View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 [17] 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Loss of pwer and strange engine noise
  2. Oil Dilema
  3. low idle at random times after sea foam
  4. Weird clicking noise
  5. Clarification on my Motor Mounts
  6. Clutch issue
  7. High pitch whine/grind no start
  8. Does anybody know what year the current clutch pedal became standard?
  9. Just bought one, should i take it back?
  10. Engine flooded exhaust sound change, sluggish engine
  11. K&N Filter Cleaning
  12. Trouble with clutch when starting
  13. Power fluctuation and engine shutdown
  14. problem with park cam
  15. A/C question
  16. 3 inch exhaust... suitable?
  17. Warning Lights
  18. Oil pressure gauge reading high?
  19. Hard idle when engine warm
  20. Have to leave rx8 for a month...help with possible problems
  21. Engine replacement question...
  22. PRoblem with start
  23. whacko idle during warm-up
  24. Random squeak/squeal, narrowed down to belts? Maybe?
  25. Problem with start
  26. Car Died on Highway Help.
  27. Insight on a worn bearing sound?
  28. Went on a 3 day vacation, came home....car won't start
  29. Engine failure
  30. Weird Ass Problem With Tiptronic Tranny
  31. horns stopped beeping when locking doors
  32. butt warmer issue
  33. flashing cel possible solution?
  34. turbocharged RX-8 HELP !
  35. first engine problems
  36. Please please help me
  37. Heeeeelllllpppppp
  38. How do you change sat/nav/tv from Jap to English?
  39. E-brake coming on during high RPMS?
  40. Rough idle - misfire
  41. Water leak around the clutch
  42. Steering issues
  43. Flooded RX8 apparently issues with dealer
  44. O2 Sensor Failure: Front or Rear?
  45. car turns over but shuts back off
  46. Strange sound.....sounds like boiling or bubbling
  47. RX8 Leaking gas from the gas tank
  48. Hopeful New RX-8 Owner: What to look out for?
  49. Oil in the Intake + Hard Start + Misfires
  50. engine replaced and now CEL on
  51. questions about problems
  52. Warm Start trouble please help.
  53. Jumping car and alarm keeps going off
  54. S1 Problem Tracking
  55. stalling?
  56. Low compression :(
  57. damaged cat
  58. Car stalling/ not getting enough power like before/engine light coming
  59. Engine stops when deccelerating
  60. Rx8 Wont Start, just clicks
  61. Door Lock problems
  62. Problems
  63. What Gaskets are covered with the engine replacement ?
  64. starting & low rev problems?
  65. brake screws
  66. !@#$#@$ Rx-8 Engine, wtf
  67. No power anything..
  68. Engine Rebuild
  69. What happens? New ENgine?
  70. RX-8 ECU Failure ?
  71. ABS, Traction, and E-Brake light issues
  72. 2nd,4th,6th gear noise
  73. Another new oil leak...
  74. pulled this code (p2098)
  75. transmission or clutch?????????????
  76. Car Not Starting / Really Hard Start - Help!
  77. Squeaky Brakes!
  78. My first CEL what could it be???? Oh and other problems
  79. Question About Cat Replacement
  80. CEL on for Air Intake Sensor
  81. Minor Accident, any HELP would be appreciated
  82. Month 5 @ the dealership & it will be fixed
  83. not happy with my 8
  84. Loss of Performance below 4500 RPM???
  85. Engine light steady/hard start
  86. fog lights
  87. Air Pump?
  88. battery charging problem
  89. Need help with OBD2 read outs
  90. Fixed everything but this !!!!!
  91. Power Steering Rack failure?
  92. Front Air Dam Need Help Quick
  93. DSC light on during accelerating?
  94. Radiator light problem
  95. Airpressure in transmission - Normal?
  96. Coolant leak
  97. wont start/turns over HARD
  98. ASWI-JACK steering wheel INT
  99. flooded, new spark plugs still wont start
  100. Engine code P1688
  101. Easy technical question need answer
  102. front tire rub
  103. Car wont crank over
  104. RX8 paddle shift problem
  105. problem car wont start possible flood but....
