- General Questions on RPMs
- rx8 wont start. havent started it in 3 months
- lumpy steering - light then heavy then light again. No CEL or EPS warning
- CEL PO171 and Secondary Air Injection Malfufuction Please shead some light If you can
- starting issues
- Does she need a new engine?
- Defogging tailights
- bouncing glass noise while driving?!?!
- cant pass 120km/h
- Rear Wheel Banging Noise
- electrical diagram
- Question regarding CEL codes P0300/P0336 and my baby's MAJOR loss of power.
- Help - CEL+Other fun
- Burned Clutch?
- Loud noise after 4k, sounds like vtec:( p0300..p0302
- Does this mean I need a new radiator?
- Alarm issue
- Engine sluggish after oil change?
- URGENT!!! No Spark.....HELP!!!
- checkengine light Help!!
- catch can, but oil in air filter??
- Vibrations/Rattles in Glove Box + Rearview Mirror
- idle but no acceleration
- What is this?
- Car wont start when temp drops
- Car flooded, de-flooded it but again it doesn't start
- Fuel Injectors Stuck Open?
- Brake Caliper Slider Bolt Seized
- Condensation getting in! but where!
- Exhaust Leak?
- Random missfire
- Help with factory Sirius unit!
- P2070 - Engine Coolant - Engine Smoke
- Two Problems
- Rough start
- heater core problem
- Power Steering
- New whining noise after topping off my oil
- 2nd gear problem
- sulfur or egg smell from exhaust??
- Leak in rear light
- New reman Engine... Failed Compression ?!
- Trobules with starting the engine on
- Major problem, need help please!!!
- Dash Controls Don't work.
- Creaking in dash...
- sharp turns cause stereo to turn off
- Cat completely destroyed
- Seals of the B13 question?
- Smoke from Behind fog lamp
- Random CEL (Please Help)
- Trans leak
- Freezing temperatures caused battery to die -- changed battery but now car stalls?
- will not start. tried jumping
- lambda sensor
- Noise at higher speeds
- LED Brake light trouble
- Heater won't go off
- RX8 braking issues?
- Strange headlight issue
- car wont start. It isnt flooded.
- Smoke? problem
- One headlight dimmer than the other, need help
- Some hard starting
- noise when braking and tight turning
- E-brake giving me a hard time.
- Praise the rotary gods!
- Reduced power, More noise after highway driving
- Wiring help
- sway bar
- Weird noise aroun 4 - 5k rpm please help
- Starting/Idle Issues
- can only shift if car is moving or off.
- LSD trouble!
- stalling problem....
- front roter problom
- heater blow hot no matter what
- Car won't start, search leads to spam. ><
- Stalling issues.. or a leak
- What is this stuff?
- Engine Won't start.
- turtle slow!
- CEL P0038 No Fix and ECU issues.
- Stuck SSVs and redlining?
- What is this?
- cooling fan control circuit
- Driver Side Fender
- Wont start when the engine is hot
- dreaded CEL.......:(
- Center console lid
- Takes long time to start
- Black smoke coming from vents and hood.
- Strange rattling
- Windshield wipers and heated seats not working
- Tcs/dsc
- My Auxiliarry Fan Stays on After Engine Shut Off
- tach revved to 9k when starting
- ABS, Traction Control light
- Crossmember bolt
- Need a new clutch... What clutch should I get?
- winter issue
- Was -11 last night, car clicks but won't start (no exhaust fumes)
- in-line coolant heater
- New clutch bad chatter + more issues
- lots of vibration
- My electronis wont work! Help!!!!
- i've done alot of searching...
- valves
- Car will not start
- Alternator light and strange white gunk on battery
- help!!!p2096 post catalyst fuel trim system too lean bank 1
- p0301,,,p2096,,,p0138,,p0137 need help
- Transmission help
- CEL 2138 - APP Sensor Voltage error - No throttle control
- Exhaust burning My body kit!!!!
- HELP! wont start
- Another non starter question . . .
- E-brake light, ABS light, and traction light all on at the same time
- White smoke smells sweet
- Weird noise 4 - 5k rpm need help!!!
- wont start
- Help!! flood engine
- ABS light
- cant hold idle when starts up.
- Coolant not circulating.
- Quick question fixing handbrake
- Smoke and yellow residue?
