View Full Version : Trouble Shooting
- My 2004 rx8 computer is down
- My lights won't shut off
- Not Starting Flooded Bad
- Preventative Measures
- More Than Just a flooded Rx8
- Keyless Remote
- Another Non Starter... Not looking good :(
- Pin the E-shaft sensor for the noob.
- Strange Power Loss
- P2096 Recurring Check Engine Light after Fill up/Car Wash -- Troubleshooting help
- wont start after shut off
- coolant leak and no idle
- Spark plug question from a noob
- 2004 won't start even after warm-up
- Changing a light bulb
- Engine dies when coming to a complete stop after spirited running
- Compression test results
- Warm start issues with a twist. Need advice please!!!
- Rx8 p2096 again !!
- Help with Rebuild - what can I get away with not replacing
- help please
- motor turns and turns won't fire over
- intermittent CEL
- 1st gear reverse still grinding after new clutch install
- No ignition on front rotor
- Hot restart= ABS and Traction lights
- Rx8 stalled at lights never started again?
- alternator?
- Engine burning off oil too quickly?
- clutch problems?
- Strange Flutter noise
- Misfire CEL, BHR Ignition, some troubleshooting already done...
- Couple of issues with the 8 and need some help.
- You know where this goes?
- Keys?
- Need help with head unit
- RX8 Tractor!
- Help! Please!
- Front Rotor Misfire
- Compression Ratings
- CD player
- Help Please (Clutch Blown)
- Power Loss, V-tec sound when acceleratin above 6k. In much need of help.
- Help =/
- rat ate the rx8....
- 2004 RX-8 Won't Turn Over
- A/C is kinda weird
- HELP! transmission problem HELP!
- 2004 rx8 car stalls when hot in stop and go
- This piece looks broken...what is it?
- Knocking sound coming from rear over bumps
- The Saga Continues... Several codes now....
- Thermostat O-Ring Question
- Window noise....Sorry I posted in DIY first
- Engine will die when the clutch pedal is pressed
- Front wheel lugs getting loose?
- rx8 intake purge valve broken
- maybe one of you can diagnose this noise?
- Huge oil leak !!
- Won't start - very weird electrics
- is this a possible clutch pedal problem?
- Hot starting problem
- Starts fine, but trouble re-starting
- engine stalls when revving
- Fix for engine stall after battery disconnect
- (help) fire sparks came from the exhaust then engine shut off
- Arggghhhh, I need help getting parts
- Stuck Throttle Body valve after de-flooding procedure
- Help Clutch and LEAK!!!!
- Water in trunk/taillights (resolved?)
- Power Steering Electronic Control Module
- Another Steering Issue?
- Weird Noise in cold weather
- Coolant light (not the standard problem)
- Diagnostic Codes
- Cel
- Sluggish Start/No Power
- Small annoying problem
- Started then died within 5 seconds.
- Electrical problem, alternator or bad battery?
- DSC comes on
- Heater problem, AC too
- Electrical Problem Heater, A/C, Defrosters, Temp Display Out!
- Help ( o2 censor maybe?)
- Clutch Issues
- 2006 RX8 rough idle
- Tan Grease in the oil
- stalling when rev
- Fuel pump maybe??
- extremely weird electrical power issue!
- HELP! Reving Idle in Park (2005 RX8)
- Brake grinding noises on application
- Total stupidity- I ran my rx-8 out of oil now it runs like crap
- Turbo'ed 8 won't rev past 8000
- Won't start after replacing the Upper Intake Manifold
- Could it be a broken hose??? Help
- Newly cutted fob blade is not cranking the engine
- 2005 rx8 hard start
- Problem with engine starting, as well as abrupt shutoff when turned off..
- Multiple Issues!
- MS CAI to stock intake-Help
- cel went on.. help
- rx8 wont start
- Milky dip stick(i know its been asked before)
- Rough idle, popping/sputtering exhaust, sounds and feels off...
- Misfire in cylinder 2
- Starting Issues: Some like it hot, some like it cold.
- Misfire code P0301
- idle rough, tries to stall after o2 sensor change
- Replacing Radiator Fan assembly
- Help 04 rx8 wont start!!!
- Bad misfire only when cold
- Need Help with My 8
- PREMIX High RPM bog/grind - (not your average "help me" thread)
- strange fluid in my air filter
- p0171 that wont go away help!!!!!
- Weird startups
- CEL with no codes?
- RX8 wont start
- Need some opinions, grinding sound in my 8.
- Acceleration Issue
- Air bag light 5 flash pause 1 flash O.o
- Car drove fine now wont start
- Complex Problem Starting, then Overheating Exhaust
- variation of metra problem
- Car wont turn on
- Possible Hydrolocked RX-8? PLZ HELP!
