PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 [25] 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Soft Clutch Pedal Upon Start-up and More...
  2. abs and traction light wont go off!!!!
  3. What happened?
  4. speed. wobble
  5. ACT clutch problems
  6. New pads and rotos..front bads rubbing on rotor while driving
  7. car won't start after setting...
  8. starter is ticking, car won't start
  9. Weird starting sound plz help!!!
  10. New Engine...Dealer Messed Up WTF!
  11. Low Oil Pressure
  12. what happens at 4500 rpm ?
  13. RX8 wont beep anymore?????
  14. Just to confirm whether its a dead cat
  15. DTC P1687 Help
  16. Weird Whirr after accident
  17. Battery Not holding charge
  18. "Wrong' Radiator OK to Use?
  19. Help please! clutch problem
  20. Help - Battery, Alternator, Starter, Fuse?
  21. Help - Clucth pedal goes to the floor and stays there?
  22. Program the remote on 2004 RX8
  23. Tire Pressure
  24. Front Tires Slip a Bit
  25. 04 RX8 MT - clogged cat w/o reason (dealer issue)
  26. Cranks awhile before starting when hot.
  27. New radiator and fans pulsing
  28. Coil Question
  29. Just deflooded now car stays at 3000k! what's wrong?
  30. De-Carb and Warranty
  31. Engine is misfiring
  32. Overfilled with Oil
  33. Starter "Stutter" - intermittent - VIDEOS
  34. engine vibration at high rpms
  35. tpms sync/reset
  36. Black Foam Hanging under engine compartment
  37. 40K '05 with Oil + Coolant + Tranny Issues
  38. Flooded or battery prob?
  39. Battery terminal REConnet, PLZ help??
  40. let me tell you about my day....
  41. Yet another power loss issue...
  42. brake problems
  43. 2005 Sways at High Speed when hitting bumps or ueveven road surfaces
  44. Rear passenger side door stuck
  45. How to search for parasitic draw
  46. clutch cable
  47. Loss of Power, rough idle, SSV issue?
  48. About Those Fuses...
  49. Need help big time...!
  50. !Check engine light - P0506!
  51. Aftermarket gas cap?
  52. Repair, Wiring, etc.. manuals
  53. Couple of Quick questions from a new RX8 Owner
  54. Reset the CEL help
  55. burnt smell
  56. stage 3 act clutch problems ?
  57. Too heavy? O.o
  58. P0455 Check Engine Light
  59. Issues with Turning Right / Steering
  60. stereo help
  61. partial electrical systems failure, engine not starting but door ajar light working
  62. Intermittent loss of AC + surging/fading
  63. Persistently dead
  64. Wheel Lip Damage
  65. Check engine light problems?
  66. What kind bulbs do I need for xenon low beam?
  67. Fuel line issue?
  68. Oil Leak issue
  69. Heavy steering at low speeds
  70. HELP! engine stuck at idle after flooding
  71. New suspension parts Noise Hunt (pictures inside)
  72. AC dye question
  73. Help please!!!
  74. rough pulling out
  75. Trouble with Crank-angle Sensor
  76. Questions/Concerns about New Engine
  77. worn belt
  78. Rough if not premixed
  79. 2006 Oil Filler Neck Mod on a 2004?
  80. Weird windshield fogging problem
  81. Fuel Pump Malfunctioning?
  82. Ran a Puddle and my RX stalled.
  83. drama's with engine light!
  84. BHR Ignition Coil Install Issue
  85. Oil leak at front bumper
  86. How do I receive my CEL codes
  87. How to solve the no spare tire issue?
  88. Brakes change gone completely wrong :O
  89. Seat Problem(s)
  90. Pedal positioning sensor
  91. funky smell
  92. electronic display problems
  93. Power loss and untable idling..
  94. window rattling sound on drivers side
  95. Dead Raido
  96. Oil in my airfilter
  97. if catalytic converter dead
  98. problem after problem
  99. Help please!
  100. car dying after driving 30+ miles...
  101. car dying after driving 30+ miles...
  102. does anyone understand this?
  103. Axxess Aswc
  104. Another motor yet again... I need advice tho pls
  105. Cleaning cloth interior
  106. Rough Low RPM Acceleration
  107. intermittent weird engine noise and rough idle
  108. Getting a new engine block
  109. weird vibration on idle
  110. Blinking DSC light
  111. Strange low rpm acceleration--ideas?
  112. Rattling/Loss of power/Stall
  113. TPMS/ABS/ebrake/traction light all pop on
  114. Rx 8 won't start, help!!!!!
  115. New intake= check engine light please advise
  116. rx8 will not start (electrical problem)
  117. Awful rattle coming from chassis/engine??
  118. Ignition Fuse Blowing
  119. What is considered 'Loss of power'?
  120. Clunking Shock - Diagnosing the Problem
  121. Topping off refrigerant for the AC
  122. Have ABS DCS/TCS issues with lights staying on?
  123. gasket size
  124. Rubbing noise coming from rear end
  125. Auto tranny jump
  126. new owner moderate problems
  127. Help??
  128. **HELP**completely stumped
  129. Two issues I'm dealing with...
  130. Keyless Controle Module
  131. how do i get rid of the cel light with no cat
  132. hoping I just need a wheel alignment?!
