking hot seat rails!? Passenger only - need a couple answers.
  194. New engine lasts 3 days
  195. CEL Blinked At Me *Oh Noes*
  196. Check Engine Light... Details Inside.
  197. I got oil coming out my a*ss
  198. Need Help Getting to Bottom of Misfire Issues
  199. Clear coat pealing, warranty fix?
  200. Strange Clutch Issue
  201. When starting... supposed to wait?
  202. Roof/ceiling tapping noise
  203. DAMN another Misfire P0302 here!
  204. What should I check before the warranty goes?
  205. Noisy brakes
  206. Engine failure – Have you opened an engine up?
  207. Stalling - Idling rough, then ka-put!
  208. Shifting Problems
  209. Power Problem (UK)
  210. Change in the sound of your exhaust
  211. More Brake Dust out of the rear brakes
  212. Question about bogging engine
  213. Are the 04 trannys ticking time bombs?
  214. Engine Issues! Need HELP!
  215. Got the news today--new synchros on the way.
  216. No A|C or on-heated air
  217. Window Problem
  218. Car Smells Like Gas!
  219. Help please - urgent
  220. Question - How Much Does Your Coolant Rise/Expand?
  221. just bought used, what should i look for?
  222. Snychro update--new tranny not a rebuild
  223. Getting tranny and diff fluid tomorrow, what to buy?
  224. popping noise from front brake
  225. Have any one have problems with their 06-07 RX8?
  226. Interior lights flickering
  227. Ebrake malfunction?
  228. Oil Cooler Blockage?
  229. Clutch safety switch.. help!
  230. help with pulleys
  231. clutch will not disengage
  232. MT engine stall at idle
  233. Need some help on engine problems. Thanks.
  234. Strange noise from below
  235. Sluggish at low RPM, stall at idle
  236. Experiencing problems with the Mazdaspeed cold air intake installed?
  237. blower fan died
  238. problem with my 05 rx8 i just purchased
  239. Installed pulleys, now CEL is blinking
  240. Possible solutions for brakes squeal..?
  241. Shinka vs. reg rx8 (engine wise)
  242. Whats Wrong With My A/c???
  243. Handling a bit off, steering wheel vibration
  244. Oil Go Bye Bye
  245. Break in issues
  246. squeel noise from centre console
  247. CEL Light on Again... PLUGS???? AGAIN??
  248. Keyless entry :(
  249. mazdaspeed intake, sock
  250. Banging noise.. =( HELP!
