View Full Version : Trouble Shooting
Pages : 1 2 [3] 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Got my recalls done and asked the tech a few questions
  2. I think I broke my radio :-( and LED :-(
  3. Transmission Tail Shaft Seal
  4. What type of motor oil do you use ?
  5. marbles marbles
  6. Hp gains from ecu reflash?
  7. Sudden Power (Electrical) Loss
  8. Recall Question
  9. RP Short Shifter leak???
  10. Confused! Recall Done But No Re-flash.
  11. New Engine Owners - Any Improvement?
  12. all lights are on and power steering doesn't work
  13. rx8 can't use synthetic oil
  14. MyNew/Used RX-8
  15. Performance reduction after switching from premium to regular gas?
  16. Can someone actually ANSWER this please?
  17. Clutch weakness
  18. Clutch broken? Car will not shift while engine running
  19. rear view mirror - vibration
  20. Time to say Goodbye to the 8
  21. A/C Condenser hole
  22. How often AC cycles?
  23. Should I take my 8 back?
  24. STARTER WILL NOT GO IN AFTER NEW ACT CLUTCH & FLYWHEEL
  25. New K&N Intake questions....
  26. Heat/Fuel tank recall and rear drivetrain question
  27. Foglight Out
  28. misfires.
  29. Close to Accident
  30. NEED HELP FAST intake problem
  31. CAT Replacement
  32. Poll: calling all engine replacements AT or MT?
  33. Suspension Vibration
  34. Big problem I Have gone through 2 quarts of oil in 3 weeks.
  35. Problems
  36. Recurring flashing DSC light
  37. Rotors
  38. Blue clutch is normal!!!
  39. High Oil and Gas Consumption and Rough Idle
  40. Power loss
  41. Quick question
  42. Question about tranny oil
  43. Welding for BOV
  44. 1 month old RX8 running good,what r these ECU reflashes?R N M??what r they do i need?
  45. Slight sqeal when gas is initially applied
  46. Exhaust Manifold Bolts
  47. Race gas? octane boost? good for car? bad??
  48. Water Dripping From Transmission
  49. Check engine light flasshed 3 or 4 times after gunning it?????
  50. Greddy Type R BOV
  51. Greddy Type R BOV
  52. damage to tranny?
  53. flashing CEL and a lil power decrease
  54. Just got the new flash and its running terrible.
  55. Is there a way to revert to older flashes?
  56. Another "Rough Idle"
  57. Mazda Customer survey
  58. Low antifreeze light???
  59. Pre-Detonation or "Pinking"
  60. Strong gas smell????
  61. Headlight level adjust
  62. my engine blew today
  63. how to avoid misfires?
  64. Whats the story with turning off the DSC?more mpg?hold for 5 secs??
  65. funky smell.
  66. SR High Flow Cat melting O2 sensor
  67. weird noise!
  68. First gear stumble
  69. Leak from back up light switch - recall related?
  70. Reflex Ram Mapping Kw++ ?
  71. quick idle question
  72. New (to me) noise(s) and behavior-Thoughts?
  73. Rattles in the steering column driving me crazy!!!
  74. Rattle Noise Like Diesel On Acceleration - Dealer Says Air Pump
  75. Greedy has fix for "R" Flash !!!!!!!!
  76. Check Engine Light came up
  77. Stuck between gears?
  78. *venting* #@$#@ car wont start
  79. Blown Engine
  80. Problem: Oil leaking from block
  81. Electrical Problems!
  82. K&N Filter Causing the CEL ?
  83. throwing codes like crazy
  84. 2,000 miles - CEL - Bucking @ 4,000rpm & 6,000rpm - No Power
  85. to those with transmission problems...........
  86. Damaged Rims
  87. Fluctuating Cruise control @120km/hr
  88. Sticking window up button
  89. anyone know the brace structure in the rear doors?
  90. Headlight pattern
  91. CEL = Car is choking like hell
  92. Strange Sound From Under The Console
  93. Is heat an issue?
  94. Midpipe problems please help me
  95. Passenger window - clicking
  96. Condensation INSIDE cockpit
  97. GReddy Turbo Problem
  98. Rear squeak on curbs, smal bumps
  99. Smoking after flooding
  100. Weirdness, Power Came back !
  101. Bad gas or ground problem from gas pump? Now rough idle
  102. NAV won't properly accept addresses
  103. Just checking again....slight whistle at beginning of accel then disappears.
  104. Jusr did a oil change, but how many quarts do i need.
  105. Problem/solution I had
  106. Waiting on the tow
  107. Whining/whistle noise from interior
  108. rx8 head unit skipping all the sudden on clean CDrs???
  109. question for clutch
  110. Engine Pings at High RPM's
  111. Evening Interior Light Failure after Install
  112. Another Cel Thread
  113. For the guys who have blew an engine
  114. Car won't start
  115. I need some help
  116. Rear dash rattle/tapping driving me nuts, help please!
  117. Little Lug Nut problem
  118. Too much oil causing CEL
  119. Front grille cracking
  120. Question for all those with bad mpg..
  121. Mildew smell from AC
  122. Down shift grind
  123. 100 Miles And Another Cel!!!!!!!
