View Full Version : Trouble Shooting
- Thermostat gasket leaking?
- Long Start and Acceleration Stutter
- window loose
- Trouble starting my RX8
- Engine start problem
- Hot start failure, long crank times
- Stressed out, easy problem.. need fixed. lol
- Mazda rx8 acting up
- 07 rx8 rough idle, loss of power @ higher RPM, eng sounds rough
- Check Engine P2259 Confusion
- Security Indicator Light /wont start
- Could malfuctioning SSV create chatter noise??
- Grinding from Engine
- lurching in first/reverse (MT) from neutral
- Help! My 07' RX8 wont start!?!?
- Coolant boiling out the rad cap!
- Traction control/abs light, only when driving/head lights are on.
- Removing exhaust flange
- wont go past 6500 rpms and super loud
- Clutch problems
- Very Picky Heating
- Broken Differential.
- Loud clicking noise
- Got some questions about swapping parts..
- Transmission trouble...sticking in 6th gear
- rx8 wont rev past 3k rpms
- Grinding noise
- 2005 MT Rx-8 won't turn over -- Key FOB Issue?
- 2004 Clutch Slipping/Smelling - Suggestions
- Overheating?
- Fuel pump question need help
- Please help! Rx8 smoking and barely running!
- Cel P0610
- Coil, CEL and Random Stopping issues
- Strange Power Steering Issue
- 2004 no heat
- Car sitting about 1" low on Right Rear
- The start of an epic journey
- Rx8 engine (under the hood) is smoking
- engine sounds like a lawn mower?
- Bose speaker does not work on driver side door
- Problem with oil pressure
- Car hesitates to start and losing power
- Please, Please help!! just searched for 3 hours and nothing....
- New Bearings?
- Wont turn Over..New Engine & ECU..HELP
- Few Issues...not sure where to start first?
- Power steering
- Rx8 wont start?
- Crazy grounding wire?
- RX8 LED Install (Warning Lights-ABS Warning Light/TCS/DSC Indicator/No Cruise Contr)
- Please help! CEL issues/power issues
- Check engine light
- engine vibration at idle
- Hot Smell and Radiator light
- Marbles in a can sound only during engine braking?
- Is it all over? :'(
- Trying to figure out my coolant problem.
- think clutch is gone, but not sure
- post-BHR Ignition Kit RPM Drop
- Fire cracker burning smell
- Installed a new clutch and car wont start?
- Rx8 won't start by clutch all of a sudden!
- Spring or Shock...or Both?
- Fluid Everywhere
- Possible compression issue? HELP!!
- hard start hot + smelly exhaust, compression numbers
- 2005 rx8 smoking
- Possible Flooding?
- Seafoam and now I have P0335 and P0107 codes
- New with OMP problem
- Grind when setting off
- Bad Clutch Line?
- Heater Core
- Spark plug wire question
- Thud from Gearbox
- One side COLD, Other side HOT !
- Limp mode after changing OMP
- Starting trouble please help!
- Driver's Side Lock
- New owner please help.
- Heat Problem
- No Crank, No Start, Good Battery, New Relays
- Something really wrong with my rx8, please help
- random misfires
- Code 2096 (system too lean right bank)
- Clutch Master Cylinder Leak Inside Car
- Help please! Code c1306
- Transmission fluid in radiator water
- Strange noise, sounds like its got an induction kit fitted but hasn't
- car stalls whenever
- Rolling start to bring flooded engine to life?
- Eml was on, but now odd starting behaviour
- no power steering :(
- Idle vibration, and engine reving
- A/C isn't working?
- Rx8 stalls but not consistantly???
- Correlation...
- Metallic whirring/rubbing sound
- rx8 no start might be flooded
- Engine Choice
- Engine vibration at idle
- Can't put car in any gear when car's turned on...
- Anyone know the part # for...
- F. Chugging, Hesitation, No power.
- Black 8 down! Need Help!
- Need some help / advise
- mazda corp. not helping
- Need some serious help with my 8!!!
- Fresh installs but now car won't turn over
- need help from an experienced rx8 owner! rattling noise while accelerating
- clutch failure today?
- engine code P0411
- Immediate Help Needed!!!
- Serious loss of power, please help!
- Will bad ignition coils cause a CEL Code?
- Engine Knocking - Please help
- Throttle Body Tube Oil Leak
- Car dies when turn electrical load on
- Car wont start?
- Help! I need to know what a rabbit chewed off in my car
- Fuel Pump not getting power
- rx8 with failsafe mode active
- Misfiring once engine reaches normal running temperature
- new parts and now not running right...
