PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 [28] 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Trouble with Starting
  2. LED issues, anyone else experience this?
  3. Squeaks, ticks, and rubber flaps, oh my!
  4. CA Fail smog Rp supercat
  5. Door Check Loose
  6. HVAC problems
  7. Catch Can install question
  8. Do I need a new engine?
  9. Starting Issue please help!!
  10. failed emmisions due to check engine light
  11. is this possible!?!
  12. Hot Start Issue
  13. Not the usual headlight haze problem
  14. Melted plastic on headlight help?
  15. Instrument panel doesnt change color
  16. HELP WITH TAIL LIGHT LED's!
  17. Starting problem
  18. Occasional light *thump* when turning... rotors?
  19. need help!!!!!!
  20. A/C Non-existant
  21. Accessport in Conjuction with Emanage Ultimate
  22. Turn key to start, get "click"
  23. Battery Problems
  24. Car is POSESSED! Guages flicker with no key in ignition!
  25. Repeated Check Engine Lights
  26. Sputtering at high RPMs
  27. clutch problems 2006 rx8 6spd
  28. headlight problem
  29. car dies when put in reverse
  30. air pump failure linked to power steering failure?
  31. Grinding noise i reverse
  32. Cluster gauges going crazy.
  33. mods with CA smog
  34. Engine dies while on highway
  35. Random Turning?
  36. Need to find oil cooler
  37. Gas Leak
  38. Strange clutch noise
  39. Oil Question...Please Read!
  40. Remote entry doesn't work
  41. Traction Control Randomly Turning On
  42. Help.. Scared =(
  43. Car wouldn't start - Had to reprogram control modules
  44. battery light on
  45. Got a mind boggler for you tech types...
  46. side marker bulb wont light up.
  47. secondary air injection system issues
  48. MazdaSpeed Exhaust doesn't Line up, Flickering interior Lights when on Battery Power
  49. *****Having problems with transmission*****HELP
  50. Exhaust/sound problem
  51. water level sensor or air in the system?
  52. AC leak....
  53. Problem with hard starts
  54. Sticky question
  55. Fogs out
  56. guys I need help...
  57. Vibration at stop light and clicking sound in engine
  58. stalling in motion
  59. P2096 (cel)
  60. Clutch easier to engage...
  61. Sigh =/ starting problems
  62. "Marbles in Blender" issue.. PLEASE HELP!!!
  63. P0335 Eccentric shaft position sensor circuit problem - Car will not idle
  64. Check Engine Light - 35xxx Miles
  65. 2004 RX8 Has no oil compression..Help?
  66. Clutch and Transmission issues
  67. smell of gas??
  68. No sound from radio or cd
  69. Computer issue
  70. Flooded, then Engine Light On?
  71. Greddy turbo problems
  72. Warranty Coverage on Coils, wires, and plugs
  73. Oil leak and strange ignition issue
  74. Intermittent miss at idle - Normal?
  75. Split radiator
  76. Is this a rotor housing crack?
  77. Help!!! 06 GT, low beam HID's will not level out
  78. Fuel in oil pan causing smoke
  79. Engine shut off at a stop light...
  80. passenger side power window
  81. help stallin rx8
  82. Oil Pressure Meter...Normal?
  83. taking out of storage, new battary, engine light flashing..no start!Help!
  84. Sounds like someone is playing pinball in my rotary
  85. Hard start
  86. Ignition Coils not the issue...?
  87. Burning fluid/grease smell in interior?
  88. Can i transfer my tpms from my stock 16 inch to a set of stock 18 inch
  89. Can i transfer my tpms from 16inch to 18 inch stock????
  90. Penny in the gear box......
  91. car jerks really hard and sometimes just looses all power
  92. Stupid Tow Company! Engine Question
  93. MAF plug wires too tight?
  94. Strange issue...
  95. optima red top
  96. Wouldn't get into to gear, now its fine
  97. wheel hopping
  98. Intermittent squeaky noise coming from underneath the car after HKS exhaust installed
  99. Car running like sh@t
  100. changing fog lights, radio dosnt work, car wont start.
  101. Quick question regarding cat....
  102. Power steering thread
  103. P0037, P0031, P2010?? help please!
  104. Maybe someone can help me out please
  105. K&n intake !!!!!!!!!!!!!help!!!!!!!!!!!!1
  106. Clutch slipping in high rpms rarely
  107. Idle problem!!! Helpppp
  108. seat warmer
  109. front shocks - fluid leak??? I thought they were gas?
  110. Tire Presure Monitor Sys Malfunction
  111. how to remove tail light tint???
