View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 10 11 [12] 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. Engine knocking
  2. power loss
  3. help, ABS light, traction control light and brake light come on when I hit 80mph
  4. If your battery dies, can you pop the clutch on the 8?
  5. Need some insight on a problem with my 04 rx8
  6. Front Main Seal, OC2, and coils
  7. Speakers/bass problem?
  8. Large emission leak
  9. Jerky accel/decel on all gears/speeds
  10. need help car turns off on its own
  11. Remote Locking problems
  12. Backfire problem
  13. Clutch Slipping, need replacement
  14. Troubleshooting Starting Issues
  15. Help..
  16. so i need some help
  17. TPMS trouble
  18. Hard To Shift out of 1st
  19. Warning Light
  20. rust?!?!?!
  21. Can bad spark plugs throw a CEL?
  22. check engine light help
  23. Coolant light
  24. Problem continues: No power while accelerating, car stalls too!
  25. Semi-Manual help!: I brake hard, but why do I hear grinding when I do?
  26. mazdaspeed cold air
  27. Flooding covered by warranty?
  28. Weird sound coming from mid exhaust area
  29. Car Stalled After Oil Change
  30. Warranty issues
  31. 2nd gear issue
  32. trunk release button stuck?
  33. Problem after clutch swap..
  34. Humming sound when off
  35. DAMMIT! chopped a fuel pump wire!!!
  36. Tranny problem Error CEL code P0748 P0758
  37. HELP 05 won't start make funny sound
  38. Power Steering out after amp install ???
  39. TPMS Limp mode?
  40. Help:Leaking hose on top of fuel pump!
  41. car won't start after deflooding procedure
  42. shaking under 2000 rpms
  43. Blown Engine? Main Seal? Opinions?
  44. Car possible intake problems
  45. Intermittent trouble starting
  46. Headlight Issue
  47. Trip meter problem. I'm stumped.
  48. Oil in Air Intake 2004 RX8
  49. 04 RX8 Error: P0336
  50. CEL P0410 and 60amp fuse blown
  51. Keyless entry doesn't work
  52. 06 RX-8 won't start
  53. HELP! Lights and ACC on but Car will not even crank!
  54. Random Flashing CEL at High RPM's
  55. got my u flash!
  56. Voltage problem? New starter.
  57. Car won't start is it covered under warranty
  58. Viper 5701 Responder LE 2-Way Security and Remote Start System
  59. several problems NEED HELP!
  60. Really hard start after long day of highway and NYC city driving
  61. Intake Valve Stuck?
  62. Car won't turn off!
  63. Driver's Seat Loose
  64. Missfire
  65. Wtf is this?!?!?
  66. 90 mph or higher get vibrations
  67. No Heat or Cool Air?
  68. Tail light out (side flare thing)
  69. P0420 Catalytic Converter?
  70. i think the dealer is f in me over
  71. Airbag Code 23 (DTC B1996 - 1999)
  72. Clutch/Flywheel Replacement Experience
  73. ABS, E-brake and traction control lights all at once?
  74. Possible coil problem, Will not start?
  75. Another Engine light thred, my prblem and one wierd coincidence
  76. Navigation Issues
  77. heater problem wierd
  78. BAD DEALER. not sure what to do..
  79. Engine tapping sound?
  80. recall question?? help..
  81. No start - Assistance please
  82. cel for cat
  83. Help. Overheating at idle
  84. Oil in cai
  85. 2004 AT with vibration
  86. Oil catch can installed-still get oil in CAI !!
  87. no power...from an rx8 ?!? please help
  88. Burning Coolant and Deposits Color
  89. help chosing a clutch
  90. starting issues
  91. Is something wrong?
  92. Flashing CEL, then solid CEL (cold starts)
  93. my clutch is weird.... clutch slipping!!
  94. Another engine replacement
  95. Day time head light questions
  96. Acceleration and horrible noise porblem when going above 5500rpm
  97. Engine Hesitation
  98. Help please power steering
  99. Need help!!! Oil for RX-8....
  100. Smoke, And Slight Hesitation
  101. Front end noise
  102. Blowing Fan Fuse, Overheating
  103. 2004 rx8 AT problem
  104. Engine rev up problem.
  105. Weird smell after high rpm
  106. Car pulls left under acceleration @ highway speeds after new Tires installed
  107. Fuel gauge problem
  108. Sway bars causing rocking noise?
  109. Advanced Key problem in 2006 Shinka
  110. Power Steering ECU Problems...
  111. issues with stock clutch...(i need help...)
  112. Another HELP thread !!
  113. radio dont work
  114. Dashboard lights on after accelerating
  115. Gears ???
  116. Sulfur smell when driving with windows open
  117. Accidently broke 1 of the 3 hoses for intake
  118. P2259 - Locating the AIR Solenoid
  119. Suspension Replacement Part Names
  120. Sylvania SilverStar
  121. burning rubber smell...from the engine
  122. Quick/Minor question.
  123. Missing at high rpm and acceleration?
  124. power steering
  125. secondary intake?? Again??