- Car wont start after installing new battery
- Rear Windshield Rattle
- Crank position sensor
- weird clutch feel mazda said it was ok
- CEL Question
- steering locked up WTF!!!
- No center console power at ALL.
- Navigation swap?
- Fault mainly in 4th, video included
- Heater won't blow warm unless temp knob is turned to cold side.
- Dead Catalytic Converter Please Help!
- Steering wheel mind of its own???!!!!!!!
- Alright a challenging won't start issue
- Transmission/Clutch Issue after Starting!!
- AT Stalling issue HELP!
- Won't Crank
- Hot start problem - but only in the winter
- Oil coming out with water
- Alarm randomly going off?
- Hard braking needed
- R/H side Engine Mount
- Bad tank of gas?
- What is wrong with my RX8??
- Awful sound combined with tapping
- '04 Won't Start...replaced the battery, still nothing....
- P0336 and Air pump problem
- Climate control fix = No radio use? what gives?
- Power Steering will NOT Turn on Cold start
- power steering sensor
- Helpp :( Bad MPG, CEL, and Brake problemss
- More second gear issues.
- Can someone please tell me what exhaust this is?
- Electrical issue (dies)- any help is appreciated.
- Inside Light Flickering
- P2070
- Car gets stuck on gears and engine sputters!!
- Long crank times
- RX8 won't start after insurance got a hold of it
- Start issues and car dying after start
- Three mechanical issues I need help with
- know what this is?
- Car dying when engine warm and idle and wont start back up
- Need help with HID fogs and fog rewire
- Windshield wipers speed?
- Power Steering Problem
- Rattle / pilot bearing?
- Car won't start (replaced starter)
- 2007 RX8 Coughing Up Start w/ Video
- RX8 Abnormal Clutch Sound w/ Video
- need help asap cannot reverse
- Rx 8 in the Philippines need help!
- having issues starting my 8
- Power Steering and Mazda canada response
- why doesnt it fit?
- Bumper Bracket Missing? Help Please **Pics Posted**
- Engine mount nut
- Engine died while driving, now car won't start at all
- Please help? Low top speed
- Something gone wrong after oil change
- passenger side drl not working?
- Car rolls back in forth while in gear
- steering problem electrical or mechanical?
- My rx8 shat itself
- Strange/Worrisome Behavior From My RX8
- P0301 Engine light
- 1-2 shift difficulty
- 2009 Strut question
- reaccuring p2096
- Seals blown?
- Fuel pump or ignition problem possibly?
- need help with clutch issues
- Oil light remaining on for no apparent reason
- HID kit
- Car bogs and stalls.
- Major electrical issue after battery disconnected and starter changed
- RX8 Bottoming out over bumps
- APV motor
- Suspension alteration with auto-leveling light
- Rattle
- RX was running shut it off Now it wont start?
- Code P506
- o2 sensor plug melted
- White smoke from hood
- inconsistent idle after engine install
- Flooding/Compression Issue?
- Help wiring the Fuel injectors back up.
- Fuel Pump ring what happens when you use screw driver and hammer with anger
- New coils, wires, spark plugs and second hand fuel pump P0352, P0351 :scratchhe
- Cat issues?
- Blowing Bulb
- Tansmission went clunk...
- Smoke Under the hood
- M/T Starter ground wire question
- Strange clicking noise when riding over bumps
- Car slow to turn over after starting and the stop and go
- 85k miles, 2005 MY compression check failed
- Map light LED's
- Some interesting facts for us RX8 Owners
- sick of this POS car
- Looking for A LOT of Help 2004 (im in Miami)
- How to prevent flooding?
- Exhaust leak-Greddy SP2
- My Rx8 is White Smoking...
- no spark.
- Gaz trap problem
- engine high pressure problem
- Can Someone Please Help Me With My P0113 and P2070 code!!!
- big problem (can't reach redline)
- Bright red exhaust around the sensor and to the tailpipe
- My Rx8 Takes to long to start!!
- clutch pedal bracket install issue
- side marker light off and now hid headlight shutting off??
- 13mpg average. plugs? O2 sensors?
- not burning enough oil?
- Delayed Acceleration (0172, 2096, 0302, glowing cat)
- trouble code P2057
- Engine sounds like it is going to explode above 5000 RPM
- Were does the starter ground to in the engine block
- Engine Issue
- Possible compression issues
- BHR Ignition Wires and Check Engine Light
- ABS and TRACTION after re-start
- Misfire story.
- how to check CEL at home?
- RX-8 wont start / interior not working
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
