PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 [24] 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. One More Hard Start Problem: With Video
  2. problem with rattling at 5000rpm to 6000rpm
  3. Squeaking, clutch? or shift linkage?
  4. A little help...
  5. I need to know whats this sign mean please?
  6. 04 rx8 dyno problem/somethings wrong
  7. HELP! Engine cuts out
  8. My 8 keeps shuting off
  9. Urgent Help Needed: 2005 Mazda RX8 won't go into gear!
  10. Help with a Starting issue ( video)
  11. Need help with a DTC 037 CEL
  12. car stalling after fitment of racing beat duct!! help
  13. Car smokes?????
  14. Engine limited to 2K RPM
  15. CIL P0302 & P0171 - Smoke in Cabin (Please HELP if you can)
  16. Power steering issue
  17. Very Frustrating :(
  18. steering tug
  19. Vacuum lines go where?
  20. Two Problems...One Big, One Annoying
  21. A/C Compressor Ticking Noise Help!
  22. Runs worse the hotter it gets
  23. my car keeps stalling
  24. Any Suggestions? My baby is hurt.
  25. Engine too loud?
  26. Need help with Ram Air Duct
  27. ABS / DSC light on and no Cruise control PLEASE HELP!
  28. Replacemen Rubber Gromet in door handle 2007 rx8
  29. Help!!!!!!
  30. no syncro for 4th gear?
  31. bubble in my oil???
  32. Starting Problems Even AFTER Upgraded Starter...
  33. OBD Engine read... rough idle. Need thoughts
  34. RB oil adapter with OEM filter issues?
  35. Belt squeal or worse?
  36. Car wouldn't start
  37. inconstant idle in gear
  38. weird noise
  39. Tightening play in turn signal lever?
  40. help me identify this problem please!!!!!!!!! with video
  41. Squeaky Clutch
  42. Steering vibration when turning
  43. idle dipping
  44. wierd issue
  45. steering wheel off centre
  46. Engine Limp Mode with CEL, no stored codes
  47. open door senser
  48. car wont idle after cleaning throttle body???
  49. Just installed BHR ignition kit
  50. CEL....wow
  51. Dead battery. Again.
  52. disable alarm???
  53. Loose Shifter?
  54. Remote (Wireless portion) not working
  55. Power Loss after engine heats up
  56. CEL plus hard starting and rough idle
  57. Engine stalls when cold and at stop signs please help
  58. jumpin and jerkin
  59. AC and Heating Problems and faulty switch?
  60. Possible brake sound from back wheel?
  61. shifting issues
  62. CEL - Cat efficiency
  63. Decarb Question
  64. loss of power and stalling
  65. OMG! Have a LOOK at my ECU
  66. engine light is on!!!
  67. Rattling from rear left + loss of pickup/power
  68. whats this noise?
  69. 2005 RX8 stalling issues
  70. misfire code after installing AP pulley
  71. Possible Flooded Engine
  72. Water in fuel
  73. clutch bleed problem!!! help
  74. RX-8 running hot and shutting off
  75. Clutch pedal or slave cylinder?
  76. Is it time for a new motor???
  77. Squeaky Brakes
  78. Throttle Body Behavior
  79. Short Term Fuel Trims
  80. Its dying on me!!!!!!!
  81. Car wont start (Out of town and desparate)
  82. Dies intermittinley while driving???
  83. Constant A/C
  84. weirdness after slide/spin
  85. Moisture in the headlights
  86. Wierd Noise
  87. Unsettling intake noise (AEM)
  88. DAMMM!!! my car die for the on me !! please help rx8 brother
  89. Squeeky Clutch Bracket and Flexing
  90. Car wouldnt start...please help
  91. symptoms & problems solved by ignitino coil replacement
  92. jerky shifts. engine mounts?
  93. passenger power window stopped working
  94. Smoke....
  95. window problem
  96. Shimmy/Jostling noise when turning sometimes
  97. Shimmy/Jostling noise when turning sometimes
  98. "Static"-like sound at specific RPM
  99. Warranty after replacing engine?
  100. Water Flooding, Help?!
  101. Electonics Reset while driving
  102. She died but WHY????
  103. Left turns difficult (not EPS)
  104. rough idle when hot
  105. Ipod Integration?
  106. What Sound Does A Cracked Exhaust Manifold Make?
  107. Rx8 shaking
  108. Grinding while shifting @ high rpms?
  109. P0661 help
  110. Check Engine Light
  111. Engine Problem?
  112. Unique Rough Idle w/ Video!!!
  113. Vacuum leak?
  114. Another No-Start Thread - With Odd Video
  115. CEL/Misfire
  116. code P2010 pops up. loss of power above 7k rpms
  117. Power Steering Anomaly in Morning
  118. New alternator battery light after 60 miles
  119. thumping sound
  120. clogged cat and dead coils?
