PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 [15] 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. RX-8 dies when stopping, only after driving for a while and won't start up again
  2. Weird clutch problem
  3. Engine light on
  4. I't over heated.
  5. RX8 shaking
  6. Advanced Keyless Entry Remote issues
  7. No Power, no codes.
  8. PA Inspection - failed emmisions due to cleared computer...
  9. Clutch pedal does nothing...
  10. Help! Pictures included...
  11. Nav location issues
  12. Clicking Sound
  13. Catalytic Converter Issues!
  14. My most recent Epic Fail
  15. No power.....
  16. CEL but no code found with scanner
  17. Just a Quick Question about Air Pump
  18. Someone please help!
  19. Strange Problem -- At least to me
  20. Grinding in Power Steering
  21. Passenger side window/ lock not working
  22. K&n aintake help
  23. Engine and Cigarettle Lighter?
  24. Mazda fuel pump assembly
  25. ok odd misfire can't quite figure it out
  26. New Cat Glowing, Misfires And Rough Ide Acceleration
  27. Help stranded near grand canyon car died
  28. warm A/C issue.
  29. Finish rebuild,car starts, car revs, but wont hold idle.
  30. Can any one recommend RX8 mechanic in Hampshire?
  31. 2004 RX-8 pulls left upon accel., right upon decel
  32. Dead LED on Remote Key
  33. Metallic rattle when going into gear and vibrations at idle
  34. New engine and mystical misfire
  35. stainless steel brake line leaking.
  36. bearing noise and not from transmission
  37. injectors
  38. Trouble shooting stereo
  39. Running rough after it gets warm? Coils?
  40. induction kit problem
  41. Car losing power
  42. car stops in reverse gear
  43. Car stalls
  44. Check engine light
  45. DIY urethane motor mounts question
  46. Oil pressure drops
  47. P0410 and struts? help(I researched but couldn't find answer)
  48. Ticking sound when accelerating about 4000rpm
  49. power?
  50. "cylinder" 2 misfire
  51. CD Player/RCA Input not working
  52. Spark plug seized! oh no!
  53. What is wrong with my car (slow but not low compression?)
  54. P0139
  55. Center console sliding clips replacement
  56. new engine ?
  57. New RX8 owner
  58. Oil Problem (or not?)
  59. help 04 rx8 not starting socal
  60. Motor mounts question?
  61. PCM. CEL No Code. No Power.
  62. Yes another P0171 thread
  63. Capping the VFAD valve
  64. my04 rx8, Weird rattlesound?
  65. Clanking/Clicking sound upon acceleration, codes P0076 and P2259
  66. easy on the flames... please
  67. SSV CEL after oil change?
  68. Car idled until fuel gone, battery dead....
  69. Misfire above 6.5k when I put my foot in it.
  70. Low Compression??
  71. Multiple CELs. 301/125/171
  72. my '04 is not starting (need help asap)
  73. I need to change my motor mounts. I heard they have Polyurethane ones?
  74. Rx-8 not starting
  75. 2007 Electric Steering making a noise
  76. Trying to figure out what is going on
  77. smoke at high rpms
  78. anyone know of a rotary specialist in LA?
  79. My misfire story
  80. Rev up to 8k.. then severe loss of power, and warning light. Several other issues too
  81. DSC, ABS & Cruise shut off when headlights are turned on.
  82. Compression Test Intrepretation Help Please
  83. Gauge and Power Issues
  84. What's my next move?
  85. Quick exhaust question
  86. Leftover cat debris in exhaust
  87. stalling when on split journey..
  88. Faulty headlight washers
  89. 05 Auto, weird issue at 3rd gear, need change auto tranny fluid?
  90. clutch problems? (vid included)
  91. clutch problems! help!! please!
  92. !!Please Help --- Car won't crank after flywheel/clutch install
  93. Clutch problems!!!! Help
  94. Stereo issues
  95. Something Fallen Off Car?!?
  96. Emergency alarm won't shut off!! 04 RX-8
  97. Help
  98. Blown Engine Warranty Issues
  99. Frustrated New Member
  100. Stumped with ABS/TSC doesn't stay on
  101. Clutch engages smother now???
  102. loud squeak on first start after 2 day sof not running and very very cold conditions
  103. Weird chattering sound at idle?
  104. HEEEELP P0171 code
  105. Slave cylinder grease questions, clutch squeak
  106. Oil pooling btwn intake runners
  107. Drifting the RX8...issues?
  108. P0420, o2 sensor, & gas choices o.O
  109. 4 CEL codes, looking for help
  110. Rx 8 alarm
  111. start problem
  112. Heater stopped working
  113. Power steering problem...
  114. Voltage Issue: Alternator, battery, PCM, or wiring going bad?
  115. Gear changing issues
  116. Engin Light on after replacing ignition coils on 2004 Mazda RX8
  117. Engin Light on after replacing ignition coils on 2004 Mazda RX8
  118. About the EVAP test
  119. what did YOU pay for programming keys and/or ABS at the dealer?
  120. electrical issues, cd player,
  121. Back Of Steering Wheel Broke
  122. Speakers going bad ??
  123. Lots of issues
  124. Gasoline smell in cabin
  125. Drl
  126. Red Fluid on Calipers
  127. No power, won't rev.
  128. Coolant going empty every couple days
  129. Over bumps, Nearlly ALL warning lights on dash illuminate
  130. fitting on Thermostat housing leak?
