View Full Version : Trouble Shooting
Pages : 1 2 3 [4] 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. My RX-8 is nothing but problems!?!?!?!
  2. Rubaway Dashboard :(
  3. Gas gauge enters reverse?
  4. footwell lights ground?
  5. Issues with the 05 and 06 RX-8s
  6. Switchblade style key fob - dead battery?
  7. PCM on its way to Cali/Any info on time length?
  8. Car is dead, blown fuse?
  9. electronics go haywire - anyone else?
  10. shifting for MPGs.
  11. If flooded/change the engine oil!
  12. Should I buy RX-8 or not?
  13. Idle problem - Dies from electrical draw
  14. throttle before shutting engine off EVERY time?
  15. Pcm Sebt To Cali/returned Same Problems
  16. No start - not even cranking
  17. 3 Oil Questions - But not the Typical ones
  18. My Cruise Control dont work
  19. Deflooding the Cypriot way
  20. Cel Is On...ttok It To Autozone And I Got No Readings From Programers? Help
  21. Tire issues
  22. Two Major issues with my RX8
  23. Need Some Help/pinging/loss Of Pwr
  24. shifting advice pleas
  25. Mazda Sucks (Dealer Service Experience)
  26. Another Problem
  27. Negative caster on left front
  28. Another Auto Transmission Problem
  29. I have a 05, but 04 problem still bothers me
  30. Flashing TPMS light
  31. Brake squeeling problem
  32. Alarm shock sensor
  33. help with scanalyser
  34. Cel
  35. Starting problems
  36. 2005 RX8 problem
  37. first oil change
  38. No more CEL (Actual good news related to a CEL)
  39. Won't Start Coming out of storage
  40. Bringing the car in - very big power loss
  41. Second Gear Hesitation
  42. Big Problem
  43. Just bought my 8, couple of probs
  44. Strange Electronics/AC Problem
  45. Oil Cooler Fan
  46. Tanny scraping
  47. TSB work performed ONLY if the car is under warranty?
  48. oil in hose from air filter to the throttle body.
  49. RE: Oil Changes
  50. Had windshield replaced, now RX_8 won't start
  51. A Wierd loss of power...
  52. Windshield chipped? FREE repair
  53. New 2005 rx8 - Few Problems
  54. CEL on Again Even After Flash
  55. Help, bumper washers not working ??!!
  56. clutch problem (not a problem according to Mazda)
  57. Speed Limit
  58. Noise From Front Left side
  59. Compression Test Check This Out!
  60. Strange Sound While Accelerating Hard - Automatic Transmission
  61. New Engine I think?? Please advise
  62. Question from thailand....
  63. Odometer replaced - reset to 0 miles problem
  64. Crush Washers for Oil Changes
  65. ECU Reset
  66. Throttle Loss Cel Came On
  67. Pre or post delivery Inspection.
  68. any AT owners that can help me?
  69. Headlight Washers came loose
  70. SPLIT BROKEN DRIVERSIDE VISORS. driver side visor
  71. auto leveling malfunction
  72. Exhaust Backfire?
  73. dealer forgot ot replace dipstick!
  74. Need your input on 3 problems
  75. Dealership Botched Airbag Replacement
  76. Rear speaker cover rattle driving me MAD!!!
  77. Rough Idle/Stalling
  78. dealing with transmission fluid replacement
  79. So I'm Not a big fan of the Mazda Dealer
  80. Different kind of gas-related problem
  81. This time I found a wretched rattle! Lets kill it!
  82. Warranty Issue - or not?
  83. Power Loss Solved
  84. Plugs Went Bad in 2 Weeks - Why?
  85. Oil Pressure Running High
  86. Lost my power steering this time
  87. a different 2nd gear question
  88. Losing Power HELP!!!!
  89. Turbo Idle w A/C
  90. High speed brake shudder, and stuck pads and rotors?
  91. Ghost in the EPS?
  92. knocking in second gear at 5200 rpm
  93. Help Me!1 First time rotary owner!!
  94. Suspension Question
  95. LEDs caused ABS and TCS failiures
  96. Possible remedy for brake squeal issue.
  97. Keys won't turn?!?!
  98. frayed belt...
  99. Anyone else feel...paranoid?
  100. Ticking, clicking from the rear at slow speeds.
  101. This is what my Spark Plugs look like...
  102. Battery or Alternator problem?
  103. oil level too high?
  104. Steering Question
  105. 2006 A/C Issues
  106. Flooded- DIY or take to dealer?
  107. NEW Rx-8 owner please help
  108. Help me with my WOT mixture
  109. Another CEL with limp mode !!!!!!!!!!
  110. Severed Injector Trick...But still CEL.
  111. Hub Centric Rings???
  112. The sliding quarter
  113. Wds Code Problems
  114. Broken AC Tempature Knob
  115. Problems with emissions testing
  116. My first problem with the 8
  117. Is this normal?
  118. E-Brake Light w/ Turbo
  119. Different A/C problem
  120. Extra console felt pad part
  121. help! my power steering went out
  122. latest Recall
  123. Dead Spot Encountered
  124. intake needs replaced due to carbon deposits $3200.00
  125. Electric Power Loss Perpahs?
  126. Vibration at cold startup
  127. 12 MPG!!! Help!!!
