PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Hard Starting, wont idle
  2. Replacing 2nd Gear Sincro.
  3. Check engine runs rough. need help
  4. What the .... (DRL)
  5. Seafoaming issue...
  6. Engine Replacement at 105K - Need opinions
  7. Coilover Troubles....
  8. Engine Struggling for power / new battery
  9. severe knocking
  10. Coolant leak from rear of engine !!!!
  11. Hiccup at 5k RPM, loss of power at 6k plus, dealership CAT is fine
  12. Clear-ish, odourless liquid leaking from RX8?
  13. Just got New Battery. Stall at idle.
  14. Engine Idle
  15. Simple idle question
  16. 04 rx8 55k miles. Getting a weard exhaust sound.
  17. Engine burning coolant, white exhaust smoke..
  18. No heat from heater
  19. OMP line clogged?
  20. Flashing CEL when car is not running?
  21. 04 rx8 bunch of problem need help please
  22. low compression, engine rebuild or replacement
  23. Air in Coolant - Access the Radiator Cap??
  24. Yet another Low Compression Results Thread...
  25. Possibly Low Compression?
  26. Wont Crank/Blowing ACC Fuse
  27. BHR coil/wire failure
  28. Mazda starter vs NAPA starter
  29. Idle and stalling problem after battery swap
  30. new owner with problems
  31. panic button-wont start
  32. Fan only works on two and three
  33. Starting Issues? START HERE.
  34. Grinding noise above 60 km/h (Willie)
  35. New member from San Antonio, first real problem ( Start issue)
  36. Fog ligts arnt same color?!
  37. A different starting problem
  38. California Smogging Issues
  39. 2004 RX8 Starting Trouble
  40. aquarium mod x.x
  41. Remote Keyless entry system will not unlock doors
  42. mazda rx 8 catalytic converter
  43. coolant leaking, check engine light and traction control came on
  44. Weird Wobble
  45. flooded road=drowned 8
  46. Misfire readings and possibly some bad sensors
  47. Tail light question
  48. Strange stalling behavior
  49. CEL - P2097 - Need help understanding the FSM!
  50. A couple of issues
  51. Would a decarb do the trick?
  52. Problems with RX8 undertray replacement
  53. Grinding problem not the synchro mesh!
  54. need help on removing seat
  55. Clutch click and idle dip.
  56. Big troubles after engine swap ?!!
  57. Warming up too fast?
  58. Rear differential leaking.
  59. Won't start when HOT
  60. Blinking engine light, slow acceleration, white smoke.
  61. Engine Replacement Warranty Help
  62. Acceleration issues
  63. clutch chatter or mounts? how to test?
  64. Help ! Flashing CEL
  65. AT Wine in First Gear?
  66. New engine, but getting CEL (engine warning light)
  67. 2005 RX8 Gt engine issues
  68. Won't start - seems to not be flooded
  69. Car died while driving
  70. Another "Car wont Start" Thread
  71. Crankshaft Sensor Position?
  72. HELP removing Eccentric shaft position sensor
  73. Total Loss?
  74. Oil light on- oil level fine
  75. Grinding 4th gear, but with 53,000 miles?
  76. 2004 RX8 w/ factory Bose system
  77. Car won't idle
  78. Misfiring - question about changing plugs without coils
  79. P0661 intermittent question
  80. overheating issue
  81. Car wont crank!
  82. Cracking noise.. Help
  83. Misfires, HELP!
  84. Compression test results
  85. Airbag Light On
  86. Headlight problems
  87. fans and radio not working.
  88. Transmission problems?
  89. Low power in high ambient temp
  90. Start-up: New coils only helped for a moment
  91. Navigation System Issues (power button does not work)
  92. AC is on even when the light is off?
  93. Coils maybe??
  94. Gas Pedal loose
  95. check engine light/ catalytic converter
  96. A/C drain plug clogged?
  97. Running Very Rough - Gas in Oil?
  98. Another Power Loss Problem.. Help Please
  99. Syncro Warranty
  100. Thudding after jacking/tire removal
  101. Decating
  102. Spark Plug Question FAST
  103. Car Stalling at stop lights/Trouble Starting
  104. Abnormal whining sound after replacing oil cooler lines
  105. Cruise Control Pulsing
  106. Check Engine Light
  107. Gas Smell on Rear-Left Tier
  108. Interior Smell - cant seem to get rid of it
  109. Name that noise
  110. Help! On the road..and dead..
  111. having problems starting
  112. Still vibrates part ii
  113. Squeak after lowering springs
  114. Universal grounding kit issue.
  115. Advice appreciated
  116. WATER in my left tail light
  117. parking brake light ????
  118. Alarm pad won't work
  119. Loss of power due to mods?
  120. still VIBRATES!!
  121. Creeeeeeky Steering wheel
  122. Coolant leak
  123. rx8 on fire
  124. Power Steering Light
  125. 5-20 or 5-30w oil? will it really help? or?
