PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Disappearing 2nd Gear Grind
  2. changed my clutch but?????
  3. AP dual res midpipe fart cannon sound! Is this normal?
  4. Secondary air injection code?
  5. Few vibrations
  6. Power Steering Light
  7. oil metering pump
  8. car shakes/rattle when first in gear?
  9. Moonroof leaks anybody have this problem before?
  10. Thoughts plz: broken clutch pics
  11. Help me diagnose a start issue
  12. Wont Maintain Speed.
  13. Key stuck in ignition
  14. looking into buying a rx8, some questions after test drive
  15. Noob needs some help
  16. Rattling Sound on high RPM OH..OOOH?
  17. Idle snapping sound
  18. HELP ME!!! Transmission!!
  19. bad radiator cap? or worse?
  20. Loud sound when moving off first gear
  21. check engine light fuse!
  22. 6 cd only loads one?
  23. Suspension?
  24. Rear CAT Bolt snapped, options?
  25. Starting Issue - Electrical ?
  26. Whine in Reverse
  27. Gutless?!?!?
  28. Transmission acts sluggish after long drives
  29. Dash light meanings
  30. Mutiple engine codes!?!?!?
  31. Rear defroster inop. Help?
  32. Power plant frame reinstall issues?!?!?!
  33. Ignition Coil Readings
  34. Got AC working.....only kinda
  35. AEM CAI= Stuttering at 4 and 7K. HELP!!
  36. Bad Cat / Bad Leading o2 Sensor - P0410?
  37. Dealership made my car catch on fire. NOOOOO
  38. Help with oversized rims/tires!!!!!
  39. Replaced AC Condenser....but...help
  40. Clutch Pedal Issue
  41. enigine stumbles at idle
  42. Wierd Vibration after Car has been driven
  43. No power above 7k and dies at Idle sometimes
  44. Website to check what TSBs
  45. Body Shop flooded my car, now won't hold idle. Any ideas?
  46. 06 transmission issues
  47. 2nd gear grind (my dealership battle)
  48. Hazards Don't Flash -- Keyless entry
  49. Power window failure!?
  50. Coolant warning
  51. Hesitation accelerating from idle
  52. RPM issue while accelerating
  53. Did nothing, Wont Idle, and Leaked coolant
  54. Tire pressure monitoring system light is on (TPMS) HELP!
  55. PLEASE HELP car not shifting right
  56. sputtering between 2-5k rpm, low compression?
  57. 2006 Shinka Key light on IP
  58. Original battery croaks
  59. car wont start :(
  60. AC-Radio not working
  61. Is my transmission gone or just needs service
  62. Transmission locked me out last night, today its making noises?
  63. Fuse problem
  64. Flashing Engine Cel
  65. Identify this nipple! Suck or Blow?
  66. Compression testing with engine out of car
  67. Stalling, Idle Hunt, No power, I am stumped
  68. looking for some help
  69. Changing coils
  70. Strange sound
  71. ran oil dry while driving
  72. Coolant leaking everywhere!!
  73. hard to go into reverse
  74. ABS Light comes on
  75. My Triangles are broken.... : '(
  76. Turbo install - massive oil leak on oil sandwich plate
  77. Car died while driving
  78. more problems...
  79. Broken OMP line
  80. Can you help me?
  81. P2102 - Throttle Actuator Control Motor Circuit Low?
  82. P0031 and P0032 codes
  83. 05 nothing works!! dash wont even light up. Need help.
  84. New rims = dsc,brake, and traction light?
  85. Lights Issue
  86. car just died on the road
  87. Engine problems
  88. overheating trouble! need help
  89. Gargling issues
  90. Major engine trouble
  91. Car feels like its dragging something....
  92. exhaust fumes in cockpit
  93. Nav system battery draw
  94. white smoke no cel?? anyone help PLEASE
  95. P0120 Error Code
  96. Hard to shift into 2nd at high RPM
  97. Even mazda is stumped!
  98. My Hornnnnnnnnnnnnnn ?
  99. Sensor Problem?
  100. Noise shifting from 1st to 2nd only
  101. Engine help please
  102. Credit card key issue
  103. opinions needed
  104. Signs of a dying Catalyic converter?
  105. power loss, wont go above 5k when in gear
  106. Altenator light comes on when ove 3500 rpms
  107. Poor starting when warm
  108. Rx-8 popping noise
  109. help - broken exhaust spring bolt
  110. exhaust fumes
  111. Clunking Noise after Exhaust Install
  112. 2004 2-3 shift in automatic
  113. Helppp!!
  114. Failed Cat?
  115. Compression Loss/Need New Engine?
  116. Nitrous Backfire,Now car wont start!
  117. DOA? Help?
  118. stiff/rough steering and grinding/rubbing noise
  119. 04 tranny problem
  120. Shes dead!
  121. ok so my cat is bad buying going to buy a new one....
