PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Is it normal for 2-5 seconds of cranking for engine to start?
  2. I'm pretty sure there shouldn't be oil here
  3. engine going bonkers
  4. What does this error code mean, and what is the urgency?
  5. Pulsing brakes
  6. Clutch PEDAL keeps getting stuck on the floor
  7. Clunk and gridning/crunching under moderate braking
  8. Compression test failed, New Engine Process questions
  9. Car alarm wont turn off
  10. Car won't accelerate past 3000 rpm
  11. RX8 Radio failure
  12. 12 mpg update
  13. Clutch or Trans or what? Engine revving wildly
  14. Won't Idle or start warm
  15. Clutch + hard starting
  16. Battery troubles.
  17. All vehicle lights not working!! Help!!
  18. Coolant leak question
  19. RX-8 se apaga el motor
  20. Black ice damage
  21. resetting cel
  22. traction control
  23. p2070
  24. Sensor Issue?
  25. New Problem (HELP)
  26. GPS showing wrong location
  27. Weird CD changer problem
  28. Door sill rust
  29. White smoke
  30. Any ideas please.
  31. 2004 RX8 Problem with melting bumper
  32. clutch gone!!,weird Problem
  33. Help me. Please!!
  34. steering light on and locked wheel??
  35. activematic question
  36. Engine Overheating?
  37. Noob Questions
  38. coolant
  39. Aftermarket HID kit on Halogen car.
  40. Unflooding the enginge?
  41. Help! Car won't start
  42. Flashing CEL in cold weather
  43. Serious RX8 Issue
  44. Engine needs to be replaced...
  45. Does the Rx8 have an auto headlight On/Off?
  46. Quick clutch question
  47. Thermostat Housing
  48. Can someone help me? I have no idea. :[
  49. Shifting Issues! HELP PLEASE
  50. plz help! car wont start will crank
  51. steering - hard to turn right, turns left on its own.
  52. steering - hard to turn right, turns left on its own.
  53. Strange, Possibly Electrical Issue
  54. P0301 - can't get rid of it
  55. keyless engine start thing
  56. Not sure what's wrong with Engine :(
  57. NGK Iridium Ix Spark Plug only 6.99???
  58. Front O2 sensor bad- Can I try cleaning it first?
  59. Power Loss, Rattle and stutter from 3800-4500 rpms
  60. Car won't idle
  61. center console lightbulb
  62. RX8 Wont start
  63. Hear Stater motor whirring but no start - flooded or engine fail?
  64. A Guide to Troubleshooting Cat and Exhaust Problems
  65. Fuel pump or fuel pump relay??
  66. Electrical issue
  67. A/T Trans problems
  68. Blown Engine?
  69. Hard start and engine revving rough
  70. Squeaking noise.. Any ideas?
  71. Low Coolant Light
  72. My lights
  73. coil removal - how to remove the ignition coil harness
  74. CAI engine light and Power Loss
  75. No throttle response
  76. Problems after replacing clutch
  77. suspension problems!
  78. CD Play Blues....
  79. help alarm going crazy/lost fuse diagram
  80. Weird startup today
  81. Navigation not working need help. Please read
  82. Replacing Coils/plugs/wires
  83. Stereo & heater not working
  84. Checked my plugs out due to my misfires.
  85. Whine from UIM area
  86. Gas milage problemo?
  87. Starting rough, but quick and smooth idle?
  88. Water flowing sound?
  89. ABS and DCT shuts off
  90. headilght out, but it's not the bulb or a fuse
  91. Common signs of a misfire?
  92. trouble starting, blinking check engine light
  93. Power Steering (Really Hard to turn)
  94. NGK Wires Firing Order
  95. Power steering issue?
  96. Weird Sloshing Sound when coming to a stop
  97. 04 RX8 transmission Noise
  98. Need some info
  99. I still have the exhaust smoke :(
  100. Pinging Clinking sound under heavy acceleration
  101. Service Engine light on
  102. car chokes after consecutive turns
  103. Oil Gauge never moves
  104. Help all warning lights come on
  105. no start, maybe ecu realated?
  106. charging light comes on around 3500 rpms
  107. AT Dipstick
  108. PLZ read... wont start
  109. Catalytic Converter (fail)
  110. its snowing and my heat doesn't work...
  111. HELP Abnormal Sounds!
  112. Clip for negative battery terminal wont tighten
  113. rx8 wont start when it tries to turn makes ticking sound then loud thump from intake
  114. Rough idle after start, worse the longer it sits
  115. obd2 code p2109
  116. Help me confirm this...
  117. compression test???
  118. compression test???