  126. Running Issue & Radiator Light
  127. I need a little advice
  128. Coolant temp
  129. Clutch doesn't want to engage and I cannot shift it into reverse
  130. Car starts, but wont move. Help!!
  131. Shocks Top Nut untightening?
  132. weird sound after shutting off engine
  133. Sudden loss of power, now car wont start
  134. Idle dip when coming to a stop
  135. Low compression and slightly out of extended warranty
  136. Bumper welded? Need advice
  137. Dead car, sweep gauges
  138. Rpm hesitation/rpms dramatically increasing
  139. Fuel Smell Inside Car
  140. Car stalls at stops, and is slow to accelerate
  141. P0300,p0302
  142. Inconsistent fluctuating idle when stopped. (video)
  143. Airbag fault code
  144. rx8 wont start when engine is hot
  145. Oil pan leak
  146. scrapping noise from tranny maybe clutch slip
  147. Changing rims
  148. Literally Flooded Engine
  149. APV Motor Questions
  150. input shaft seal leak now clutch slipping...
  151. Bad alignment
  152. water in oil /oil in water and intake,,,:<
  153. throttle dead spot
  154. Troubleshoot this ...
  155. Hard Starting When Cold
  156. Still srs lamp flashing?!
  157. OBD II pins loose???
  158. Broken actuator
  159. Cel p0336
  160. rough idle after cleaning ess
  161. weird coolant leak! need help!!
  162. First canadian warranty
  163. Compression test result...
  164. back firing after tune up?
  165. The plastic radiator drain plug...
  166. oil leak?!?!
  167. ACT HDSS squeaking
  168. Replacing the Keyless Entry ECM
  169. 04 Rx8 Keyless Remote question
  170. Turbo Xs Catback system...HELP!!!
  171. New suspension...WAY too low
  172. Just got a rx8 2004 automatic.
  173. Broken coil mount
  174. Loosing Coolant through Overflow.
  175. A little help would be appreciated
  176. First time rx-8 buyer
  177. Spark Plugs Reversed???
  178. Car battery!!?
  179. Turbo Xs Catback w/ racepipe HELP!!!
  180. Running hot...where do I start
  181. Fan Size
  182. Battery light on at start up
  183. Fogs/DRLs suddenly stopped working?
  184. 04 6MT Grinding Issue
  185. flywheel problem
  186. gear leaver and center console get warm
  187. HID's burning out already...?
  188. HELP! Rx-8 won't shift into 1st or 6th gear
  189. Not sure what to do
  190. Clutch confusikb
  191. 07 RX8 121K over heating
  192. Squeaking in the mornings + burning smell?!
  193. Got a few minor problems...HELP! :)
  194. P2096 - Post cat fuel trim system too lean bank 1
  195. My 8 shut off at 80MPH
  196. Wird IDL + RMP PROBLEME!
  197. Acceleration Problem
  198. TPMS problems
  199. cat was glowing
  200. New owner needs help.
  201. what to look for when buying?
  202. Suspension/steering dilemma.
  203. Clutch problems after recall
  204. Cel on but no issues with my rx8
  205. Trouble starting but not flooded
  206. Accidently washed the inside of my car last night.
  207. Bought a haunted car.....
  208. 07 automatic overheating
  209. Power Steering failure after batterry change!?!
  210. Limp mode after installing new injectors?
  211. First Issue in 30 days of ownership: fast blinking check engine light at high RPM
  212. Car full of water after epic Chicago rains last night
  213. Rumbling during ignition and revving
  214. More problems; check engine/battery lights on
  215. Clutch pedal pops...
  216. A/C not working
  217. Bad power steering - hard on one side
  218. SSV actuator hole
  219. Fuel Injectors not working.
  220. P2405 cel
  221. Engine Throttle Response Time - Blip Blip Blip
  222. Radio not Working after bump in Road
  223. Fuel Pump problem?
  224. Oil leaking everywhere
  225. Midpipe to catback gap
  226. Engine dying in the heat...help
  227. best engine rebuild kit?
  228. Intermittent clutch issues???
  229. Long startup + weird intake noise from 1-3k/possibly no power after reman engine?
  230. car not cranking
  231. AEM Intake issue
  232. Wheel lock fail?!
  233. Rx8 Display Question!
  234. clutch and Flywheel issues - thoughts?
  235. '04 Rx8 I need help
  236. over fueling rx8
  237. Freak Alternator Belt Failure kills ignition = tow
  238. Engine Light after Spinning Out
  239. Cracked Dash?
  240. Audio and heating entre console unit probelm
  241. Slow Starting
  242. Radio Silence/Heavy Steering
  243. engine stutter on start up
  244. Engine problems
  245. Another Misfire Fix Thread
  246. Problem with 04, Stick barely can be pushed into gears
  247. Headlight Module Assembly Broken (Right headlight not working)
  248. help!!! new engine with P0171
  249. Voltage drop. Help! Please!
  250. Coolant level light > Bogging > Engine shutdown