  122. Vibration above 50mph
  123. Car doesnt start back up after turned off
  124. Noise In Idle
  125. Rough after warmup
  126. Oil leak (Backup light switch)
  127. What does "limp-mode" feel like?
  128. Removing OEM Ballast
  129. Do I Have A Problem? Dyno Chart included
  130. A Video of MY Display Dash Problem, Please Help!
  131. Types of motor failures and related symptoms
  132. Forgive newbie clutch question
  133. I think i have an electrical gremlin
  134. My car is dead .Stealership giving me the run around
  135. Turbo setup..to much compression?
  136. car won't go/shift into gear when on, help needed
  137. New battery now DSC light on?
  138. Ugh Car wont start, possibly flooded.
  139. Ugh...dealer says motor is likely going
  140. Warm air from coldest vent setting
  141. Door handle broke
  142. Intermittent Power Loss, MIAC, and Oil in the Intake
  143. weird idle
  144. Running Rich?
  145. Fire!!! underneath the car
  146. Intake sucks oil at high speeds.
  147. When to change gear and revving.....
  148. 04 Auto rx8 is giving me problems need help
  149. Idle help please....
  150. plastic gaurd in front?
  151. I love this model (looks) but!!!!
  152. Why is my smart key stupid?
  153. radiator light comes on.. a lot
  154. Midpipe Issue?
  155. CEL came and dissapeared
  156. Non-linear throttle response
  157. Bleeding and non returning pedal
  158. My RX8 Engine Management light & Wont start 1st time???
  159. engine problems with cold air intake
  160. Clutch problems
  161. Whats wrong with my engine?
  162. After warm up RPM drops and dies?
  163. CEL+smell of gas+backfiring
  164. Failing CAT???? Need opinions even after searching!
  165. catalyst system below threshold but no cat
  166. growling?
  167. Just found out my CAT is bad....
  168. Dsc/tcs dtc c1937
  169. Faulty Broken A/C Heater Mode Control Lights
  170. Bhp
  171. Very rough start.
  172. No power, low rpms and hard(ish) to start?
  173. omg! screw fell into fuel tank
  174. I need opinoins on these codes
  175. Major problems after Cat failure
  176. Trouble starting
  177. Horn broken watch for Finger!!!
  178. Is this normal?
  179. Check engine light flashing
  180. taking a trip....is my 8 car safe?....
  181. CEL for catalyst system
  182. Why won't my car start
  183. Cleaning out CAT
  184. RX8 Wll Only Push Starts...
  185. Threw Another Code P2070
  186. radio not working
  187. Throwout bearing making noise...
  188. Enigne, Clutch, or Transmission Issue???
  189. Engine Problems
  190. Problems with new motor.
  191. How To Clean Throttle Body and MAF
  192. Help- recurrent engine warning light
  193. Clutch Pedal Stays Depressed
  194. Firm brake pedal when at idle?
  195. starting problem
  196. TSB question about brakes
  197. Power steering squeak - sound sample
  198. Smoke from under the bonet
  199. Headlight leveling light & headlights pointed at ground
  200. Frustrated with CEL—What am I Missing?
  201. Evap Leak (LARGE)
  202. Racing Beat Duel Resonated Midpipe Issue
  203. Car shuts off while driving...
  204. Steering problem after engine start.
  205. Is anyone else having this problem?
  206. Remote Entry, driver door
  207. new cold air intake casues 25% rich fuel through the exhaust
  208. Cel p0411?
  209. shutter valve
  210. Failed RX8
  211. Greddy Turbo kit, now car wont start
  212. 2009 RX8 Oil Over Consumption WTF?
  213. I don't know what this part/accessory is called
  214. On the brink of needing a new engine??
  215. huge vibrations
  216. Low vacuum, low compression, bad MPG
  217. Has my cat gone and a few questions?
  218. Tire sensor going on at night?
  219. 2008 RX-8 Rattling noise
  220. Another Clunking Sound....Please Help
  221. C1165 - Right Rear Wheel Speed Sensor Input Circuit Failure
  222. oil leak or should i say oil flow....
  223. Need advice 2004 rx8 GTE 6spd Tranny issues!!!
  224. please help- car isnt turning over
  225. help car issue with high rpm
  226. Problems with wheel hub replacement
  227. Starting problem after refueling
  228. Guys I need help!! Transmission issues!!
  229. Fuel issue?
  230. Wiring Heated Seats...What do these wires do??
  231. Throuble with Beeper alarm RX8 2004
  232. is this bad a window motor or something else?
  233. Mazda Dealer overfill the oil in my car
  234. Clutch Slave Cylinder Dead?
  235. turn signals problem
  236. loud bang sound?
  237. 6 speed engine lag at 7500?
  238. Another coolant leak thread but a little unusual
  239. Series of Problems - Probably engine related
  240. Installed my leather seats but now we have problems =( please help
  241. Please tell me I'm wrong
  242. spudder at and idle?
  243. Mazda Can't Figure it out, To much voltage
  244. 2005 rx-8
  245. clutch bracket/pedal and mazda dealership issues
  246. is clutch noise normal?
  247. Fuel pickup problem on the track
  248. Clutch Bleeding Issues
  249. Gas mileage
  250. Question of a Odd Part
