View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 [19] 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. looking into buying a rx8, some questions after test drive
  2. Key stuck in ignition
  3. Wont Maintain Speed.
  4. Help me diagnose a start issue
  5. Thoughts plz: broken clutch pics
  6. Moonroof leaks anybody have this problem before?
  7. car shakes/rattle when first in gear?
  8. oil metering pump
  9. Power Steering Light
  10. Few vibrations
  11. Secondary air injection code?
  12. AP dual res midpipe fart cannon sound! Is this normal?
  13. changed my clutch but?????
  14. Disappearing 2nd Gear Grind
  15. Map light replacement...wtf?
  16. Air conditioning not really workin, need help....
  17. Fluid change
  18. question for turbo owners
  19. So many....ugh..
  20. CEL on... Please Help
  21. Noise
  22. Transmission? no clutch pedal loosing hydrolics?
  23. ac just blows hot air
  24. hard starting when done filling gas
  25. Car Sputtering And Died - Fuel Pump ?
  26. CEL- p0037
  27. High Clutch fix?
  28. Power steering light (wheel/exclamation point) 2006 RX8
  29. Car died n wont start help.
  30. questions on the decarbonizing the engine.
  31. Seatbelt won't Release (NOT front seatbelt in rear buckle)
  32. HELP! Smoke and hard start
  33. Question about the spark plugs and the catalyst heat-shield
  34. Replacing the clutch master cylinder need help!! anyone have a .pdf shop manuel?
  35. rx8 wont start
  36. cold start slight misfire
  37. 2005 RX-8 Eletrical Problem (Center Console)
  38. Flapping/ Growling/ YARRR from engine, mature semi-educated post. lol
  39. Engine Death with No CEL/Code
  40. Auto headlight leveling sensor warning light costs
  41. Aem intake help really needed
  42. Aem intake problem help needed
  43. tranny gone
  44. Batt. relocation, Positive Battery connection and dark current
  45. Installed BHR ignition - weird sound
  46. Compresion drop in the last year
  47. Engine not running right
  48. running over rich and smoking white alot
  49. Headunit freaks out and scrambles!
  50. Rolling a dice sound
  51. A/C Unit Issues Warm = Cold; Cold = Warm
  52. Car locks, radio, nav don't work
  53. weird engine sound at idle
  54. P0302 cel need help
  55. High Pitched sound from rear alarm tweeter
  56. Stock Radio Firmware?
  57. for those who own powdercoated AEM intake
  58. No idea wtf is going on at cold start
  59. SERIOUS steering problem
  60. Transmission/Clutch Issues
  61. HELP Oil
  62. How to test fans? Need help.
  63. Noisy transmission??
  64. Help me PLEASEEE.
  65. Wierd CEL, no apparent problem
  66. I get home from Iraq and this happens???? F*CK!!!
  67. Engine missing sometimes, running very rich
  68. I call it the "Stank"
  69. Glove Box/Compartment
  70. Clickling Sound When Sharp Turning?!
  71. I smell gas.
  72. Auto RX Shuddering
  73. Engine Management Light
  74. Testing ignition coils?
  75. I'm just lost.
  76. PCM Freeze Frame Data explained... anyone?
  77. My 8 Becomes a little bit hotter inside
  78. CEL and oil in air filter
  79. Clicking while I coast
  80. Runs loud/like crap when hot
  81. strange ticking sounds / whirring sounds
  82. Bubbles in Coolant
  83. Doe's RX8 suffer with suspension cil problems anyone??
  84. fuel pump issues
  85. hot and cold start problems??
  86. Whats wrong with my car?
  87. Yay! Check engine light!
  88. P0130 - Replaced front O2 sensor - P0130 again
  89. Turbo timer installation and CEL issues
  90. HELP! TSC/ABS malfunctions when headlights are turned on!
  91. taking my car in tomorrow
  92. Oil in post-intercooler piping? Already have a catch can
  93. Started after flooding...Now car wont rev over 2500
  94. AC Problems. Could it be expansion valve?
  95. Engine Harness routing
  96. clutch master/release cylinder
  97. CEL and engine roughness
  98. Can't get the cooler fans to work, no idea why
  99. Grounding or shorting issue
  100. no air in the texas heat!!
  101. Driver Door Speaker Cutout
  102. Heavy shifting 1st- 2nd
  103. Tempurature control innards not working
  104. Car starts without clutch
  105. What else is wrong?
  106. please help
  107. Heating problem
  108. AT doesnt downshift automatically...
  109. Heat Seats, Fan, Sunroof, Rear Defroster, ect not working
  110. Bad synchronizers? Or bad Tranny?
  111. heater and ac dont work
  112. Strange a/c problem...
  113. hesitation/misfire at 6k
  114. mazda speed strut bar question
  115. Something wrong with motor?
  116. Can barely drive when car is cold
  117. Radiator light flashing and oil in coolant
  118. Spongy brakes = no track event for me!!
  119. Can I drive without the plastic engine cover?
  120. Anyone else on thier 3rd catalytic converter?
  121. weird starting trouble...
