PDA
View Full Version : Series I Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45
  1. Whistle like noise when starting
  2. Help please
  3. Warm engine flooding?
  4. Possible cpu problem, the idiot lights are going off and I dont know why!
  5. No more power after 8500rpm since mazdaspeed cold air intake...
  6. Overheating. No fan?
  7. Intermittent CEL
  8. My car stopped at a highway exit! OMG
  9. Air filter / Throttle body vaccum connector
  10. loud clunking sound from passenger side
  11. URGENT - Rusty spark plug threads (real not BB type!).
  12. Lubricate Throwout Bearing?
  13. Wont start just clicks had to push start
  14. temp control fix
  15. Engine No Crank, Electrical Issues
  16. Drivers Side Door Will Not Unlock
  17. Sudden starting failure - don't read if you don't want to!
  18. Hesitation and Dying when car is warm.
  19. Splash Guard
  20. o2 sensor now have to get 7 rpm out of 1st
  21. rear HUB STUD replacement
  22. Weird marbles in a can?
  23. MPG and Air pump relation?
  24. help
  25. RX-8 start problem: strange noise
  26. Low power in low rpms... New Engine
  27. Is the occasional "long crank" thing normal?
  28. Trouble starting, CEL is on
  29. Flooded?
  30. A/C not blowing cold air
  31. 05 RX-8 35Kmi. Sputtered, stalled, CEL low power
  32. Daylight running lights
  33. DSC /ABS Woes....
  34. Every single dash light on
  35. If you go catless, will you smoke a bit?
  36. Idle but dies on reving
  37. Bose System - One speaker's bass cuts in & out....
  38. Trouble With RX8
  39. How to clean abs sensors
  40. always throw me to limp mode :(
  41. engine idle problems
  42. Hard Starts, especially with a warm motor when its Cold outside
  43. "Honeycomb structure's been removed from your cat?"
  44. Clutch Assembly?
  45. Front Driver Side Bose Speaker Plays Only For A Bit
  46. Hive Mind: Raspy growl at 4-6K, 2nd-3rd gear...?
  47. grinding in and out of 5th gear
  48. Compression Test Results & CEL
  49. winter storage battery question.....
  50. Car will not start, no spark from plug need HELP!
  51. tons of smoke
  52. Did I destroy my gauge cluster?
  53. 04 rx8 overheating help!
  54. Need help with a DTC ***P2123***
  55. No start when warm?
  56. Two problems with my 8
  57. Battery issues even after main fuse replacement
  58. Engine wont turn on after replacing new parts
  59. A/C Blowing Warm
  60. Newb: Starting procedure and flat spot question..
  61. Steering Problem
  62. Adjust Idle
  63. possible bearing or diff failing??
  64. engine smell awfull!!
  65. on restart--major loss of power, flashing CEL, stall
  66. engine running poorly after putting on Lucas deep clean fuel system cleaner
  67. Can anyone identify this?
  68. Headlight help
  69. 04 UK RX8 Limiter?
  70. 2004 RX8 Side marker corrosion and wiring question.
  71. How do I clear a misfire code?
  72. WOT = Engine dies.
  73. hids
  74. Engine Mount or other issue?
  75. My rx8 dies while driving.
  76. Problem with brakes
  77. Any other ideas?
  78. New Owner - CEL :(
  79. Did something stupid, so please put my mind at ease
  80. Master cylinder problems?
  81. Help! Radio/display not working
  82. Reverse light switch
  83. lack of power
  84. Could overflowing Coolant on the power steering harness cause other electrical issues
  85. master or slave cylnder
  86. A/C clutch assembly problem
  87. oil coming from exhaust HELP!!!
  88. Halp! CEL..
  89. steering wheel is not straight
  90. light in dash board
  91. 2005 mazda rx8 please HELP!!