  106. Lucas Upper Cylinder lubricant?
  107. Starting Problem
  108. Chirping air sound when on the gas
  109. Help what have i done car will no longer idle.
  110. My 8 won't go above 3000 rpms
  111. Mazda Building Me a New Car ???
  112. dirty air filter
  113. Battery Drain
  114. Flexable Brake Line Removal
  115. Wheel/Rim/Axle/idk problem.
  116. Brand new battery -- Car won't start. Help.
  117. Tire(d) Dilemma
  118. 2004 Hard Start Question
  119. Can I mix coolant?
  120. Brake Locking Problem
  121. Car hesitates, lose of power at 4k-6k RPM
  122. DTC P0076 : Intake Valve Control Solenoid Circuit Low Bank 1
  123. DSC / Traction Control Activating on Slow Turns
  124. Whining
  125. No power when I hit the gas!
  126. turbo lag
  127. Clicking/ticking under hood
  128. Help please; CEL and a couple other issues =/
  129. Help: CEL on & other small issues
  130. car dies when coming to idle
  131. Oil at the bottom of the car but not leaking
  132. Power loss
  133. My new rx8 is difficult to start after winter storage
  134. Car isnt turning on right away??
  135. back fires on cold start
  136. No information display
  137. Changing headlight bulbs
  138. Vibration again what is it this time HELP!!
  139. Power loss/Knock/Rough Idle - Any help greatly appreciated!
  140. Cell after seafoam.
  141. Stuttering problem, new car, need help
  142. Banging from underneath the pedals
  143. Coolant issue
  144. Any ideas?
  145. resetting fuel trims
  146. Please help! My 8 wont start!
  147. Odd Sound driving me crazy and getting louder
  148. Name That Sound + Identify that object!
  149. Rough idle for 15 seconds, runs great?
  150. Helllllppp!!!!
  151. Compression Issues?
  152. trunk lid button not working
  153. Loss of Power at High Revs, accompanied with high pitched noise.
  154. How many radiator hoses does an RX8 have?
  155. squealing bely
  156. Old article on what type of oil to use
  157. rough idling and loss of power
  158. Idle seek ONLY when in gear and clutch in...
  159. how to remove tail light tint???
  160. Tire Presure Monitor Sys Malfunction
  161. front shocks - fluid leak??? I thought they were gas?
  162. seat warmer
  163. Idle problem!!! Helpppp
  164. Clutch slipping in high rpms rarely
  165. K&n intake !!!!!!!!!!!!!help!!!!!!!!!!!!1
  166. Maybe someone can help me out please
  167. P0037, P0031, P2010?? help please!
  168. Power steering thread
  169. Quick question regarding cat....
  170. changing fog lights, radio dosnt work, car wont start.
  171. Car running like sh@t
  172. Intermittent squeaky noise coming from underneath the car after HKS exhaust installed
  173. wheel hopping
  174. Wouldn't get into to gear, now its fine
  175. optima red top
  176. Strange issue...
  177. MAF plug wires too tight?
  178. Stupid Tow Company! Engine Question
  179. car jerks really hard and sometimes just looses all power
  180. Penny in the gear box......
  181. Can i transfer my tpms from 16inch to 18 inch stock????
  182. Can i transfer my tpms from my stock 16 inch to a set of stock 18 inch
  183. Burning fluid/grease smell in interior?
  184. Ignition Coils not the issue...?
  185. Hard start
  186. Sounds like someone is playing pinball in my rotary
  187. taking out of storage, new battary, engine light flashing..no start!Help!
  188. Oil Pressure Meter...Normal?
  189. help stallin rx8
  190. passenger side power window
  191. Engine shut off at a stop light...
  192. Fuel in oil pan causing smoke
  193. Help!!! 06 GT, low beam HID's will not level out
  194. Is this a rotor housing crack?
  195. Split radiator
  196. Intermittent miss at idle - Normal?
  197. Oil leak and strange ignition issue
  198. Warranty Coverage on Coils, wires, and plugs
  199. Greddy turbo problems
  200. Flooded, then Engine Light On?
  201. Computer issue
  202. No sound from radio or cd
  203. smell of gas??
  204. Clutch and Transmission issues
  205. 2004 RX8 Has no oil compression..Help?
  206. Check Engine Light - 35xxx Miles
  207. P0335 Eccentric shaft position sensor circuit problem - Car will not idle
  208. "Marbles in Blender" issue.. PLEASE HELP!!!
  209. Sigh =/ starting problems
  210. Clutch easier to engage...
  211. P2096 (cel)
  212. stalling in motion
  213. Vibration at stop light and clicking sound in engine
  214. guys I need help...
  215. Fogs out
  216. Sticky question
  217. Problem with hard starts
  218. AC leak....
  219. water level sensor or air in the system?
  220. Exhaust/sound problem
  221. *****Having problems with transmission*****HELP
  222. MazdaSpeed Exhaust doesn't Line up, Flickering interior Lights when on Battery Power
  223. secondary air injection system issues
  224. side marker bulb wont light up.
  225. Got a mind boggler for you tech types...
  226. battery light on
  227. Car wouldn't start - Had to reprogram control modules
  228. Help.. Scared =(
  229. Traction Control Randomly Turning On
  230. Remote entry doesn't work
  231. Oil Question...Please Read!
  232. Strange clutch noise
  233. Gas Leak
  234. Need to find oil cooler
  235. Random Turning?
  236. Engine dies while on highway
  237. mods with CA smog
  238. Cluster gauges going crazy.
  239. Grinding noise i reverse
  240. air pump failure linked to power steering failure?
  241. car dies when put in reverse
  242. headlight problem
  243. clutch problems 2006 rx8 6spd
  244. Sputtering at high RPMs
  245. Repeated Check Engine Lights
  246. Car is POSESSED! Guages flicker with no key in ignition!
  247. Battery Problems
  248. Turn key to start, get "click"
  249. Accessport in Conjuction with Emanage Ultimate
  250. A/C Non-existant