- AT Brake pedal and MT Brake Pedal compatability
- Power Steering Failure help.
- Pulling P2004 code - APV stuck open
- Wont accelerate when WOT
- 2005 RX-8 Starting issue and air pump issue.
- Little too much oil. Can I remove some?
- Bad day = no more motor
- Car Wont Start- Please Help
- Lots of codes after flooding. Starting jitters when cold
- Doesn't want to hot start..?
- fitting on Thermostat housing leak?
- Over bumps, Nearlly ALL warning lights on dash illuminate
- Coolant going empty every couple days
- No power, won't rev.
- Red Fluid on Calipers
- Drl
- Gasoline smell in cabin
- Lots of issues
- Speakers going bad ??
- Back Of Steering Wheel Broke
- electrical issues, cd player,
- what did YOU pay for programming keys and/or ABS at the dealer?
- About the EVAP test
- Engin Light on after replacing ignition coils on 2004 Mazda RX8
- Gear changing issues
- Voltage Issue: Alternator, battery, PCM, or wiring going bad?
- Power steering problem...
- Heater stopped working
- start problem
- Rx 8 alarm
- 4 CEL codes, looking for help
- P0420, o2 sensor, & gas choices o.O
- Drifting the RX8...issues?
- Oil pooling btwn intake runners
- Slave cylinder grease questions, clutch squeak
- HEEEELP P0171 code
- Weird chattering sound at idle?
- loud squeak on first start after 2 day sof not running and very very cold conditions
- Clutch engages smother now???
- Stumped with ABS/TSC doesn't stay on
- Frustrated New Member
- Blown Engine Warranty Issues
- Help
- Emergency alarm won't shut off!! 04 RX-8
- Something Fallen Off Car?!?
- Stereo issues
- Clutch problems!!!! Help
- !!Please Help --- Car won't crank after flywheel/clutch install
- clutch problems! help!! please!
- clutch problems? (vid included)
- 05 Auto, weird issue at 3rd gear, need change auto tranny fluid?
- Faulty headlight washers
- stalling when on split journey..
- Leftover cat debris in exhaust
- Quick exhaust question
- What's my next move?
- Gauge and Power Issues
- Compression Test Intrepretation Help Please
- DSC, ABS & Cruise shut off when headlights are turned on.
- Rev up to 8k.. then severe loss of power, and warning light. Several other issues too
- My misfire story
- anyone know of a rotary specialist in LA?
- smoke at high rpms
- Trying to figure out what is going on
- 2007 Electric Steering making a noise
- Rx-8 not starting
- I need to change my motor mounts. I heard they have Polyurethane ones?
- my '04 is not starting (need help asap)
- Multiple CELs. 301/125/171
- Low Compression??
- Misfire above 6.5k when I put my foot in it.
- Car idled until fuel gone, battery dead....
- SSV CEL after oil change?
- easy on the flames... please
- Clanking/Clicking sound upon acceleration, codes P0076 and P2259
- my04 rx8, Weird rattlesound?
- Capping the VFAD valve
- Yes another P0171 thread
- PCM. CEL No Code. No Power.
- Motor mounts question?
- help 04 rx8 not starting socal
- Oil Problem (or not?)
- New RX8 owner
- new engine ?
- Center console sliding clips replacement
- P0139
- What is wrong with my car (slow but not low compression?)
- Spark plug seized! oh no!
- CD Player/RCA Input not working
- "cylinder" 2 misfire
- power?
- Ticking sound when accelerating about 4000rpm
- P0410 and struts? help(I researched but couldn't find answer)
- Oil pressure drops
- DIY urethane motor mounts question
- Check engine light
- Car stalls
- car stops in reverse gear
- Car losing power
- induction kit problem
- Running rough after it gets warm? Coils?
- Trouble shooting stereo
- injectors
- bearing noise and not from transmission
- stainless steel brake line leaking.
- New engine and mystical misfire
- Metallic rattle when going into gear and vibrations at idle
- Dead LED on Remote Key
- 2004 RX-8 pulls left upon accel., right upon decel
- Can any one recommend RX8 mechanic in Hampshire?
- Finish rebuild,car starts, car revs, but wont hold idle.
- warm A/C issue.
- Help stranded near grand canyon car died
- New Cat Glowing, Misfires And Rough Ide Acceleration
- ok odd misfire can't quite figure it out
- Mazda fuel pump assembly
- Engine and Cigarettle Lighter?
- K&n aintake help
- Passenger side window/ lock not working
- Grinding in Power Steering
- Strange Problem -- At least to me
- Someone please help!
