View Full Version : Trouble Shooting
- White Gummy stuff on dip stick. HELP!
- screwy heat
- P0443 but car still run normal !!!
- RX-8 '08 lost power
- rough idle no power and glowing cat
- car wont start!
- 04 rx8 recalls and vib. at idle
- Another Won't Start Issue
- Parking Light
- CEL plus won't go past 3k RPM
- Help!!! Electric seat is FROZEN FORWARD!
- check oil light coming on at start up?
- Traction control light won't turn off
- I think 2 questions that have simple answers
- Car Won't Start After Frost??
- Fog lights went out
- Bent fender
- Help! Missing bolt leaking coolant
- Help! RX-8 backfires stalls then floods
- Radio is on but no sound
- CEL Secondary Air Injection System
- WTF????....I've had it.......
- I hear a thud
- brakes!!!!
- clutch play!!
- Lost key dealership says I need to take my car in?
- Can CEL P0113 Cause Engine to DIE?
- Clutch question
- Anti theft problems?
- Keyless Entry Won't Program...
- Hazard Lights & A/c Controlls Out of Commision
- Car has no electrical power, battery is charged
- Car suddenly runs like crap after Dealership Reflash
- One problem after the other
- Car won't start
- white smokey exahust
- Misfirsing + Long Crank Times
- Strange Noise around 6k
- Got CEL P2122 , how to repair or replace
- Onced jacked up, if I free spin the left front wheel there is a grinding noise
- Dangerous brake and stearing failure!!
- Car won't start after short vacation
- Car throwing multiple CELs, hesitiation on gear change
- Engine sounds hoarse
- Engine stumbles on acceleration
- Burnt Transmission?
- 6-Stacker won't play CD's anymore (CD IN, no error msg)
- slow starting and bad idle..
- 05 rx8 misfire
- Advice needed
- lots of vibration
- car wont start and power is there?? PLEASE HELP
- Port Flutter? Strange Engine Noise
- TPMS stays lit + beep when starting?
- Burning smell when idling - CAT Failure?
- P0126
- car will not give codes...dealership frustrated
- Weak battery with appearance of corrosion
- Check Engine Light - CEL
- whining / chugging noise
- 2004 Rx-8 Starting Problems
- blue smoke & oil in air breather
- need help..burning smell!
- Air Intake Noise
- quick help!!!
- SLow Start
- Wheel arch height with Tein S.Tech
- Clutch problems
- T1 & T2 not firing
- navigation buttons issue
- Tire Deflation Problem
- Car wont start and sounds like a Kazoo
- My 8 won't start. sometimes.
- Heating problem on JAP Import
- Remote Start Issues
- Bad Speaker?
- Idle surges during warm up, dealer wants $600?
- my car wont start. please help
- Possible starter failure?
- Another Noise.. Clutch? Tranny?
- help please! cel p0300 and p0171
- Milky White Substance in Oil in FL
- FSM Download?
- Information display continuously cycling
- no day time running light or high beam
- Do not overflow coolant tank!
- Random CEL
- Rx7 interchangeable parts
- Clutch Pedal Hijinks
- Shuddering at low rpm and idle, runs rough, occasional P0301
- engine wont start when warm?
- Engine Mounts
- Rough Idle/Screeching Sound/Stuttering... But I don't know why
- Auto Lock Question
- HVAC lights don't come on - but buttons still work?
- Check engine light. Rear 02 sensor
- New Battery and now stalling
- Bogging bad sound on startup missfire etc.
- need helping swaping door
- Royal Purple BADDD???!!! PLEASE HELP!!!
- Hesitation Under Load In All Gears and NOISE
- Annoying Squeak
- CEL P0171 help
- cooling system problem // please help...
- Shifting problems
- Center console light and blue LED lights not working on night mode
- turbo installed now it won't start
- Acceleration issue
- Headlights going out ? Only sometimes
- Need Advice on dying engine...
- Clutch Problems... Push rod with leaking Master Cylinder
- cel last week and rougher idle.
- Need some help...
- 13.3 volts car will not start
- please HELP.... Two Problems
- replaced coils and still really rough idle
- Leather dye no good?
- Rearend Knock?
- CEL and Reduced Power ?
- A few vibrations and questions
- Upgraded Starter
- 2nd gear, sulpur smell from exhaust & steering wheel sound problems
- PKM won't program new keys
- coolant in the motor??
