View Full Version : Trouble Shooting
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. ABS Light and DSC Light On At Same Time...
  2. losing power at 7500 RPM
  3. High Pitch Whine
  4. Engine Smoking After Heavy Driving / Abuse
  5. STEERING FAILURE , won't believe this one
  6. Dyno-since N-Flash
  7. Complain About Your General Fixups
  8. Questions About Normal Idling Changes As Car Warms Up
  9. Headlight Flicker
  10. Headlights do not seem level
  11. Takes 3-4 Seconds To Start
  12. Smoke from engine
  13. Won't start after winter storage
  14. THA-THUMP goes the suspension
  15. beep with no warning light
  16. problem with my tranny
  17. In For Oil Change... Out With New Transmission
  18. Oil Leak
  19. Top linings of my roof are loose
  20. Anyone had a windshield replaced?
  21. Brake Master Cylinder Leaking?
  22. Dealer blames TPMS for CEL
  23. Any luck with A/C amplifier?
  24. New Engine@19,000 miles
  25. Oil Coolers and stone impact - anyone else?
  26. Intermittent whine from rear at speed
  27. Wierd alarm problem?
  28. Trunk seal failure, anyone?
  29. Leak From Oil Cooler Line ???
  30. Weird problem with Center Diplay - looks like alien language
  31. Car wont start!! Is it flooded?
  32. Clutch wear?
  33. Minor Problem - Easy Fix
  34. ABS, TCS, E-brake lights all on at once! Any ideas?
  35. Turn signal disengaging
  36. Flooding
  37. Weird Steering Issue
  38. Rusted Lug Nuts
  39. Engine "Pinking" constantly - any advice?
  40. Engine Exchange by Mazda
  41. Soon to be my 3rd windshield
  42. buzz or whir sound when shifting
  43. Analysis of failed rotaries.
  44. 2 days old...problem
  45. squeaking in the interior?
  46. Oil refill after 3000km?
  47. idea for dyno'ing the 8
  48. Carbon Lockup Issues
  49. Bizarre shrieking/scraping noise
  50. CEL question
  51. Headlights look foggy under the lens
  52. clutch and trnasmission gone, please help
  53. 16,000 mile engine replacement.
  54. Intake voided warranty??
  55. rX-8 Constant problems would you trade-in
  56. steering wheel clicking
  57. What's causing my "THUNK!"
  58. Burning smell?
  59. Flooding cause question
  60. Engine Light Came On,after 7800 Miles
  61. This goes beyond knocking
  62. My 30 hour mazda trip...
  63. CEL = New engine?!?!?
  64. How get dealership service record before purchase?
  65. problems with 8
  66. CEL high rpm
  67. Fuel Starvation & performance
  68. ABS clank on hard braking
  69. stock exhaust when start up
  70. Mileage tips for the noob rx8'er
  71. Oil frothing on dipstick
  72. long road trip ticking noise and clutch feel
  73. Please - if you are using Line-level conversions for Audio...help me out
  74. Hand (E-) brake ?s
  75. Oily/burning smell
  76. Power drop off over 7K RPM
  77. need bushings to help stop wheel hop
  78. Question / favor about the fuel filler tube.
  79. engine flood...what now?
  80. Loud Throw Out Bearing
  81. Driver's side rear too low
  82. New Engine @ 2,200 Miles
  83. 4, 000 rpms and kind of sluggish + Smoke
  84. Rear (passenger side?) Window Rattle...
  85. Possible cause of "THUNK" at start
  86. CEL question
  87. rough idle
  88. Dtc P0610
  89. my greddy emanage sucks!
  90. Rattle in Driver's Door... Fixed!
  91. tail light water!
  92. climate control/radio display not working
  93. EPS Failure
  94. Sounds like emergency brake is sticking
  95. Power loss, then it died...
  96. cruise control issue?
  97. Harrison CANScan Problems
  98. Battery problems
  99. DSC help...
  100. May be giving up on the RX8 cuz of the PCM
  101. Yeah, another mileage thread (deal with it)
  102. A/C Grill (or something)
  103. SQUEAKY BRAKES!!: What should i do?!
  104. reverse gear being a b!tch
  105. Repeated stalling - AT
  106. best way to clean the carbon out?
  107. Is the porling noise a problem?
  108. Customer Service
  109. Check Engine Light On
  110. compression check
  111. OK..This is FREAKY...
  112. Getting new 05 headlights installed
  113. Headlight "Aim"
  114. Mazda Tech Line?
  115. problem idleing with my 05 auto rx-8
  116. It finally happend - Check engine light
  117. I turned it off and it didn't stop!
  118. TRUNK release button not working
  119. Advise about evoking the lemon law
  120. Brake Click
  121. Check engine light
  122. grinding in 3rd
  123. Dealer won't replace headlights or rotors...
  124. I've had enough A/C problems
  125. One unhappy customer
  126. Loss of Power in 1st...
  127. Seconf Gear Gone
  128. Heavy carbon deposits, exhaust pipe
  129. Clutch Clicking...Fixed?
  130. Missing and Power loss over 7000
  131. Squeaky Wheel?
  132. My mazda dealership said check the oil while the engine is running....
  133. Hesitation
  134. my car sounds like its dying! help!