  119. RX won't start
  120. Engine starting issue (cold & hot), bad mileage, loss of power
  121. Did RX7 plugs screw my RX8 engine?
  122. New car wont start
  123. New too the club :/
  124. Fuel Leak at Pump Nipple
  125. Climate Control Issue - A/C & Defrost Switches
  126. Cruise control
  127. A/C glovebox rattle
  128. Strange sound(rx8)
  129. white smoke .. lots of smoke
  130. Thumping sound coming from the engine
  131. Motor bogging.
  132. Car not run right after engine rebuild
  133. Cel p0420 p0302
  134. Fuel Consumption Increase Due to Midpipe
  135. possible locations for a vacuum leak?
  136. 2004 RX8 flooded engine - please watch my engine startup video and help me diagnose
  137. Power loss/hard starting after spark plug replacement - What's wrong?
  138. Need engine help. Won't crank but I have power
  139. traction, brake, abs light on
  140. rear side-marker lights goes out
  141. Sunroof vibrates as it opens
  142. Nexus gauges need HELP!!!!
  143. Car Wont start up..need help
  144. issues with temperature knob
  145. bad air pump?
  146. Dead battery, or dead alternator?
  147. Redline CEL light...
  148. Steering Locked Up
  149. car smelling like gas
  150. fuel starvation, misfire, or TC? @ SoW
  151. Milky Oil??
  152. steering/wiring problem
  153. Can anyone recommend me a good brand for a/c condenser?
  154. Winters here...NO HEAT
  155. Annoying Rasp - Gasket Related?
  156. High Pitched Whine
  157. Data logging. High coolant temps. Any advice?
  158. Blue Smoke out the exhaust?
  159. Running Lights
  160. A Littlle Advice Please...
  161. car vibration while in drive? any ideas
  162. Blown Engine
  163. Engine light blinking and smoke coming from engine
  164. Help anyone???
  165. Major Problem With Engine
  166. Heater control unit connected to the..
  167. Car Won't Start
  168. no radio, or interior lights?
  169. strong gas smell
  170. Griding sound WHILE in 6th gear?
  171. How can i install these side skirts??
  172. clutch bleeding problem
  173. Front tires slipping
  174. skipping and misfire.
  175. Rear fog light issue
  176. Jerky Accel/deceleration! Very very frustrated....pls HELP! : (
  177. Hard starting - suspect your starter motor ? check this out
  178. Can't compress rear break piston
  179. Power loss
  180. U0073 and incorrect airflow
  181. RX8 idle, stall, a/c issue
  182. 3k RPM IDLE, stuck check engine light no response from Gas pedal
  183. windshield stain?
  184. Clanking over bumps
  185. deflooded now engine light
  186. Rattling/ Grinding Sound
  187. I have problem with my engine
  188. Cooling fan clicking question
  189. ignition/misfire issue
  190. Worried newbie
  191. Missing Head Unit Info
  192. NEW CLUTCH IS IN but werid feeling now
  193. Difficulty Starting and Lack of Power on Bottom End
  194. manual shift mode, AT warning light
  195. Cel P0300 & P0301
  196. has anyone have this problem
  197. Had Compression Test Done, seeking opinions...
  198. loss of power @ 5K rpm!!!
  199. weird juddering
  200. weird juddering
  201. Engine RPM's fluctuating during idling, @dealer now getting compression test.
  202. hard to shift into second
  203. can it be the coils?
  204. ECM/PCM Problems In Cold Weather
  205. Brake lights won't work
  206. Troubleshooting Flow Chart
  207. Factory Alarm Issue
  208. someone help
  209. i need help!!! please!!
  210. AC issue warm on driver side cold on passengers
  211. No Gasket?
  212. Not using oil?
  213. scratching sound from my wheel
  214. high pitch whistle after removing throttle body
  215. Sludge in Radiator Overflow
  216. Urgent Gasket Question
  217. Power Door Locks Fuse - Short?
  218. Check engine warning light
  219. warranty?
  220. Car won't start (original eh?) - doesn't crank
  221. Oxygen Sensors
  222. Click Noise when starting
  223. Coldair intake does damage to coils?
  224. Keyless Entry/Smart Card Button Help!!
  225. Headlight lens cleaning
  226. Temporary engine failure?
  227. Shuddering wheels
  228. Help!!!! Clutchhh
  229. Engine turns over but no crank?
  230. air bag light
  231. Wierd Eletrical Related Problem
  232. Symptoms of a bad cat.
  233. Problem restarting while decarbing with WD40 and water
  234. My car is making huge blue clouds.
  235. Can't Start
  236. No audio. Need some advice
  237. new problem/coil question
  238. Rust ON the rear fender....deal breaker?
  239. HID issue - common problem?
  240. is this repairable and how much
  241. Uh oh... CEL P0661 and P0300 =/
  242. is it true???????
  243. need help now
  244. Oil light on 800 miles before oil change
  245. Strange, annoying issue
  246. Traction control light flashes while driving.
  247. Help p2004 code : APV?
  248. noise coming from engine?
  249. Broke Down...Help!
  250. P0126