  124. Car alarm problems
  125. another weird noise
  126. How embarassing, I flooded!
  127. Bass Feedback w/ Turbo Timer
  128. TPMS question
  129. Anyone with starter problems?? Possible recall?
  130. Rear glass rattle/tapping problem....solved, hopefully
  131. need help. rough idle
  132. Electrical problems - please I need advice
  133. Rant + Flooding Issue + Warrenty work
  134. Blown Motor
  135. Fogged/Clouded headlamps - Where's the TSB?
  136. ice on inner front window
  137. flooding, airleak, moisture in tail light
  138. throttle body cleaning??
  139. Cel
  140. wouldnt start
  141. eManage problem
  142. What octane gas do you use ?
  143. Broken Center Console... (NOT the lid)!
  144. Window Ice
  145. wiper broke! help!
  146. Rattle noises coming from L/F mirror
  147. How to turn on DSC light
  148. Battery keeps dying
  149. Flooded Again(7th time)
  150. RANT: Flooded.. for the frist time
  151. Overpriced OEM Underbrace?
  152. gas Pedal sticking
  153. what's up with the heater?
  154. Gas
  155. Pressure Plate Failing @ 18k mi
  156. will auto-start screw up the igination system?
  157. Tire rubbing/shudder in front??
  158. Alternate Flood Start procedure
  159. My seat is finally quiet and solid again.
  160. A/C or heat always on
  161. Hesitation with throttle.
  162. F'n POS won't start
  163. Fuel Consumption Increase after Recall 3305G service
  164. dynamic stability: safety for everyone or for lead feet?
  165. "break in" rules followed by dealership?
  166. 6 speed problem. Felt like something hit me from the back.
  167. Up & Down RPMS at Idle + Check Engine Light
  168. CEL and 40k miles
  169. I love my 8 but xmas flooding sux
  170. SSV stuck open.....code P2070.
  171. Flooding when its over 40 degrees?
  172. A "Don't Flood This Car!" Placard (for valet, etc.)
  173. break-in period
  174. need help
  175. problem with MAF sensor
  176. oil over half full but keeps lighting up.
  177. Service woes
  178. defi oil pressure gauge
  179. throttle position sensor
  180. throttle position senser
  181. my rx8 is running lean i think please help
  182. headlights problem
  183. Ran out of gas, added more :: Car won't start?
  184. 5W30 or 10W30?
  185. handing over the keys with fear of engine flooding
  186. Flooding
  187. air fuel mixture
  188. Is there any bad effect to the fuel system??
  189. greddy turbo vs t4 turbo
  190. Engine light flashed at around 7000RPM
  191. handbrake inside cover cracked!
  192. Broken or stuck thermostat?
  193. Power problem thats a little different
  194. Engine in running rich...
  195. Cold Engine Starting Procedures
  196. Help me figure out what the heck the dealership did to my car!
  197. transmission replacement
  198. Power loss. Help
  199. Noise in Engine: Dealer said replace to replace Comp or Engine
  200. Spark Knock
  201. Passenger seatback rattle anyone?
  202. sound coming intakemanifold
  203. Transmission delay from park/neutral to drive.
  204. greddy turbo
  205. a big bang noise...
  206. Why does my exhaust smell bitter-sweet
  207. 3K RPM for 10 sec?
  208. Transmission 3-4 upshift grind. Just EXPLODED! Lost my calf.
  209. It wont start
  210. We'll It Finally Happenned!
  211. Lots of transmission noise when stopped, 5th like a wall, reverse lashing.
  212. Power Loss: Blame it on the mouse?
  213. Im away on a road trip - CELs, Power-Loss, etc
  214. A/C switch problem
  215. different kind of brake prob
  216. Bleeding brakes - rear hubs still spinning?!?!?
  217. Half-flooded engine?
  218. Battery issues
  219. knocking noise
  220. shifting check engine light problem
  221. Help! Weird rev issues
  222. Smelly Clutch
  223. Intake problems
  224. Oil Soaked Air Filter
  225. Cold temps, Engine light issues
  226. Rusting Rotors
  227. Bad Cat at 8000 miles?
  228. Sounded like valve clatter
  229. No power steering after replacing the engine
  230. Best guess as to abnormally low MPG
  231. HELP!! power steering/dsc and traction light are on!!
  232. Common RX-8 problems?
  233. anyone havin alarm problems????
  234. Weird Noise...louder with intake
  235. third brake light blinks
  236. noise from right rear after shutdown...
  237. Weird Electrical "Problem"
  238. i joined the blown trans crew today!
  239. Possible clutch replacement
  240. NEW 8! 2 things, are these normal ?
  241. Thermostats vs. MPG
  242. RX-8 Engine problems
  243. didn't expect THIS much oil consumption.
  244. HELP with clear side markers!!!!
  245. alighnment issue kinda
  246. help!!
  247. Help!! Pinging, Loss of power, Rough idle
  248. Motor Mount Issues Around 30k
  249. Need Help - Got An Oil Change...
  250. Starting Problems....again
