View Full Version : Trouble Shooting
- shifter rattle?
- Car shut down after pressing Start Button
- Seat Belt light malfunction
- car shakes at 1k rpms
- Massive power loss in top-half of rev range
- Idle issues after putting stock intake back on.
- top speed issue.
- my dead tranny...
- 4206F Interesting Repair Procdure RANT!
- A/C blows HOT after recall
- Problems. Nees Answers ASAP!
- scored front brake rotor, minimal mileage
- 2004 RX-8 Will Not Start
- Oil overfilled: potential for damage?
- Catalytic Converter...
- Fan running more after recall?
- what is this??? wont rev past 3k!
- Powertrain Control Module Recall
- Is my motor blown?
- Broken AC Temp Control Knob
- need help don't know whats up with my car
- Seat Controls Fall Off
- Loose dead pedal
- My '05 has some electrical issues all of a sudden
- Won't even make a sound!!
- AEM/MS CAI Intake in wet weather
- rattling sound @ 5k rpm
- RP Super CAT
- Power steering fail & uneven steering force
- Oil on Air filter + Strong fuel smell on oil dipstick!!!
- how many have fuel stavation issues?
- Infrequent Idle searching when cold, can't easily recreate the problem
- Street Racing?
- Alignment Issues
- AEM sensor problem
- too soon for scheduled maintenance?
- Radio Reset
- Clutch Noise when Idling. Goes away when clutch pedal pressed.
- Problem w/ Seat Belts & Suicide Doors...
- Blinkers no longer flash when locking/unlocking.
- steering wheel rattle
- excessive transmission noise in 4th gear
- rattling and hesitation in 2nd gear
- Smell when approaching 100mph.
- crankshaft sensor
- 3rd and 4th Gear issues
- Clutch worn out in 18 months
- AC Condensor woes
- Oil consumption
- a newbee problem
- Return of power loss problem while goiing..
- Engine Coolant
- Problems with cold air intake!?
- Vacuum Leak
- Problem with acceleration in first gear w/AT
- brake service bulletin
- Click when engaged in to park
- New Plugs?
- HELP Alarm going nuts
- Remember that problem? After fwy crusing, the car would have NO power?
- Shifting problems
- RH Taillight Problems w/ Sirius Radio??
- 4206f flash
- fan on when i turn off the car
- CEL at 55050
- Cracked windshield....your thoughts please
- CLUTCH burn out!!
- Help!!! RX-8 Won't Start!!!
- Lost power in 1st gear.
- Metal "clunk" noise in first gear.
- Parking Brake Handle Replaced with Plastic
- my poor baby......
- Idle vibration after recall service
- Is anyone else's car running worse after the recall flash?
- How much pressure in oil cooler hoses
- No 6th gear -> Mazda replaces my tranny
- Hesitation in 1st/ oil ?
- Front Suspension Squeak When Cold
- Weird Rattle
- Is it possible to replace these LED/Blub ?
- Anyone know what this means?
- Axial Flow SS
- Idle problems after blown fuse
- what does the 9k beep sound like ?
- Headlamp Pattern after collision repair
- Driving in snow
- 30 Nov = Eday (Engine Day)
- What's the trick to get temperature knob setting to appear on LED Display?
- Intake runner valve stuck open
- Service made it worse!
- Car wont start
- underdrive pulley kit install problem
- help with problem.....need advice from intelligent rotorhead......
- Alternator Died
- Anyone Have/Had These Problems ??????
- warranty problems with riverside mazda
- Engine freeze at 3000 rpm !
- First Oil Change...
- 2004 RX8 Touring: Issues since purchased
- Tranny Question
- 7000 RPM Stutter, CEL Flashing
- Constant engine whine, regardless of RPMs
- My heater doesn't heat my feet enough..
- Lack of power and rattling noise when accelerating above 5000rpm
- My car doesn't burn any oil...should I be worried?
- CEL came on!
- Paint adhesion problems anyone?
- Flat spot in 2nd gear
- loud noise comming from the glove box area
- My Car just doesnt burn oil, it drinks it to!
- Strange problems with 8
- well it finally happen
- "Brake Vibration"
- RX8 will not start
- SSV stuck open, cheaper fix ????
- Automatic trans problems, I think
- Brake squeal fixed -- finally
- Brake Light On Help
- 5th gear grind
- serious loss of power going up a hill
- Excessive road noise
- 2nd gear grinding (sort of)
- Lost wheel lock!!