- Check Engine Light and Engine Hesitation
- Rx8 taking a nap
- Weird CD Changer/Steering Wheel Controls/Door Lock/DSC/Traction Control Issue
- Alarm setting issue w/trunk lid
- Weird rattling sound just above idle and braking
- Does Compression Test Need New Starter
- Door Handle Broken - NOT POWER LOCK PROBLEM
- where does this wire go to?
- Flooded please help?
- strange sound
- Narrow steering
- Yet another problem to which the answer will prolly be "search"
- Premature Catalytic Converter failures
- need new engine? or is it fixable?
- DSC Problem ?
- Wife brought home my 8 with burned clutch smell.
- AEM intake problem.
- Did I kill it??
- Where does this go?
- PLEASE HELP!! Lost my only Key..How do I program new Transponder Key !????
- Will not start after 3 days of cold weather
- bouncing tachometer with flashing engine light
- Main engine wiring harness diagram
- RX8 starts only when pushed
- Cat + o2 sensor (s)
- Vibration while driving.
- New Exhaust , CEL , Bung Extension ?
- P0301 & P2096 CEL on
- highway speed issue
- lowered rev limiter?
- Car cuts power from engine.
- ’04 RX8 won’t idle after battery change.
- my roof lights dont work
- Any other RX8's start liek this when really warm ? Video
- Strange high pitch underhood buzzing at startup
- Cooling issues
- Keyless Entry Dead Key
- Help! Engine misfiring!!!
- My mazda still cuts out badly...
- Lower Control Arm Problem - Picture Attached
- 04 Remote Doesn't work...
- Radio works but CD/EX1 don't
- Repeated Cold Start Issues (yes I searched)
- noise coming from back of my 8 when applying brake between 50mph and 70mph
- Check Engine Light - Need some advice
- display
- Burnt Apex Seals ?
- help me plz
- a special case (has something to do with flooding)
- Starting problems
- jerky acceleration and VERY slow take off
- Help with DIY: No Heat? Repair the Heater Control post by Wingnut
- Strange bang from the engine
- Starting problems
- inner fender plactic pic help
- Bleedin clutch
- cold engine issue
- smell when reversing
- flush out antifreeze
- blinking CEL
- Quick Tech question
- Retrieving Diagnostic Codes
- Need some help guys
- Clutch Issue?
- fuel Injector harness connector?
- Bang Bang
- Help! Help! Help! O2 Sensor reinstall!!!!!!
- Warm engine will not restart
- Metering Oil Pump
- Code P2070
- Cleaning under the hood
- Console dimming lights don't come on
- Raspy Squeal at 2500 rpm
- 2004 RX-8 Wont Start
- 04 not starting this morning...need help ASAP
- Hand Break doesn't lock Rear wheels to drift
- P2106 error :(
- Heater/ac trouble
- power loss issue
- Dead Battery jumping problems.
- Coolant or Condensation on Oil Dipstick?
- Flooded?
- call will not idle once warm
- Advice needed
- Flashing CEL
- Replace Sun visor
- How to replace Shifting Boot
- Replace Shiting boot
- Oil leak 1qt. per fill up
- New clutch now a big whining noise
- CEL but no code
- Clicking Sound During Warmup?
- Weird RPM issue while driving
- Engine Overheating! Help!
- when the heat is on my car wants to stall..
- Finally, display/head unit problem solutions
- engine cut off at 5000 rpm
- No power steering and electrical resets?
- P0302 cylinder misfire, p0125 , p0506
- Fourth Gear's Scaring Me
- intermittent E-brake sensor light
- Strange "whirling" sound from engine at start up
- messed up differential?
- CEL Flashing after minor collision coincidence
- Lambda sensor problem
- I had to jump start it this morning, find the culprit...
- p2004 code
- Alarm question
- E-brake light, ABS light, and traction light all on at the same time.
- Cel
- mazda mess
- New (to me) car and new guy.
- Ignition coil problem?
- Steering wheel controls don't work for audio
- so i changed the plugs but.....
- lost power ~
- clutch pedal stiff?
- new clutch/flywheel and major issue
- Tune Needed???
- Car power/electronics goes off and resets?
- Where does the other end of the steering wheel control cable go?
- More problems
- blinking engine light when underload