  112. Idle seek ONLY when in gear and clutch in...
  113. rough idling and loss of power
  114. Old article on what type of oil to use
  115. squealing bely
  116. How many radiator hoses does an RX8 have?
  117. Loss of Power at High Revs, accompanied with high pitched noise.
  118. trunk lid button not working
  119. Compression Issues?
  120. Helllllppp!!!!
  121. Rough idle for 15 seconds, runs great?
  122. Name That Sound + Identify that object!
  123. Odd Sound driving me crazy and getting louder
  124. Please help! My 8 wont start!
  125. resetting fuel trims
  126. Any ideas?
  127. Coolant issue
  128. Banging from underneath the pedals
  129. Stuttering problem, new car, need help
  130. Cell after seafoam.
  131. Power loss/Knock/Rough Idle - Any help greatly appreciated!
  132. Vibration again what is it this time HELP!!
  133. Changing headlight bulbs
  134. No information display
  135. back fires on cold start
  136. Car isnt turning on right away??
  137. My new rx8 is difficult to start after winter storage
  138. Power loss
  139. Oil at the bottom of the car but not leaking
  140. car dies when coming to idle
  141. Help: CEL on & other small issues
  142. Help please; CEL and a couple other issues =/
  143. Clicking/ticking under hood
  144. turbo lag
  145. No power when I hit the gas!
  146. Whining
  147. DSC / Traction Control Activating on Slow Turns
  148. DTC P0076 : Intake Valve Control Solenoid Circuit Low Bank 1
  149. Car hesitates, lose of power at 4k-6k RPM
  150. Brake Locking Problem
  151. Can I mix coolant?
  152. 2004 Hard Start Question
  153. Tire(d) Dilemma
  154. Brand new battery -- Car won't start. Help.
  155. Wheel/Rim/Axle/idk problem.
  156. Flexable Brake Line Removal
  157. Battery Drain
  158. dirty air filter
  159. Mazda Building Me a New Car ???
  160. My 8 won't go above 3000 rpms
  161. Help what have i done car will no longer idle.
  162. Chirping air sound when on the gas
  163. Starting Problem
  164. Lucas Upper Cylinder lubricant?
  165. problem car wont start possible flood but....
  166. RX8 paddle shift problem
  167. Car wont crank over
  168. front tire rub
  169. Easy technical question need answer
  170. Engine code P1688
  171. flooded, new spark plugs still wont start
  172. ASWI-JACK steering wheel INT
  173. wont start/turns over HARD
  174. Coolant leak
  175. Airpressure in transmission - Normal?
  176. Radiator light problem
  177. DSC light on during accelerating?
  178. Front Air Dam Need Help Quick
  179. Power Steering Rack failure?
  180. Fixed everything but this !!!!!
  181. Need help with OBD2 read outs
  182. battery charging problem
  183. Air Pump?
  184. fog lights
  185. Engine light steady/hard start
  186. Loss of Performance below 4500 RPM???
  187. not happy with my 8
  188. Month 5 @ the dealership & it will be fixed
  189. Minor Accident, any HELP would be appreciated
  190. CEL on for Air Intake Sensor
  191. Question About Cat Replacement
  192. My first CEL what could it be???? Oh and other problems
  193. Squeaky Brakes!
  194. Car Not Starting / Really Hard Start - Help!
  195. transmission or clutch?????????????
  196. pulled this code (p2098)
  197. Another new oil leak...
  198. 2nd,4th,6th gear noise
  199. ABS, Traction, and E-Brake light issues
  200. RX-8 ECU Failure ?
  201. What happens? New ENgine?
  202. Engine Rebuild
  203. No power anything..
  204. !@#$#@$ Rx-8 Engine, wtf
  205. brake screws
  206. starting & low rev problems?
  207. What Gaskets are covered with the engine replacement ?
  208. Problems
  209. Door Lock problems
  210. Rx8 Wont Start, just clicks
  211. Engine stops when deccelerating
  212. Car stalling/ not getting enough power like before/engine light coming
  213. damaged cat
  214. Low compression :(
  215. stalling?
  216. S1 Problem Tracking
  217. Jumping car and alarm keeps going off
  218. Warm Start trouble please help.
  219. questions about problems
  220. engine replaced and now CEL on
  221. Oil in the Intake + Hard Start + Misfires
  222. Hopeful New RX-8 Owner: What to look out for?
  223. RX8 Leaking gas from the gas tank
  224. Strange sound.....sounds like boiling or bubbling
  225. car turns over but shuts back off
  226. O2 Sensor Failure: Front or Rear?
  227. Flooded RX8 apparently issues with dealer
  228. Steering issues
  229. Water leak around the clutch
  230. Rough idle - misfire
  231. E-brake coming on during high RPMS?
  232. How do you change sat/nav/tv from Jap to English?
  233. Heeeeelllllpppppp
  234. Please please help me
  235. first engine problems
  236. turbocharged RX-8 HELP !
  237. flashing cel possible solution?
  238. butt warmer issue
  239. horns stopped beeping when locking doors
  240. Weird Ass Problem With Tiptronic Tranny
  241. Engine failure
  242. Went on a 3 day vacation, came home....car won't start
  243. Insight on a worn bearing sound?
  244. Car Died on Highway Help.
  245. Problem with start
  246. Random squeak/squeal, narrowed down to belts? Maybe?
  247. whacko idle during warm-up
  248. PRoblem with start
  249. Engine replacement question...
  250. Have to leave rx8 for a month...help with possible problems