- Engine Light
- Over Filling Engine Oil
- Help!..... please check engine light is on p0240
- My 8 remote control doesnt work...???
- 05 rx8 at no spark at coil
- vibrating and stalling
- Flooded engine - really need new spark plugs?
- MS exhaust 2.5? Little confused...
- engine coolant problem?
- Not beeping when i redline
- need help, engine shuts off while driving
- Clutch isn't releasing..?
- gooey residue
- Leakk!!! D: help
- Is this normal?
- lock/unlock... flashers don't work?
- Deflooding Success
- Exhaust Pop, Rough Idle and Lower MPG
- Weird noise and hard starts
- New 2010 Mazda only 280 km per tank!
- Can you guys do a little test for me?
- Electrical Problem HELP!!!
- Driver door wont open
- Driving hard....minute of CEL....power loss.....brake down
- CEL codes
- Both low beams
- Grind from starter - Need some help picking new starter!
- Finally an answer to engine stalling problem
- What is this!?!?
- Blown Shock/Strut??
- 04 engine replaced with '05
- Help! - Failed state inspection
- water mixed with oil
- Hello There!
- Manual Transmission Problems
- Motor Mount Failure on 2004?
- FLOODED.. yes or no?
- Help!!! my alarm keeps going off.
- Problem ! NEw Fuel
- Start up Issues...PLEASE help
- Brake Bleeding Issues, MC Brace Possible Cause?
- Hard start new starter or new engine?
- Front Lip(Stock Black part of bumper) Falling off!! heLP!
- CD/Radio Stuck disk
- Moisture in Back left tail light
- Flasher Control Module Failure?
- Cold start problem?
- Water puddle stalled, try to start or tow to dealer?
- u think I'm a new engine candidate?
- Compression Test Readings, can anyone help?
- RX8 2004 power stearing warning lights on rackpinion off
- Mazda denied warranty on engine replacement....
- RX8 loosing power
- I can't reprogram my remote
- NEED HELP - spark plugs, bhr ignition coil, msd wires, hks ignition system-break down
- CODE RED...DAMSEL IN DISTRESS!!! :tear:
- Code red...damsel in distress!!! :(
- really bad small in side car and out side car
- Strange cruise control problem
- 12 miles to the gallon
- Clutch/Slave Cylinder/Clutch/Fork/Throwout Bearing/Transmission problem
- Hard Warm Start, Please Help
- How do you adjust the Clutch Safety Switch
- Should i be worried about white stuff on my dip stick
- Engine hesitation
- weird CEL issues
- OMP Leaking & Transmission Bearing : (
- !!! Ugh Leaking Cooloant !!!!
- HELP - Still won't start
- Please Help..RPM on engine shut down??
- complete loss of power 7-8k
- felt like power loss...
- air bag light came on doing 70
- Check engine....and others
- 2004 RX8 has power problem
- Sticking Door Lock
- Visteon 41844 remote
- BHR Ignition...now wont start
- P0302 P0300 issues.
- cat removal question
- Code P2096 NEED HELP (also code P0300, P0301)
- carbon fiber hood help!!!!!
- rx8 loosing power
- Start Up Noise/flashing CEL
- wont start after several days of sitting
- Electrical dies for a second under load (brights/power steering), engine doesn't
- wth my hood rattles
- CEL running lean and get stutters only when slaming gas pedal and reaching high rpms
- Parking Lights Turn On When Applying Brakes
- 3rd brake light led trouble
- Ignition coil kit
- Losing power
- Dead battery now power issues
- Clutch pedal loosing pressure
- Losing Power, but only under very specific circumstances
- Stalling after high RPM load, but not your usual scenario. Help!
- Engine hesitation... :(
- clutch slipping
- 04 rx8 po300/po301
- AT, cold ride, cel, driving like a manual?
- Please help me fix my baby
- Won't start, have spark, have fuel... ideas?
- how many times...
- One CEL after another, Jezuz friggin H!
- Just my luck
- LED Help please!
- Alarm wont turn off.....HELP
- starting car
- New To the RX-8: Need some advice/help
- Climate control fan only works on high
- Headlight comes on and off?????
- Odd puddle under car
- Major problems - any clues?
- Cold start thumping
- First rx8 problem
- Driver's Airbag/horn cover removal
- I'm screwed. please help.
- Rear Bumper falling off
- new to the site
- Air Conditioning Problem
- Why is my car growling at me?
- engine light?
- engine prob
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