  92. Michigan Help
  93. Locking A/T Issue
  94. Secondary Air Pump disassembly and reassembly?
  95. rx8 CEL and vacuum lines
  96. Cruise Control issue?
  97. Live feed data interpretation help?
  98. Another Won't Start Thread (Oh Boy!)
  99. antifreeze leak
  100. turn signal hazard lights not working
  101. Sunroof problem, thanks for any input
  102. Pulling code
  103. Help! I cant get my ECU out!!!!!
  104. sounds like a blown exhaust
  105. Rx8 running sluggish..PLEASE HELP!!
  106. Car squeak ???
  107. Help Rotor speeds issues :(
  108. How am I doing with these compression #s?
  109. Car squealing and Radiator Light..
  110. Potential dangers of running idle for an extended period of time?
  111. Fkn Driver Door jammed
  112. Motor sound help needed please
  113. My Spare Key, Aint much of a spare key.
  114. no power lock on passenger door
  115. Help!!!
  116. Will turn over but no fire - not like every othey no start post!!!
  117. Please help. Fuel issue? or???
  118. Hot start issue - 2004 RX8 (UK Owner)
  119. Car turns over a few times before it starts but the battery if fine..any help??
  120. Headlight Auto Level Malfunctioning
  121. Engine codes
  122. Overheating... Help
  123. Engine light on after New Engine? WORRIED
  124. clutch pedal removed. no engine start
  125. Where is the TP sensor on a 2004 mazda rx8
  126. Power Loss, blinking CEL, rough idle....
  127. Dash light on, plz help
  128. Power loss after Mid Pipe install
  129. Front end Pieces
  130. Hard start and faint burning smell
  131. Lack of power, stalling, pinking noise and more
  132. 04' RX-8 Check Engine Light (Engine replaced)
  133. Ignition coil failure
  134. Parking Brake Loose
  135. Searched: Key fob doesn't unlock doors
  136. Scraping sound while turning
  137. Alignment and suspension woes
  138. any help would be great
  139. trouble removing eccentric shaft bolt
  140. Cylinder 1 misfire
  141. Noob and low compression thread
  142. What is it?
  143. Starter motor wiring issue??
  144. Check Engine Light
  145. Yet another stalling/rough idle thread after battery disconnect
  146. Rx8 Vacuum Cleaner startup
  147. Coolant blown out, engine blown?
  148. Possible Stalling Issue
  149. Reset oil pressure?
  150. can i have 1 different ignition coil?
  151. Starter wont come out?? Help
  152. Startup Issues
  153. quick coolant line question
  154. Bad Engine?
  155. Hard starting...What's my next step?
  156. Central panel help 2004 rx8
  157. New coils but still unstable timing light?
  158. A/C not cooling
  159. Unwanted noise from gearbox/engine
  160. Engine shut off when stopping/running rough all the time
  161. LOUD Clicking noise coming from top of engine
  162. blown apex!!!
  163. low compression code
  164. not your normal low coolant problem!!!
  165. Low oil pressure + engine overheat fast
  166. Clicking under load
  167. Won't Start After Storage
  168. Car has a "dead" miss! Please help.
  169. bad accelerating issu
  170. Temp Control Intermittent
  171. stock navigation black display
  172. Oil filter removal prob.
  173. water pump problem?
  174. oil flow/lowrmp studder/rough idle
  175. weird sound
  176. Cat issues
  177. Engine Coolant Level Dropping Quickly Daily...
  178. weird sound when idle at neutral
  179. Vibrations
  180. Skid Plate Missing Bolts
  181. Synchro issues
  182. Strange turning
  183. Weird rattling, squeaking noise
  184. Sourcing a front caliper bracket - seized slider pin's
  185. wont start after storage
  186. Smog Check Failure - w/ New engine
  187. not starting
  188. air conditioning problem please help
  189. Fumes in Cabin
  190. Battery Relocate Problem
  191. engine will not start
  192. Radiator coolant stays "ON" from engine start.
  193. engine light flashing then went solid
  194. Cel p0410
  195. Loran - Low coolant warning & airbag warning lights
  196. car dies at idle once warm
  197. Resonation @ 45 mph
  198. random misfire
  199. Idle dip hose cracked help
  200. Rx8 helppppppppppp?!
  201. New RX-8 owner with few problems
  202. Some transmission/clutch issues
  203. Hallelujah - flooded startup
  204. Engine Coolant Light problem?
  205. torsion bar??
  206. Ice bits coming out of A/C
  207. troubled 04 rx8
  208. CEL mystery
  209. Electrical issue - intermitantly flicking lights, power steering, cd, lights, dash
  210. please help-cooling system issues
  211. RX not running smoothly???
  212. Questions and Confirmations
  213. weird engine revs
  214. Clutch/Transmission Issue
  215. New 2004 Rx8, 80,000 miles several issues..
  216. Tapping sound under plastic intake manifold
  217. Wire tuck, no start
  218. 2nd gear grind when cold after transmission fluid change
  219. Transmission issue...Please Help!
  220. Car won't start
  221. 04 rx8 not starting
  222. spark plug concern
  223. New Rx-8 owner
  224. Secondary air system
  225. Car completely dead, disconnected/reconnected the battery and it was fine.
  226. Diagnostics? What do you use?
  227. Fuel Pump Issue?
  228. 05 RX8 is eating batteries.
  229. Retractable Key Problem
  230. No codes says error, Security key flashes
  231. Everyone's favorite, clutch pedal issues
  232. Can't shift into gear - what is going on?
  233. Stalling Auto?
  234. Anti Roll Bar links
  235. clutch help?
  236. This may seem obvious to some.
  237. Car won't start. PLEASE HELP!!!
  238. Coils suddenly stall when running normal 60km/h
  239. Clank when braking in reverse
  240. Strong Gas smell while car is sitting idle?
  241. Just bought an rx-8 with a couple problems
  242. Pcm: U0073, ic: U0019, eps: U1900, rke: U1900
  243. Huge Oil Leak!!
  244. 2005 RX8 flooded engine - please watch my engine startup video and help me diagnose
  245. Transmission/Motor mount? need help
  246. Creaking/rubbing/rattling sound RT REAR seat area????
  247. Creaking.. Maybe?
  248. Repeat Flooding - with a twist...:(
  249. Radio/CD buttons not working.
  250. Coolant leaking....is it mixing with oil???
