View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Massive loss of power
  2. Please Help with Engine Diagnosis
  3. engine trouble need help please
  4. PESKY Cel Question Hope for a Resolve?
  5. Quick Cel question poo37
  6. numerous issues
  7. Brand new engine, heard a clicking noise while reving..
  8. Help.. TPMS?!
  9. RX8 Wont start after flat battery
  10. New Engine Problem
  11. where can i find this for cheap?
  12. Center Console not working in Hot Weather?
  13. Violent Clicking at startup - Urgent
  14. Shifter misalignement
  15. Blinking CEL on hard accel, misfires when cold, even at 4k
  16. ah! the infamous P0420 code! what now
  17. Problem diagnosing - Please help
  18. where does the middle intake breather hose connect to the engine?
  19. Having some problems with my 8....
  20. Weird trouble with HID WIRES, wouldn’t turn the car off!!!!!!
  21. Weird Idling and Shifting Problem
  22. Need help
  23. My Rx8 is dying at stop lights, but only after running on the highway
  24. Yet Another Power Steering Issue
  25. Low level coolant warning light
  26. Need help from local member who knows transmissions well
  27. No traction control button?
  28. Rebuilt engine problem - Please help :(
  29. Steering issue
  30. Weekend Install Problems
  31. battery goes dead
  32. Rotary Heaven
  33. cat throwing a cel, time to replace?
  34. $400 power steering problem
  35. power locks problem
  36. help !!! wont go into gear
  37. head light ignition?
  38. P0420 and overheating
  39. oil light & 236 degree water temp
  40. Serious Misfiring
  41. Weird performance in third gear...
  42. acceleration sloww...0-60 in 15 seconds??
  43. airbag light
  44. 3rd to 4th gear grind
  45. Dealership changed cat=exhaust sounds way different?(examples inside)
  46. Noise in the rear axle when I remove the foot from the accelerator
  47. no clutch pressure
  48. progress anti-sway bar bump noise fix
  49. Carbon Lock and, or Flooding
  50. Mystery issue stumps dealer.
  51. "Wet" Spots on engine plastics after autocrossing
  52. Intake Manifold Carbon Buildup
  53. Agency Power sway bar bracket broken
  54. Running rich
  55. Help! Oil in air filter!
  56. RX8 CEL Codes P0204 C1604 C1503
  57. Bad engine casting?
  58. Electrical Problem
  59. alternator problems?
  60. Radiator Light...?
  61. Clutch issues
  62. Gas Cap Fix.
  63. damm cel
  64. Clutch bracket problems
  65. Snapped my ebrake?
  66. Car not responding to keyless entry
  67. sputtering at 6k and CEL
  68. CEL and too much oil?
  69. Normal????
  70. Driver car seat went all the way down automatically!
  71. Low compression in 1 roter.. What should I do?
  72. my engine coolant light.
  73. Need help URGENT
  74. hazard fuze??
  75. another sputtering prob..
  76. Weird rev limiter like issue
  77. New engine in my new 8
  78. engine overheating?
  79. Hmm....no turn signals?
  80. no low-end power...
  81. strut bar bolt broke
  82. p0117 CEL and overheating issues?
  83. Brake Noise At Low Speed Turn
  84. diy to change the coils?
  85. Car wont start Question.
  86. Just got new engine, but AC no longer works.
  87. AC Drain Location???
  88. RX8 track coolant temperatures
  89. p/s issue
  90. Drivers Door Stuck!!!!
  91. Brand new rx8 owner!! Need some help
  92. Heated Seats
  93. Is clutch bracket covered under extended warranty?
  94. Clutch made noise, now soft spot
  95. Car doesn't turn over, click, or start...stereo and lights don't turn on either ???
  96. Is this normal?
  97. No power after 2 weeks ownership on '04
  98. Spark Plug Cracked!
  99. Oil light
  100. Why does my fan stay on
  101. CEL on...Rough Start?
  102. Question about spring install.......
  103. CEL code for small Vacuum Leak
  104. Clunk or pop when turning
  105. Interior lights won't turn off
  106. Why does my 8 feel like it's going to die
  107. Grinding noise
  108. My RX-8 seems to be possessed
  109. transmission / clutch noises ? video
  110. Excessive debris getting sucked up by cabin filter!
  111. Something draining battery and kills engine no idea what.
  112. help rotor thudding?...