  133. New Engine?
  134. Rotary Engine Turn Over Time
  135. engine stalling
  136. Another loss of power, stall, won't start cycle...already replaced plugs and coils
  137. Dead space at the beginning of throttle pedal travel
  138. clutch
  139. High idle with clutch pedal out, normal idle when clutch pedal pushed in.
  140. Excessive Cabin Heat
  141. Starter issues/Questions
  142. starter + Flooding
  143. Kittyyy Wants To Get Her Wheel Locks Off
  144. Check Engine light + Engine Smoke
  145. Radiator light keeps coming on. Sensor problem or not?
  146. ac not working..need help
  147. Need some help!
  148. Will not drive past 70mph
  149. Warning Lights Ago-go
  150. Screeching noise
  151. Ebrake light doesn't turn off?
  152. P0103 - At my wits end..
  153. Scraping at slow speeds
  154. Car does not turn over
  155. Does he really know what he is doing?
  156. Help please!! Loss of power when normal running temp reached
  157. Need Expert Help A to Z
  158. Should 5w-30 be used instead?
  159. "AT" Light Came On - WTF is that?
  160. Pls help , mazda rx8 has finished me
  161. rx8 engine hesitation at stop
  162. Another Idling Problem
  163. Car is smoking and i dont know what is wrong
  164. rx 8 door handle
  165. Ecu replacement
  166. Broken Clutch Pedal?
  167. Electrical problem? car shorts out? idk
  168. Help! 46K and first problem ever!!
  169. cai= cough
  170. Noise/Loss of Power?
  171. Misfire at idle
  172. P0300
  173. Help power steering
  174. sparck plugs and wires?
  175. New motor installed... Wont start
  176. Clicking while backing up.
  177. I think i've got problems... Please help
  178. Clutch problem
  179. More on Starting Flooded RX8
  180. Clutch doesn't come up all the way after pushed down.
  181. Rattling in reverse
  182. HELP!!! engine flooded
  183. Will i pass the compression test?
  184. Need Some Input
  185. Considering Purchasing an RX8 but i hada few questions for you vets about it....
  186. Replaced Brakes now Fluid Reservoir is Overfilled and Spilled Over
  187. My first rotary, seems a bit jerky and unstabile
  188. Air Intake Installed - CEL Gained... HELP
  189. running rich
  190. windshield fogging up
  191. Hesitation
  192. Pull under Acceleration
  193. Stalling at idle
  194. linking error
  195. Radio cutting out and resetting while ABS/traction activates... ?
  196. Emissions
  197. CEL on - OBD code P0410
  198. Helppp pleasee! Asapp
  199. oil problems
  200. Engine warning light
  201. Check Engine Light P2259
  202. RX8 dead?
  203. Stalling / Cooling? Issue in RX-8
  204. brake then check oil light
  205. A/C Issue: Driver side vents hot while pass. side is cool?
  206. Vibration from 55mph onwards.
  207. Ground Kit Recomendations
  208. Aftermarket Radiator for '04 A/T Rx8
  209. engine issue
  210. Proving / Confirming Oil Control Ring failure
  211. Car still pulling right after alignment
  212. Hunting Idle, does not want to idle, very difficult start
  213. Misfire code and burnt rubber smell?
  214. No Clue???? Need help!!!!! Lots
  215. Paid 10k for my bike, I guess
  216. just had engine replaced and it's misfiring on cold start??
  217. Big smokey blue cloud
  218. P0661
  219. AC knob problems
  220. Heated Seats dont work.??
  221. RX8 Driven Through Flooded Street-- Won't Start~~~ HELP!!!
  222. Newbie Needs Help; Engine Shaking
  223. Pilot Bearing removal - Big issue
  224. Hot Start Problem
  225. Water leaking from under glove compartment?
  226. 2 parts electronical and audio
  227. all speakers not working
  228. Stalls at idle, but starts up right away
  229. Sluggish Acceleration...Warranty?
  230. Lazy Start - Stealership Woes
  231. Completely Confused!!
  232. Power Steering problems - Water Damage. Please help
  233. I'm a moron
  234. headlight ballast
  235. Quick help with p0661 and p2259
  236. Struggling
  237. How Do You Get Silver Piece Out of Fog Light
  238. ac fan control problem
  239. Phantom Coolant light
  240. torque specs
  241. please, i don't know what it is but need your help
  242. ABNORMAL popping from exhaust
  243. Rattling/vibrating sound coming from car
  244. Check Engine Light after jumping a dead battery
  245. Does Your Engine Hesitate at 7500rpm?
  246. Coolant label issues
  247. Door Handle Damage
  248. battery died & car wont respond to remote, key, none of interior control works
  249. Clutch Pedal Bracket Installation
  250. fog lights not working!!
