- Ticking sound after plugs installed
- GPS disc Issue
- Desperate, despondent and broke!
- 2004 AT problems!
- Quick question
- 2004 rx8 unflooded now stumped...
- I have a race this weekend but my RX-8 always dies 4 seconds after starting. Help?
- Seat Airbag Cover Removal
- alternator replaced. battery light still comes on occasionally??
- Battery light coming on only while driving
- Please help. Hesitation at high rpm.
- Help me diagnose.. (TCS, vacuum leak, starting issues etc)
- Need Help! Does this not look Wrong?!
- 04 Running light isn't working
- Dipstick
- Keyless Entry Not Working
- Coils killed the cat?
- she just wont start after winter storage.
- weird noise from the rear wheels when i brake (no its not because of the brakes)
- Driver side door stuck
- AC fan comes on after shutting off the car
- Headlight issues!!!!!!
- Power Steering
- Lock Nut Problem...PLEASE HELP!
- Please Help...RX8 keeps turning off...
- Needs Cleaning?
- Odd Problems. lights and buttons n trans lurch[$20 to whoever leads me to fix]
- first time flood
- Creaking noise when hit bumps under 30 mph
- p0301 engine code
- CEL after bumpy dirt road and somewhat working stereo (Video)
- Car is sluggish
- How long can i leave my RX8?
- New member with electrical problems
- Running Lean
- Strange clicking noise after changing spark plugs.
- car wont go into gear
- Freeway driving, engine doesn't want to run as good...halp
- instrument cluster died and immobilizer flash's
- Ok to Disconnect Battery for Storage?
- running problem
- Coolant/Overheat fiasco - Help!
- Unknown chatter/rattling Tranny or Engine
- Engine starting
- EGI comp 2 fuse blow
- Starting issue....
- CEL...car runs great though...HELP!
- Another one down
- RX8 Head lights always on even when light in switch-off position
- Idle problem after room fuse removal w video
- flickering display
- he wont start
- RX8 eccentric shaft oil leak
- Starts with CEL and revs less than 2000rpm now won't start.
- Low power below 4K RPM - Help
- power steering issue is it the steering rack??
- Help for New 8 Owner
- losing electrical power
- Not sure what kind of issue this is
- Weird squel when reverse or drive is ingaged at a stop on a automatic
- Sloshing water sound when revving
- few questions... possible problem but not sure
- RX8 will not stay on. Dies at idle
- Pull-Starting RX8 6MT
- Samco 6 pc rad hoses, where does this piece go?!
- Problems with the Gas
- Engine rough at Red light, also hesitates from dead stop
- Coolant Leak
- Car Light Wont blink when open with remote
- Stalled out, new fuel pump, still no start?
- CD player locked up
- power loss
- Upgraded Starter and Still Having Problems?!
- Help me please! engine lack of power!
- Subtle Clunk when Shifing into 1st Gear
- Help! Need More MPGs!!
- Rear End Roar
- CEL stays on, flashes when I am over 4000 rpm?
- Cat overheating, should I get a cat replacement pipe?
- Radio won't turn on/ LCD wont light up/ AC won't work
- Weird Tail Light Issue
- tranny noise
- English fella needs help! Low power
- Clutch won't disengage
- Rotor Misfire @ engine start only
- Help walbro installation
- Help plz!!!!!!!!!!!!!!!!!!!
- Water leak in drivers side!! Floor mat is soaked,water in hood popper! Please Help!
- Still not wanting to go into reverse.
- Wheelbase 10 mm shorter on NS
- Major loss of power above 6300 rpm - dyno plot included
- Starter motor
- Sounds like a sawmill under the hood
- Loss of power, LOUD noise from exhaust.
- car knocking
- New Engine from Japan
- Car Keeps cutting out at traffic lights
- Brakes???
- Engine Problem? Maybe Nothing Major
- Antifreeze leak.
- NEW!Starter, sprark plug,wire, ignition still sound like this!!video!
- Misfire at high load
- Courtesy light question
- Installed new battery, cranks but won't start.
- No cold air from Aircon.
- Methods of finding a vacuum leaks
- Coolant Light Randomly Illuminates
- Fuel line pops off!!
- Loud roaring and vibrating noise at high rpm HELP
- A few Questions
- Just replaced coil, plugs and wires and no zoom zoom zoom
- Bubbles in Radiator - Crackling @ High RPMs
- Codes My rx8 Flashed at me
- DRL Issue/low beam problems
- Problem not listed in manual NEED HELP!!
- Engine Problem?
- Hid problem
- Rack & Pinion !?!? Power steering went out! And Transmission Filter kit
- engine dead?