- starting trouble...
- Purge solenoid valve. Is it possible to check?
- Seat cover removal around air bag?
- Short drive flooding and solutions ??????
- car running like crap
- flooding or something else?
- Bad Gas Mileage
- check engine light
- Water pump leaking?
- Ghost in the Machine.... my car has gone insane...
- Weird Problem
- My Spark Plug wire Pop out!!!
- Rear defrost problem
- clutch lever arm
- CEL and symptoms
- Light Dimming, Alternator Going?
- How to replace the stock HID bulbs?
- Problem with VFAD (HELP!!)
- Help
- need help to find out where some connectors should get plugged
- Taglight issue
- HELP! car cutting out!
- CEL+3beeps
- Flat battery overnight
- tcs and abs on.....
- Car stumbles around 6k
- New Engine and New Clutch at 40k Miles (Repost from General Discussion)
- Exhaust System Help Please!!
- Climate effect performance???
- Road Noise from Back End
- Stall Problems
- Steering wheel Mode button won't loop cycle through all the functions anymore
- Flooded after it run out of battery
- Flooding with TSB upgrades?
- Need infos about the electronic systems
- I have a question about feed,Auto Exec,Re-Amemiya headers.
- New gearbox oil = notchy 1st and 2nd
- Car turns when under hard braking??
- 4th Time Horn Fuse has Blown!
- Quick Question: Trunk Problem
- Car won't start. Help!
- Rattle / Buzzing Sound From Under Car
- Could this be the oil pressure sensor?
- Clutch/ transmission check...
- AT bounces when shifting and loud engine...
- Troubles with emission testing
- poof goes the clutch...
- Is your 8 running good or like crap?
- Need Help with my OEM iPod Module
- RX-8 Problems!!!!
- Annoying Noise - Technical help
- Clutch Pedal Squuk/creek??
- Burned my coils this weekend- question for the rx 8 gurus
- Agency Power Pulley Problem
- Power Steering failure - I know its been covered...
- Sparks Changed - Battery Dead
- Gas Mileage and hard idle
- Popping noise from front left suspension during low speed quick transition
- CEL with Agency Power Exhaust
- RP shifter problem
- Light on Dash
- Passenger Air Bag
- F&*k&*g Radio!!!
- 50,000 mile bumper to Bumper Warranty
- AC/Heat is the the correct Bulletin
- HELP my car is dying... ignition issues
- Lol, New member of the RX-8 club, and the failed Power steering club!
- My freakin 8
- Car won't start..
- Mazda Special Program MSP13
- No Boost Or Power
- Burning oil smell . . . MOP?
- Flashing CEL(Engine Light) at High RPM's
- Dealer Certification woes
- different marble issue.
- Car won't start unless jumped
- MP3 player has hijacked my cd
- Need Help!!
- Power Loss
- low engine temp
- clutch jammed
- Not starting before the 3rd-4th crank
- P2096
- New owner needs advice
- I think i messud up my car, HELP
- Car Shakes when Clutch is released.
- Key Programming Conflict Problem
- Stuck in Neutral
- How to identify engine down on power?
- Tranny problem.
- My first CEL
- Jump Start or Trickle Charge?
- Just Had Clutch Replaced...Now it feels weird...
- Strange sounds after cold weather start
- New TSB for the Broken Sun Visor
- the seat belt is jammed, it's out of a wreck
- need help car won't start
- Brap!! Brap!!! Brap!!!
- Weird grinding....
- RX-8 AT Redlining While in Automatic
- Help !Coils wont get power! Checked Coils ALL coils ok...confused..!!
- Stalling
- Strange crackling noise
- Weird noise.
- Is my After Market Exhaust coming loose?
- Engine oil
- Steering Rack Problem For Rx8
- RX8 hissing sound when accelerating
- Saga of Bad Cat and Mazda's inaction
- CEL if catalytic converter fails?
- Hot engine on highway?
- So, what do ya'll think?
- Pinging?
- A/C comes on at start
- cel gas leak
- CD player doesnt play track 4
- cylinder 2 misfire...what?
- Idle at 4k RPM?????
- oil in the intake
- shifting 1st into 2nd
- Clutch pedal came off.
- RX7 RX8 Same clutch?
- Trunk Liner issue
- Pop when braking as well as left turns.
- Barely starts and rough idle
- I need help ASAP.
- "Buck"
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