  121. Warning lights
  122. What might be causing this humming...
  123. Clutch problem(please help)
  124. Question on AEM CAI noise
  125. Flickering Head Light
  126. Help
  127. Short Ram Air caused CEL to come on
  128. Weird Electrical Problem
  129. Just pushed car into parking lot
  130. Keyless beep
  131. decat pipe
  132. Cabin fuse box
  133. Here is my issue, can anyone help.
  134. oil leak - front of case
  135. Ticking/Tapping sound from engine bay
  136. Check Engine Light On, Code 302, Turbo
  137. Low RPM issue
  138. Transmission Woes
  139. Everybody come together and help
  140. O.K. Have been searching for 4 days.
  141. Replaced 2 sets of coils AND Catalytic Converter in 3 months time?
  142. Engine Popping and Crackling
  143. smoke after replacing coils, wires, and plugs...
  144. 2004 rx8
  145. AC causes rough idling and knocking noise?
  146. Need advice!!!!!!!!!!
  147. High pitch squeak on light accel
  148. Blown Engine? I need advice
  149. purge solenoid valve
  150. rough sounding engine
  151. Car jerks when trying to accelerate
  152. ABS/Traction Control Lights and Cruise Control
  153. OEM Wheel Paint Question
  154. Key Fob Programming Issues
  155. Reinforced Front Sway Bar Brackets
  156. tranny 2nd gear problems
  157. Need some sdvise please
  158. Broken end link and noise
  159. ODD re reving problem
  160. Bad Clutch or Transmission?
  161. Need help! Issues when shifting at high rpm
  162. Clutch issues???
  163. Vacuum leak behind intake....
  164. Issues with fuel delivery
  165. Temp gauge normal but over heating
  166. DSC light after changing suspension
  167. Cut Sunvisor
  168. QUESTION: Pre-mix & 2cycle
  169. no a/c, power steering or radio.....
  170. Need some help
  171. Coolant leak
  172. WTF is this nosie
  173. Engine misfiring at cruise with pegged 11.2 AFR-- Stalled at traffic light
  174. help plz???
  175. Rear window defogger not working
  176. Front left Tire losing PSI
  177. atf leak
  178. Coolant leak and over heating
  179. Hood latch cable broken
  180. TPMS sensor
  181. 3 engine codes What do they mean?...any advice?
  182. headliner water leak
  183. Door Stuck Complaints
  184. Strange Clutch Slippage
  185. Buzzing door
  186. Rough Idle and Popping Noise from under vehicle
  187. Catalytic Converter bad??
  188. Fan keeps running
  189. 3 error codes on an 04 rx8 gt
  190. My gear shifter came apart. What do I need to reattach it?
  191. Dag nabid dealer!! Coils, Cats, huh?
  192. water in oil again.. think this is serious though!!
  193. Shutter Valve.....again?
  194. Engine Start and shut down
  195. Help!
  196. Motor mount Question
  197. mazda masters help plz
  198. help please
  199. Your free replacement will only be $1200!
  200. Misfiring-Fuel Starvation ?? Video/sound attached!
  201. need to replace coils after plugs?
  202. oem or act clutch???
  203. Check Engine Light + battery light + dead battery
  204. Help, radio sound delay
  205. ABS + Stability control light (C1290)
  206. Rx8 after defllooded fails here is a video.
  207. engine coolant warning light
  208. Rough / Hard Starting
  209. COBB AcessTuner Connect to ECU doesn't work
  210. Problem running and idling? please help
  211. Compression Test Score Help
  212. Oxyen sensor bad (I think) Does warranty cover that?
  213. PISSED! Brand new engine, coils, plugs, STILL have power loss!
  214. brake fluid dirty, recommend induction
  215. ignition fuse blowing please help
  216. Help! Strange "resonating" noise between 2000-3000rpm
  217. Transmission Help Please
  218. reassure me
  219. Clutch pedal assembly
  220. New Clutch??? HELP!!
  221. new turbo install.. oil from bov.. and smoke out of exhaust..help!!
  222. Weird Idle, W/video
  223. Rx8 after deflooded
  224. Cat problem
  225. engine replacement
  226. TCS LED ON, DSC Blinking
  227. power loss...can a year old cat already be bad?
  228. Sound when turning
  229. Fast Flashing Immobiliser - Now won't start
  230. Blue cloud of smoke with rev. Please help!!!!
  231. good news, bad news, good news??
  232. Just curious...Redline Buzzer mysteriously stopped working.
  233. Whats the best tranmission fluid?
  234. morning start up with unusual amount of smoke...
  235. overfilled oil killed my 8?
  236. Head unit won't shut off
  237. Battery goes dead at times
  238. won't start at times...
  239. DCS and ABS lights on after short drive
  240. Rough Starts - Advice please
  241. got Metra kit installed and clock is not correct
  242. '05 AT Overheating
  243. speakers!!!!!!!!!!
  244. won't start/no humming when turn key on
  245. Issues with a Rx8 2003.
  246. Engine Light on but passes diagnostics
  247. Can anyone help me with warning lights?
  248. Idle problem, what's NEXT???
  249. Door lock/alarm don't work
  250. Weirdest Clutch Problem