- Door Ajar switch/sensor
- Is this acceleration normal?
- Transmission Grind
- Emissions Test Help
- Dash Light Sequences?
- HELP NEEDED! Bad sound, switched off, will not start now, oil leaking
- brake light filling up with water
- Electrical smoke inside car!!!
- 06 AT, sputter at 4500rpm, low idle, bogging down
- Lack Of Power / Hard Start
- low compression
- Gas smell and no leak!?!?
- Alternator Wiring Harness
- Check Engine, diag Error
- Engine trouble
- New Owner.
- Misfires Low RPM, NO CEL
- Help answering dealer plug and coil question.
- Manual transmission. Will shift in gear when car is off, but wont shift when on?
- does coil numbering matter?
- Best way to remove stock Donut Gasket ?
- After hard rain- driver's side floorboard is wet. Where to look?
- Engine Misfire Due to Water
- obd2 won't read after msp16 ecu flash
- Liquid under Break Master Cylinder
- bang / poping rear
- car just stopped
- BOSE ground wire location??
- High RPM Sputter Problem, Help?
- Clutch Pedal Soft
- RMagic exhaust overheating
- I win for loudest ticking noise. [video]
- fresh rebiuld engine wont start please help
- Rear axle/differential noise
- Cranks a lot longer than normal and low RPM power
- CEL Flash.....
- Common Diff Gear Problems ?
- How to tell if No sound from speaker caused by Dead Amp or Dead Speaker?
- Fuel sensor/gauge issue?? Please help!
- 8yr/100,000 mile warranty RIPOFF!!!!
- Trouble eith REVI INTAKE KIT AND HEADERS
- Car Won't Start this morning? Why?
- AEM CAI sucked up water and now car runs rough.
- RX-8 Storage Question (stored for over a year)
- Frozen car
- Excessive Oil Consumption
- Is this a sign of my tranny dyng?
- Cheaper diagnosis for engine light?
- Miss Firing 2004 RX 8
- cleaned SSV now it won't start
- P0455 :[[[ halp
- 04 rx8 wont start!
- Press gas pedal....no go
- Acting up in rain
- Help problem with crank pulleys
- Engine failure - something broken off in engine?
- Head Unit / LCD problems
- WtF?
- No acceleration until 6000rpms
- low compression...seriously?
- Ticking noise
- Identifying bad coil
- Flywheel changed...reset NVRAM??
- floods everytime I go to start?
- SSV question from rx-8 noob
- Ambient Temp Display Hotter Than Normal?
- Cel and cruise main light
- FIXED: ABS and DSC light coming on occationally
- A few other problems
- Red Sign of Raditor in my RX-8
- What is reasonable plug life?
- Gas Mileage Dropped Suddenly
- Arggh...CEL's and stalling...please not this nightmare again.
- High Idle
- Starter problem or engine flooded
- possible to fix cracked radiator?
- Exhaust Sputter past 6k
- slow acceleration
- OEM radio adapter no longer works
- Dealer says SSV is stuck
- Squeeking?
- Grinding trying to go into reverse..
- rear brakes are locked
- hard to start
- Engine faulty indicator always on
- bubbles in coolent
- More on reduced power after highway driving
- smoking greddy turbo :(
- Engine Low Compression Issue. Help.
- Please help...feel like car is lacking pick up
- Starting problems with my rx8
- I
- Dirty/Clogged MOP lines!?
- Take a look at my rear end
- no power on coils after install of brand new ones.
- Please help me figure this out.
- short in steering column? Brief loss of power.
- Help, rx8 is sick!!
- Loss of power in all gears help!!
- Engine wont start after clutch/flywheel replacement
- Fuel pump retaining ring issues..
- Buy new engine or?????
- PLEASE help me, my BABY wont Start with video!!!
- idle rough and hard to start.
- Oil stain around MAF?
- i need help, please... ECT sensor
- clueless on ignition problem
- APV Questions
- Eletrical problems, Taillight wont work even with new fuses, Help
- P0037 cel
- RB dual resonated midpipe knocking
- HID Lights only
- P0506/P0302 idling problems
- rx8 issues... bubbles in coolant oveflow
- Oil in Air Intake
- When to change brake fluid?
- E-Brake light not turning off..
- extremely low mileage
- Help Please...Opinions
- Trouble with rearend caused by accident (please help)!!!!
- 2008 40th anniv - Dead LCD/radio-A/C display
- air intake problem
- Radiator Light and leakage
- Bad gas cap again?
- How does your 8 idle???
- PS Harness Part #
- Dead Spot in Rev Range
- Loss of power while crusing
- P0455 EVAP leak
- Clankity clank clank and no vroom vroom.