  113. HELP, My MT 8 revs like an AT in low rpm!!!
  114. Code P2259
  115. Potential new 8 owner. Concerns....
  116. Bad idles only after driving?
  117. hazy/foggy Gauge Cluster
  118. Strange Buzz Then Hissing Noise Near Rear of Car
  119. Odd Idle when AC is on.
  120. Problem with my 8
  121. Is this normal? Servo noise from TB.
  122. AF guage wont turn off
  123. Low coolant indicator at 160km/h run
  124. Need Help
  125. WTF is a VDI solenoid valve control circuit?
  126. Burning rubber smell
  127. Dozer Needs Help, cluth feeling loose
  128. Sputtering
  129. P0336 came on.
  130. Urgent help
  131. engine & tranny problems
  132. Ranned Out gas problem
  133. Oil in air filter
  134. failiure at springs
  135. MM Greddy turbo Hardware
  136. Stock oil light turning on ( in hot weather)
  137. Car bogs when Full throttle
  138. Can't figure out my rough running/stalling!
  139. Engine Number Three
  140. traction control problems
  141. Can't read codes?
  142. Help removing the thermostat
  143. temp +36 problems
  144. screw holes on rotor threaded?
  145. Hard rear shaking starting out?
  146. starting and idling issues
  147. Engine *may* be overheating?
  148. Car doesn't do well in the heat
  149. my 8 has factory massage chair, I know I am not the only one!
  150. Metalic vibration at 3500-3750rpm, only in gear...any ideas?
  151. can someone in the bay area come look at my car? it won't start. Redwood city.
  152. exhaust problem?
  153. White Smoke!!!
  154. Idle problems...
  155. radio blackout...help!
  156. Power steering failure?
  157. Mazdaspeed Exhaust failure (no warranty)
  158. New gas cap for 05 is far superior to old
  159. 2nd Gear Feels Weak
  160. Center display problem
  161. Heat related issues?
  162. Intermittent P0171
  163. Does anyone know if this is true!?
  164. Dealer says swapping leather seats in for cloth = no heated seats!
  165. OIL leak
  166. Help gr3ddy! I haz electrical problem BAD
  167. Wierd knock/rattle issue
  168. Missing a Cap Please Help
  169. VFAD Solenoid - somethings snapped off
  170. car won't turn over
  171. Intermittent Starting Problem
  172. VERY INTERESTING PROBLEM... anyone care to advise
  173. Check engine light!!!!help!!!
  174. blinking ignition security light
  175. Battery change question
  176. Help needed...dash info display problems
  177. weird whistle/chirp when i accelerate
  178. Rough Idle
  179. Coolant Light has been coming on at a weird time
  180. Oil cap stuck
  181. replaced rear tires -TCS/DSC?
  182. Touch-Up Paint Nightmares
  183. Clutch Pedal (breaking/snapping)
  184. idling lean, Bogging at dle
  185. Misfires at highway speeds when decelerating?
  186. Fog light help
  187. Loss of power....2-3 seconds crank
  188. bad day.. car on the side of the road
  189. Exhaust Leak cant find
  190. Assistance Needed
  191. engine dies out after high rpms
  192. Major E-Brake Problem
  193. Another Wierd Idle Thread
  194. i think my clutch is gone
  195. Shutter Valve Question
  196. Help me diagnose a starter problem please
  197. So I think I killed the battery...
  198. traction control engaging brakes in reverse?
  199. Please help with headlights...
  200. Fast Blinker Fix (LEDS)
  201. Need to find a temporary wire reroute for parking brakes.
  202. AC Amplifier Question
  203. metra kit installation
  204. Rear Main Seal Leak
  205. Power Loss and Smell
  206. clicking noise in engine area?
  207. Strange car vibrations when accelerating
  208. Engine Warning Light!
  209. compression problem?
  210. APV position
  211. Greddy Turbo/Intercooler Issue
  212. Holy crap! Mazda service issue and Engine replacement
  213. turbo from rx7
  214. Fuel Fill Flow Back
  215. Flashing CEL... that goes away?
  216. Gas mileage gone bad all of a sudden?
  217. Check enigne light - code PO301
  218. mazda-parts.com??? :(
  219. Ticking on boost?
  220. Cold Air intake
  221. metra kit installed-- clock problem
  222. Coils, Plugs and Catalytic Converter
  223. New coils
  224. Are these signs l need new coils?
  225. something wrong
  226. COolant level light
  227. sea foam/engine light
  228. Issues with Battery....
  229. I smell chemicals in side my car when on a light
  230. headlight buildup
  231. Help with identifying engine hesitation
  232. I NEED HELP BAAADD!! Intake Screens
  233. Tachometer Problem
  234. Clogged cat
  235. Temp Woes... Need help with solutions
  236. Loss of Power on hill?
  237. Gearbox problems?
  238. Knowledge Needed!
  239. Any ideas?
  240. Phantom Problem....engine immobilizer
  241. Noise when clutch is pushed, from outside car (not braket!)
  242. Second alternator in one day, Help Quick Please.
  243. Please help. Replaced alternator, new battery, Battery light still on
  244. Help!
  245. Racing Beat Sway Bar Bushings Dry W/ No Grease?
  246. Tracing an engine oil seepage
  247. factory scissor jack seized
  248. Engine Overheating?
  249. Burning rubber smell after hard driving
  250. 3 brake pads match and 1 is different