  131. Doesn't want to hot start..?
  132. Lots of codes after flooding. Starting jitters when cold
  133. Car Wont Start- Please Help
  134. Bad day = no more motor
  135. Little too much oil. Can I remove some?
  136. 2005 RX-8 Starting issue and air pump issue.
  137. Wont accelerate when WOT
  138. Pulling P2004 code - APV stuck open
  139. Power Steering Failure help.
  140. AT Brake pedal and MT Brake Pedal compatability
  141. Possible Hydrolocked RX-8? PLZ HELP!
  142. Car wont turn on
  143. variation of metra problem
  144. Complex Problem Starting, then Overheating Exhaust
  145. Car drove fine now wont start
  146. Air bag light 5 flash pause 1 flash O.o
  147. Acceleration Issue
  148. Need some opinions, grinding sound in my 8.
  149. RX8 wont start
  150. CEL with no codes?
  151. Weird startups
  152. p0171 that wont go away help!!!!!
  153. strange fluid in my air filter
  154. PREMIX High RPM bog/grind - (not your average "help me" thread)
  155. Need Help with My 8
  156. My RX8 is goosed
  157. Bad misfire only when cold
  158. Help 04 rx8 wont start!!!
  159. Replacing Radiator Fan assembly
  160. idle rough, tries to stall after o2 sensor change
  161. Misfire code P0301
  162. Starting Issues: Some like it hot, some like it cold.
  163. Misfire in cylinder 2
  164. Rough idle, popping/sputtering exhaust, sounds and feels off...
  165. Milky dip stick(i know its been asked before)
  166. rx8 wont start
  167. cel went on.. help
  168. MS CAI to stock intake-Help
  169. Multiple Issues!
  170. Problem with engine starting, as well as abrupt shutoff when turned off..
  171. 2005 rx8 hard start
  172. Newly cutted fob blade is not cranking the engine
  173. Could it be a broken hose??? Help
  174. Won't start after replacing the Upper Intake Manifold
  175. Turbo'ed 8 won't rev past 8000
  176. Total stupidity- I ran my rx-8 out of oil now it runs like crap
  177. Brake grinding noises on application
  178. HELP! Reving Idle in Park (2005 RX8)
  179. extremely weird electrical power issue!
  180. Fuel pump maybe??
  181. stalling when rev
  182. Tan Grease in the oil
  183. 2006 RX8 rough idle
  184. Clutch Issues
  185. Help ( o2 censor maybe?)
  186. Electrical Problem Heater, A/C, Defrosters, Temp Display Out!
  187. Heater problem, AC too
  188. DSC comes on
  189. Electrical problem, alternator or bad battery?
  190. Started then died within 5 seconds.
  191. Small annoying problem
  192. Sluggish Start/No Power
  193. Cel
  194. Diagnostic Codes
  195. Coolant light (not the standard problem)
  196. Weird Noise in cold weather
  197. Another Steering Issue?
  198. Power Steering Electronic Control Module
  199. Water in trunk/taillights (resolved?)
  200. Help Clutch and LEAK!!!!
  201. Stuck Throttle Body valve after de-flooding procedure
  202. Arggghhhh, I need help getting parts
  203. (help) fire sparks came from the exhaust then engine shut off
  204. Fix for engine stall after battery disconnect
  205. engine stalls when revving
  206. Starts fine, but trouble re-starting
  207. Hot starting problem
  208. is this a possible clutch pedal problem?
  209. Won't start - very weird electrics
  210. Huge oil leak !!
  211. maybe one of you can diagnose this noise?
  212. rx8 intake purge valve broken
  213. Front wheel lugs getting loose?
  214. Engine will die when the clutch pedal is pressed
  215. Window noise....Sorry I posted in DIY first
  216. Thermostat O-Ring Question
  217. The Saga Continues... Several codes now....
  218. Knocking sound coming from rear over bumps
  219. This piece looks broken...what is it?
  220. 2004 rx8 car stalls when hot in stop and go
  221. HELP! transmission problem HELP!
  222. A/C is kinda weird
  223. 2004 RX-8 Won't Turn Over
  224. rat ate the rx8....
  225. Help =/
  226. Power Loss, V-tec sound when acceleratin above 6k. In much need of help.
  227. Help Please (Clutch Blown)
  228. CD player
  229. Compression Ratings
  230. Front Rotor Misfire
  231. Help! Please!
  232. RX8 Tractor!
  233. Need help with head unit
  234. Keys?
  235. You know where this goes?
  236. Couple of issues with the 8 and need some help.
  237. Misfire CEL, BHR Ignition, some troubleshooting already done...
  238. Strange Flutter noise
  239. clutch problems?
  240. Engine burning off oil too quickly?
  241. alternator?
  242. Rx8 stalled at lights never started again?
  243. Hot restart= ABS and Traction lights
  244. No ignition on front rotor
  245. 1st gear reverse still grinding after new clutch install
  246. intermittent CEL
  247. motor turns and turns won't fire over
  248. help please
  249. Help with Rebuild - what can I get away with not replacing
  250. Rx8 p2096 again !!