  122. Headlight leveling system/clicking noise in idle
  123. Check Engine Light
  124. Care to read my plugs?
  125. Before I start dropping coin and hanging parts.......
  126. bleeding master cylinder help
  127. Coils and Cats question
  128. Problems after AP pulley install.
  129. AC issue
  130. Turbo no good?
  131. Engine Trouble
  132. K&N filter contaminated O2 sensor?
  133. Coolant Question
  134. Injen Intake issues
  135. 04 RX8 won't idle, Throttle body failure?
  136. Pretty sure it has to do with the tranny...
  137. Is this a dealer only job?
  138. Ebrake lever not locking in place ... please help
  139. I hear a clicking or popping noise when driving under 10mph
  140. wont start at all..any help?
  141. Low RPM (hit the gas all the way down)
  142. smoke??
  143. power steering issue
  144. Engine lacks mid range power when hot
  145. Small issues around start and idle.....
  146. Driveline damage, Post tranny
  147. Car Run and Revs Fine...BUT
  148. new tranny now car dies in nuetral
  149. 2004 rx8ides of rear end 48,000 k loud thumping from both s
  150. Just had engine replaced. AT seems a little weird now.
  151. auto leveling headlight caused by modification?
  152. idk what to look for now?
  153. AC Troubleshooting
  154. Intermittent Oil Level Light on Highway - Plenty of Oil
  155. F Me this car sucks (or my starter's shot)
  156. PCM Reflash Question(msp16)
  157. Looks like I'm in the new engine club as well!
  158. key fob keep on dying
  159. Question for fellow automatics
  160. Won't Start, Please Help!
  161. Take Off
  162. Car stalls when idle
  163. Just had engine replaced and now after driving i get a coolant/syrup smell after driv
  164. rx8 door light
  165. Secondary o2 sensor
  166. Do I need a new engine??:-(
  167. Car died won't start, gasoline dripping everywhere.
  168. Traction light comes up, can't go above 2.5k rpms
  169. LED STUCK in parking light Hole
  170. compression test printout no rpm?
  171. Intermittent engine power loss
  172. Jittery/rough Acceleration
  173. Stability System works great (except in corners)
  174. Guys! Help!
  175. Engine wont rev over 8500rpm? (231hp model)
  176. CEL and Cruise Control
  177. Sounded like a boat, now it wont start
  178. Remote Battery model.
  179. Cleaning out map light lens/reflector/area?
  180. Spitting in topend and during fast shifts.
  181. AP pulley install - stripped bolts
  182. New battery? Lights dimming
  183. 2004 rx8 security sysem malfunction????
  184. car died, security light flashing rapidly, wont start. any ideas>??
  185. Ignition coil testing: resistance values of new and old set
  186. Check Engine Light- P0455
  187. Engine gets really hot!!! Please help!
  188. What radiator cap preassure does the rx8 use?
  189. installed lowering springs... Now i have an issue.
  190. Power Loss at high speed, up hill
  191. Damaged apex seals?
  192. Fueling overflow problem – solved
  193. !!!Overheating!!!!
  194. Smoke/Gas Mileage
  195. Odd Air Conditioner problem: warm from left vents, cold from right vents
  196. CEL codes p2070 p2004
  197. Plugs/Coils. Again?
  198. Centre console / display / HVAC controls dead
  199. Power Steering Problem :-\
  200. Advice on Plugs and Coils.
  201. Stank coming from rear drivers side wheel well
  202. compression numbers - your opinions?
  203. Oil Pressure
  204. well i'm finally part of the club
  205. Lots of Smoke!!
  206. My baby is sick again!!!
  207. Centre console problem
  208. 04 RX8 MT feels like an AT
  209. Slow shift from 2nd to 3rd. Also slow into reverse.
  210. car wont start, electrical problem?
  211. Summer heat causing car to run sluggish?
  212. Uh oh, Loud noise @ high rpm
  213. Violent idle when AC is on
  214. weird idle and no cel light
  215. radiator light
  216. Engine lost power, misfiring
  217. Car has rough idle
  218. Headlamp level error light
  219. How to fix Air Conditioner unit?
  220. Oil Filter plastered on.
  221. Won't start - help please
  222. What is the silver box UNDER the Air Pump?
  223. weird sound with clutch???!!
  224. Help with oil!!
  225. Engine power issues - but not the norm...?
  226. injector wire help
  227. colder air for the engine
  228. Glowing cat
  229. Cracked Exhaust Mainifold?!
  230. 04 rx8 no center console\radio at all
  231. Maf sensor position?
  232. Temp guage problem
  233. rattling from clutch
  234. interesting noise...
  235. Help - clutch noise? Whistle sound???!!
  236. PLEASE HELP New rx8 owner with serious problems
  237. New coils cured my rough idle
  238. Engine or cat problem?
  239. car imoblized itself
  240. Power Steering Problem- Not your normal symptoms
  241. Stalling and Intermittant Power Loss
  242. Horn Gone Bad???
  243. Engine failure..
  244. Lasting damage from shot ignition?
  245. No power steering WTF
  246. 1st-2nd sticky shift
  247. No heaters, blowers or air con, blown A/C fuse
  248. engine light on
  249. **HELP COOLANT LEEKING RIGHT THROUGH THE CAR**. pics inside
  250. Spark plug hole carbon buildup