  126. oil light
  127. P0139 during hot weather
  128. Weird sound/squeaking
  129. overheating issue NEED HELP!!!!
  130. ongoing problem. i'm tired of this.
  131. Help please
  132. Strange Sound When between 7-9 RPM
  133. Pulsating brake squeaking... warped rotor or dragging brakes?
  134. Dash battery light stays on
  135. unstable idle, where's the likely problem?
  136. Need a Slave/Master Cylinder? Cant get RX8 into gears when car is warm!
  137. Stalling while idling on upslope
  138. Help!!!
  139. Dealer covering bad clutch installation
  140. Strange Whine?
  141. lack of power and p0037?
  142. P0131 causing P0302? Thoughts?
  143. Diagnosis help
  144. Frayed trunk wire (3rd brake light)
  145. 8 won"t start.....help!!!
  146. Display Console Intermittent Electrical Problem
  147. Rough Shifting in 2nd and Reverse
  148. Hesitation at Start up
  149. car just died
  150. Transmission Issue Warrenty Fail
  151. Passenger power window - thunking noise
  152. $2000+ to get car running after storing for 8 months=severe rectal bleeding..
  153. losing brake fluid...
  154. Oh the stickies!
  155. weird new noise after 8k
  156. Car stalling while driving...
  157. ABS and Brake Light
  158. brain trust needed
  159. Does this seem compression related?
  160. I have no heat help me please!!
  161. electric help. headlights very dim.
  162. Gear whine + weird sound when shift 1-2 then 2-3
  163. Panic alarm
  164. problem with greddy turbo kit.
  165. abs and dsc dash lights come on after moderate braking
  166. Bank 1 Too Lean and Where does this plug go?
  167. Change rear wheel bolts
  168. SRS light
  169. 04 Rx8 TRANNY, HELP ME PLEASEEE
  170. I have to jump start my car everyday
  171. dash lit up like an xmas tree
  172. Shift Fork TSB?
  173. Revs stop at 6.5 K every now and then...
  174. Clutch Slave Cylinder Meow??!!?
  175. Need help starting problems help
  176. Check engine light P0171, P0302
  177. HELP!! Weak Acceleration Under 4000 Rpm
  178. vibrating problem -__-
  179. a few issues
  180. Liquid to Air intercooler
  181. HELP!!!...Exhaust manifold Clamps
  182. Coolant light comes on when at high Rpm
  183. Anyone know what this problem can be?
  184. Hot engine?
  185. Rattling inside of Muffler
  186. Going From "Park" to "Drive"
  187. Engine clicking - Related to AC
  188. Starting problem :(
  189. Clutch/Gear issue
  190. Something is rubbing, but where?
  191. !!!!!!!!!!!!!!!!!! Oh my god
  192. Tail light getting humidity
  193. Right turn woes
  194. Rough Idle
  195. Audio link & Warranty
  196. Knocking after Agency Power adjustable swaybar link install
  197. Loose Cat Heat Shield
  198. 120,000 miles on my engine
  199. Idle Problems
  200. POWER!!!!! problems!!!
  201. radiator warning light
  202. Loose ground?
  203. Lost of power
  204. Installed BHR ignition Kit, now CEL flashing when hitting high rpms...
  205. Helppppp!!!
  206. Strange Power Loss.
  207. AC display not showing up?
  208. possible engine blow?
  209. Electrical Issue
  210. Greddy Exhaust - No sound in high RPM
  211. god Damn car!!!! wont start
  212. Throw out or input bearing ???
  213. DRL Diagnosis
  214. 2004 RX8 FOR SALE Port Washington, NY 11050
  215. Engine Shutdown!!
  216. Clutch Pedal Problem
  217. Help - Radio / AirCon / Information display fault
  218. Battery / Electrical problem
  219. Power loss + traction control light
  220. Airbag light is on
  221. Car wont start
  222. Need Your Guys' Help Desperately, Car Can't Start
  223. How to start your car when it wont start
  224. Sluggish Startup and acceleration
  225. Annoying rattle
  226. Check engine light - P0455
  227. thinkin blown motor... again
  228. front shock failure?
  229. Forgot to reconnect air filter electrical connector.
  230. Cracking/knocking above 5k RPMs
  231. 2005 in need of a new engine
  232. I need help/ opinions...pictures to help out
  233. My AC is confused goes from hot to cold
  234. Car 3/4" lower on driverside
  235. Test Pipe Trips Eng Light
  236. Power loss after going very fast on a long turning on ramp
  237. Vacuum line broken
  238. AC problems please help!
  239. Radio fire>
  240. A/C compressor almost fell off...
  241. Misfire at 4k ish. Not ignition?
  242. Rear window rattle
  243. help?! possible power loss.
  244. Catback Install - Cat bolt problem
  245. News to me... My 8 consume oil like a fat man at a buffet.
  246. Cant figure it out- idling like crap
  247. Ignition problems
  248. can't remove my endlink
  249. car wont start.
  250. Superior Curbing!