  128. tranny issues ver 2.0
  129. Check Engine Light For No Reason?
  130. Engine Fan Not Shutting Off
  131. strange rattling noise
  132. Took the car to Mazda
  133. 2004 M/T Dynamic Damper Heat Shield Replacement Recall
  134. A/C Amplifier Question
  135. What is the longevity of the 2004 RX-8?
  136. Loud click on shutting down
  137. Something loose underneath?
  138. HELP!!Effect on Engine due to Gas Kit explosion
  139. Congealing Oil
  140. steering problem. help!
  141. Bad power loss
  142. problems with the 8
  143. Help...hood Refuses To Open
  144. E-Brake Light/Electrical problems?
  145. periodic powerloss help!
  146. Need Help - Clutch Problem???
  147. Car has power, but nothing works
  148. Clutch squeal when hot
  149. A/C condenser screen service bulletin
  150. Loss Of Pwr/pinging/rough Idle/stalling..finally I Got Them To Replace The Engine!
  151. Brake Squeal TSB Rev. 2
  152. Broken Cupholder Door/Button?
  153. slipping???
  154. New Cat, Same Problems. HELP!
  155. Diff. and Tranny fluids
  156. Small-town Stranded and My 8 Won't Start
  157. Sputtering low rpms....
  158. Temperature / Thermostat Issues
  159. using high octane or not? is it necessary?
  160. Immobilizer issue?
  161. Problem with radio and cd
  162. rumble from 4500 RPM and up
  163. Loss of electrical power
  164. new description of an old noise,whistle,squeal,chirp
  165. Waring light: Headlight auto level and squeaky clutch pedal
  166. Trunk Light Dead Battery
  167. Car died on me today...
  168. exhaust smells bad. is this normal??
  169. Wierd Full Sweep of Gauge Needles?
  170. help!......strange squeak noise
  171. Ticking noise from lower passenger side?
  172. Loss of power and PS
  173. Strange noise and power loss
  174. Running midpipe w/o O2 sensor
  175. oil blowby/turbo 8
  176. Rosenthal Maszda did not show this one
  177. 1st Gear issue
  178. brake noise
  179. Temp of cooled air at the vent when AC is on
  180. is she being ripping her off?!
  181. Constant Clicking grr....
  182. Warning Lights/All ON
  183. Rattle under glove compartment
  184. compression test
  185. Engine stalls under load
  186. Blinking Cel
  187. Strange Starting Issues
  188. Steering Shaft Torque Sensor Issue
  189. Lost power steering on the highway at 65mph
  190. Faulty Fuel Gauge?
  191. Corrosion issues with oil coolers and lines
  192. 2 Questions about Auto Trans Fluid
  193. Got a Question!
  194. clicking front brake
  195. FED UP with the issues my 8 is having...
  196. Steering Clicking
  197. RPM surges when clutch is engaged but car is in neutral.
  198. Clutch Clicking
  199. IAT Sensor
  200. Spare Tire Removal Problems
  201. rattling in both doors
  202. Engine stalls under load
  203. Flooded Road -> Flooded Engine
  204. DS Drive Shaft Boot Leaking
  205. Warranty for AB light?
  206. Help Needed - Novice Suspension Warranty Question
  207. Help! Quick response appreciated!
  208. clutch vibration??!!
  209. Crazy Warning Lights @ Autocross
  210. Anyone have trouble finding Reverse?
  211. Anyone ever get a blinking CEL?
  212. car doesn't turn on
  213. A/C on cool air blowing then blasted with HOT AIR...HELP!!!
  214. piuuu....psst ... from aircon
  215. Problem with car Starting
  216. Temperature Knob Question
  217. pressure oil gauge low and low oil light!!! weird
  218. Does 8 stall in winter?
  219. Mounting changed but... "gluk ...gluk..."
  220. Squeaking when cold
  221. New '06 Rx8.. less than a month old... scraping sound!!
  222. Should I take it in?
  223. breaking up
  224. Clutch Does Not Engage? Help
  225. Coolant Leaks
  226. A/C Screatch
  227. Possible Overheating???
  228. Why won't my car start?!?
  229. More Strange Issues, This Time Electrical related.
  230. Flashing CEL when the engine is OFF
  231. Mazda's Powertrain Warranty Extension Plan
  232. Dead Battery Saga Continues
  233. this can't be normal *clutch related*
  234. TSB Warranty Costs
  235. Anyone read about the new TSB recall..........
  236. Car won't start-- EPS light on
  237. Hard start with cel Help!!!!
  238. misfire on cylinder 2
  239. An answer to “should I drive my RX8 in the winter?”
  240. Recall notices arrived today.
  241. N, R, S Flash explanations
  242. RX-8 4206F Recall: Completed - Feedback
  243. Dying Car Problem Help!
  244. High beam failure
  245. "Continuing" engine light problems, anyone?
  246. New Owner Rough Idle ?
  247. Engine Replacement/Now Transmission Problems
  248. paying for TSB's??
  249. Cruise Control fluctuates
  250. Recall work - slightly OT please help
