PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20] 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Engine Dies on Neutral while moving, please help!
  2. Engine Misfire (Two Scenarios/Yes, Another Topic)
  3. Trunk lid install - sheared bolt
  4. rx8 idling problems
  5. Wheel Hop Troubleshooting
  6. First time starting car after premix.. CEL
  7. Strange Electrical Issues
  8. Exhaust smell
  9. A/C leak, found leak, pic posted, how do I fix?
  10. Rough Starts
  11. Removed slave cylinder. Have a question.
  12. 04 rx8 weird vtec sound
  13. Coolant reservoir failure
  14. misfire problem
  15. Loss of Power
  16. Need help Diagnosing my tranny
  17. Diff issues...
  18. help! rotors!
  19. Hard starting problems... possible engine to be replaced...
  20. Strange idle
  21. Starting Trouble
  22. less then 1k miles and already on my 3rd clutch.
  23. evap gross leak?
  24. RR Clutch Reinforcement Bracket help
  25. another engine mount question.
  26. Automatic Door Lock and Key Fob Trouble
  27. Issues with my RX8 lately, need help!
  28. Car wont start
  29. engine installed/ no start
  30. vibrates kind of rough
  31. Won't start (possibly electrical or fuel pump related)
  32. Emergency Brake Problems
  33. Reservoir under glovebox leaked?
  34. New owner - small issue CEL
  35. Seatbelt trapped me in the 8
  36. Running Issues, Need Help Badly
  37. low idle problem...at wits end
  38. Problems after AEM CAI
  39. Quick bit of feedback please!
  40. Possibly dying cat, no CELs
  41. Difficulty starting after filling up with gas?
  42. Steering Issue
  43. stalling at freeway speed
  44. Setting Clock and Temperature
  45. Wheel rubbing/jerking
  46. just bought.
  47. professional help please!!!!
  48. P0302 code with good coils
  49. mazsport coils problems !!? really need help
  50. Trouble with starting and...
  51. check engine light on start
  52. Cylinder 2 misfire
  53. RPM unstable
  54. Problem: Remote does not lock or unlock
  55. No power!?
  56. Blown motor ???
  57. Car sucked in WATER!
  58. Compression good but still wont start
  59. Won't start when warm? Ideas?
  60. Wont start, Screeching high pitched noise when i attempt to start it
  61. No start
  62. Cruise Control Issue
  63. Can't communicate with ECU
  64. New RX8 Owner, a few questions =)
  65. Wandering accelleration??
  66. Noise coming from the transmission
  67. Define "glowing red" cat?
  68. Battery/alternator issue. 2005 RX-8
  69. Question for people with high flow cat. Sound related.
  70. Error code p3920????
  71. Little help for a newbe
  72. loss of power, sounds like vtec please help!
  73. new engine same bad mpg..??
  74. Quick Help
  75. Weird noise after pulling keys from Ignition
  76. Back again . . . More issues!!
  77. HELP! wierd cluster freakout!
  78. Falling Rear Mirror
  79. Reman already dead? w/ Video
  80. e-brake light coming on under hard braking
  81. engine rattles, check engine light is on :(
  82. 8 problem
  83. Starter issues
  84. broken ground wire on positive cable?
  85. Suspect overheating causing pinging/pre-detonation sounds
  86. Car turning over slow.
  87. Help! Do I need a new car??
  88. The lower tire light comes on??
  89. Car gives up in hot weather with ac on
  90. Parking light short circuit. Help?
  91. Burning clutch smell...so slip
  92. half throttle at 5.1k rpm holds back and pull off again
  93. will not rev above 3-4000 rpm
  94. How to fix RX8 Credit Card style keys! (battery issue)
  95. Omp
  96. Please need some help
  97. Problem with Air pump
  98. COBB Accessport error 1014
  99. White smoke and overheating.
  100. Strange noise and feel in tranny
  101. OBD II Questions
  102. 2009 rx8 r3 died in middle of highway
  103. Coolant Leak (Not a house) Help Needed
  104. Coolant Light
  105. Wiper arm question.
  106. Weird starting issue
  107. CEL ON, bad gas mileage, cat problem?
  108. Loud clunking noise from front suspension
  109. Coolant Leak (Possible Overflow???)
  110. White Smoke From Exhaust and CEL?
  111. 53 reg new engine wont start
  112. Transmission or Clutch noise
  113. No pressure in clutch pedal
  114. Hello newbie alert. Got rough idle with knocking from lower engine
  115. Replaced clutch now noise
  116. Silly question, but please help!
  117. Strange read out
  118. newbie - replaced rx8 motor - vibration?
  119. cat overheating from misfire?
  120. fuel starva
  121. Changed ECU/ PCM Wont Crank
  122. HVAC Control Issue
  123. Possible Oil Leak?
  124. RX8 wont start 2004 model
  125. Confused on symptoms, have searched extensively.
  126. rough start
  127. Exhaust/Shield Rattle
  128. Possessed fan?
  129. strange rattling and squeaky noise exhaust
  130. cel code p2096???