  135. A "clunk" over bumps
  136. Oil in filter and loss of compression
  137. Temperature of your A/C
  138. Loud ticking noise on startup
  139. yay! My first easily verifiable broken part
  140. Dealer refuses service to my RX8 A/C
  141. engine rattle during a long road trip
  142. Something owners with aftermarket swaybars might want to lookout for
  143. ABS and TCS light will not go off
  144. Traction Light On/off??
  145. A/C center driver side vent blows warmer than others
  146. Speedometer stopped working
  147. transmisson issues resolved for 05?
  148. poor customer service
  149. Huge Clouds of Exhaust Smoke!
  150. Dash Rattle Fix?
  151. Check Engine - twice in 3 weeks
  152. RECALL THREAD/MNAO suspend RX-8 deliveries.
  153. Help!! Cant Here Radio Or Cd
  154. Intermittant Low Oil Level Light!!!
  155. cz problems........no throttle response
  156. Loose Parts and Seat Wiggle
  157. Front fenders too soft?
  158. Power steering out again...
  159. Low rpm whistle noise.
  160. Question about Fuel Line`
  161. Parts needed to replace torn brake handle boot?
  162. Brakes locking up
  163. RX8 No start problem
  164. Glove Box Problem
  165. help!
  166. Cold idling problem
  167. RX8 Engine Replacement - BAD NEWS
  168. Burning Oil?
  169. New AC Fix at dealers?
  170. Fuel tank recall
  171. Auto Leveling Headlights Don't Work
  172. VEGAS - Report on engines - WED
  173. RX-8 Control Arm/Ball Joint Problems RECALL
  174. Squeaking sound. sounds like knocking valves
  175. Driver side seat fabric worn?
  176. Is There a Conclusion About Oil in the Airbox?
  177. cat conv. failure?
  178. Put too much oil in - why problem?
  179. High pitched engine sound
  180. Will a Canadian A/C controler work on USA
  181. Dealer won't fix engine rattle -- They claim it's pinging
  182. few questions
  183. idling problem with knn typhoon intake
  184. ABS, TCS and Airbag lights on after hard turn.
  185. Does outside temp effect CELs?
  186. does the a/c normally make a sound...
  187. Notchy trasmission problem
  188. Arg...I'm conflicted.
  189. The "F" Word
  190. does anyone else's abs traction control light flicker from time to time?
  191. Which Flash I have? how to check ?
  192. Broken Transmitter on Key
  193. Clicking noise from wheel
  194. So Who belongs to the New engine club?
  195. transmission dampner
  196. How better crancks the new starting motor?
  197. Idle or fuel delivery problem?
  198. Brake Squeal Part II
  199. AC growling noise
  200. Squeeking sound
  201. I need as much info as possible on backing out pressure plate bolts and tranny issues
  202. Wanna hear BS from what mazda told me about our cars...
  203. Explanation of Ping?
  204. gas fill up problems
  205. class 1 recall
  206. Clutch Pedal Feeling
  207. Funny 2-3 shift in auto 8
  208. Coolant Warning Light
  209. Sudden Oil Usage Increase
  210. To those who got the catalytic converter heatshield fix
  211. Gas Mileage
  212. Window Tracking...
  213. occasional clicking
  214. Recall Work - Dont know if they reflashed me!
  215. Slipping clutch = 10000 rpms ??
  216. Is the engine flooding problem now 'under control' ?
  217. I "BROKE" my clutch?!?
  218. Recall work
  219. battery cover box
  220. Shift nob
  221. Recall Notices... ?
  222. ABS, emergency brake, traction control lights
  223. Split Sun Visor
  224. blew my main belt, maybe engine blown
  225. Shinka paint problem?????
  226. Help Needed : Engine Lost Compression
  227. Question about Idle RPM with clutch out
  228. Engine fan problem with NEW flash
  229. Sunroof open - Roof creaking noises? wtf?
  230. Suspension Noise
  231. Clutch Safety Switch--Car Won't Start
  232. Leather wrap on steering wheel flaking
  233. Recalls finally added to the Mazda Web Site
  234. Received recall letter for 3305G today - 9/1/05
  235. Weird Noises and stupid mechanics...
  236. Funny Engine noises between 3-4K
  237. hard starts
  238. Problems with Recall
  239. Power steering??
  240. Waiting for Engine for 31 day - HELP!!
  241. check engine light
  242. Car "smells" hot...
  243. Weird noise when in Drive and Holding on to the break pedal
  244. Front Suspension Rattling???
  245. Car Just Went In....Got Any Thoughts On These Issues
  246. A BIG UK 'thanks' to Rosenthal Mazda , Arlington.
  247. Greddy Turbo and White Smoke?
  248. AC Condenser Damage
  249. New tyres causing DSC to go off quick
  250. Power Problems and CEL