  131. Help she wont start
  132. Weird running hot situation, need some input guys
  133. Weird noise and strong vibration at exactly 2000 RPM
  134. How do you make people leave your car alone?
  135. I am having several problems with my RX-8
  136. Rattling ticking noise??
  137. engine trouble
  138. how to shift? proper way?
  139. tpms light stays on
  140. Carbon removal????????
  141. Holding back at 5 RPM, what could it be?
  142. Shrieking Noise From The Passenger Rear Side
  143. No start
  144. Vibrations at 170-180kmh
  145. What seems to be the problem please help ?
  146. overheating troubles
  147. Possible Bearing or rear diff problem
  148. Misfire and SSV Code
  149. Low oil indicator (old TSB related) how do I *make* it happen
  150. the MORE and FASTER I drive the better it idle???y?lol
  151. help im an rx8 nube (engine failure)
  152. help im an rx8 nube (engine failure)
  153. car wont start
  154. car won't start all of a suidden
  155. Heater temp fluctuation
  156. Temp sensor install
  157. Driver side mirror glass removal
  158. Clutch Sqeaking
  159. RX8 dies when clutch is pressed.
  160. Chattering @ low RPM starts.
  161. Slow start
  162. New engine problem, now at dealers...
  163. AT 4Port - Blue Smoke = New Intake Manifold?
  164. Simple question about the clutch master cylinder
  165. Rough Idle on Cold-Start
  166. HELP! Turns over and won't start sounds like no compression
  167. High RPM, High Load Misifre
  168. mass air flow sensor???????? Idling Problem!!!
  169. Fuel will not enter
  170. I let it sit, now it won't start.
  171. Major Vibrations when opening sun roof
  172. Clutch Noise
  173. Cant upload my photos
  174. Grinding into 3rd at 6500-9000 rpm!?!?
  175. Is there a cheaper way for 02 sensors and Cat
  176. Jerking motion while cold- AT
  177. Jerking while changing gears, when cold- AT
  178. HVAC System
  179. RX8 overheating clutch problem
  180. Dealership Can't fix my problem :-(
  181. RX 8 Service Manual
  182. Dont know what Happened???
  183. Issue with RB Daul Rosonated Midpipe.
  184. Rx8 pooped out on me today
  185. weird heater problem
  186. Weird start up noise...
  187. Diagnosed with decreased performance due mods??
  188. Refrigerant Pressure switch
  189. Squeal or Suction sound
  190. P0661 (I Searched) need more advice.
  191. Gear Grind shifting from neutral
  192. Check Engine Blinking
  193. Frustrated as hell!!!!!!!!!!!!!!
  194. Bad Starter
  195. Finally Spring, New Battery, No Power Steering..
  196. Popping after coldstart
  197. RX8 making rumbling/poping noise after 4500RPM
  198. Speedometer Signal Wire?!?! Help!
  199. could this be bad?
  200. Car overheating above 4k rpm
  201. Power steering+battery light. this is different I swear!
  202. A few questions..
  203. Hesitation between 3-5000 RPM
  204. Need help getting a vibration at 67mph
  205. "Multiple Random Misfires" CEL code - replaced coils/plugs - still no help
  206. BONEHEAD move of the week! HELP
  207. seems to be "limp mode" season....
  208. Unable to rev, lack of accelerator pedal response
  209. random beep
  210. 6 speed gearbox
  211. car wont start, wont even crank
  212. Light revving issues?
  213. Loose battery terminal causing stalling on turns?
  214. Really really Soft Clutch, but nothing broken?
  215. Hot starting problem
  216. bogs on acceleration
  217. confused
  218. confused
  219. troubleshooting ABS/TCS, horn, and brake lights
  220. Strange wheel sound and "thing"
  221. slow accelaration
  222. Installed gnd kit and ODO added 200K?
  223. Having problems with my engine. Please help!
  224. Navigation Question
  225. 2004 AT Freeway Stalling Issue
  226. CEL and loss of power
  227. My Car wont Start, Search Button Dosent Work Either.
  228. engine problem
  229. P0302 after cleaning SSV
  230. Power Loss Issues
  231. Need Some Advice After RX8 Overheated
  232. First Scare i hope
  233. Loss Of Power
  234. First problem ever ! HELP
  235. First problem ever ! HELP
  236. RX8 no start died on highway
  237. Very Weird Clutch Problem
  238. What is this attached to my ECU??!!
  239. Misfiring After new plugs?!
  240. 05 recall
  241. so having trouble after winter sitting.
  242. This thing broke, what is it? (Please)
  243. just bought a 2004 mazda rx8 i have maintence questions
  244. WHY IS MY RX8 do this to ME??? with VIDEO
  245. Oil leak
  246. Starting Issue
  247. Steering Wheel Shimmy/Shudder post balancing
  248. Headlights out
  249. Brakes making noise :(
  250. Occasional cold start issue
