View Full Version : Trouble Shooting
- Rattle coming from sunroof
- Flashing Engine light-P0130 error
- please help
- Burnt smell
- Crazy rattle from the back window/rear speakers
- Needed Help!!! Urgent!!
- ATF in intake?
- RX8 - 2003 - 231 - Check Engine Light
- door locks are crazy
- Typhoon V.2 Issue.
- RX8 - 231 - Headlight AutoLeveling Malfuncation Indicator Light
- I don't know what my wife did.....
- New battery causes problems???
- It only happens when its been cold out...
- Help P0139 what does it mean?
- NEED HELP! CEL codes P0125 and P0172
- Engine Inquiry --> water residue on my dipstick
- CEL w/ coughing and sputtering
- 04 rx-8 stalls occasionally
- how high??
- Popping the Clutch
- Help! Ignition Coil Pack/Flooding Need to Tell Mechanic what Repairs to make!
- Power loss and weird sound
- CEL - Bad Idle, Missing, Fuel Smell, Smoke - Help please !
- Can't get car to start, HELP!!
- glowing cat?!? Need advice please
- driving in the snow in ct with summer tires
- Weird noise
- burnt oil smell from exhaust...
- Engine won't start, sound like has no compression ! :(
- Need Help 04 8 wont start!!
- dipstick
- Car Putters during high rev shifting.
- Installed Greddy Turbo....won't start
- Major coolant leak!
- new guy, possibly flooded?
- ash tray housing removal
- Clutch/Transmission issues.
- with slight input of gas pedal, RPM drops..
- Oil Scent In Cabin after Tranny Oil Change
- 4000 rpm hesitation
- Engine Woos... milky white oil
- the battle continues!(advice needed)
- "tire" noise?
- rx8 wont start... IDK. HELP!!! PLEASE!!!!!
- Traction Control Light
- Auto Front bumper missing plastic, HELP!!!
- Whistle when starting
- RX8 Started then Quit
- Oil change killed my car????
- Engine acted like it wanted stall at light.
- WTF is wrong with the Heater!!!!
- o2 sensor turns into exhaust manifold
- Engine Coolant Indicator
- How do you change the battery for the 05 key?
- TPMS help
- Help I need insight on a p0300 code and a few others.
- CEL, plugs, wires, coils, fuel system
- Transmission issue?
- Leaking Coolant
- Oil foam solution from dealer...breather???
- Oxygen Sensor problem. Please help!
- Please Help!!!
- how many rx-8s have burned
- Fog light issue
- Alt/water pump belt ripped to shreds this morning
- broke mazsport ppf
- Just install AP pulley, CEL 300 came on? engine light blinks at 4000rpm
- Dead battery: can recharging while driving hurt alternator?
- Pioneer F900BT install issue
- P0420 and Catalytic converter that empty inside!!!
- OIL inside my intake tube of my rx-8?
- car broke down-help
- Aftermarket PCM Flash Service / New PCM firmware upgrade from Racing Beat
- Help! Hissing Noise
- Fault coedes. Who can tell me what they means?
- Aftermarket Radiator no mounting?
- Help, ball-joint below rotor issue....
- Help! Car Completely Blacks out
- Car Alarm Issues
- hvac blower making noise
- need help car sounds like wrx (greddy turbo kit)
- Possible fuel pump problem?
- Magic words to use when describing problem to dealer??
- Dealerships suck, where should I go?
- whats wrong with my car?
- New to RX-8 Got a few ?'s
- Blown Engine?
- Help please!!! CEL and 4k redline
- Need Help...Car Starting problems
- rx8 Flooded Engine
- CEL for Butterfly valves - / driving pedal position - Sensor A
- The transmission saga continues!
- Stalling Idle Problems ? Battery Light
- Tokico D-Spec popping noise
- o2 sensor WTFFF!!! 500 dollars?
- detonation, Fuel pump perhaps?
- Please Help NAVIgation has gone sketchy!!
- Help!!! Fuel pump???
- Is there any part of the radio that is connected to the navigation unti.
- Help fellas Another PO420 code What to do?
- Help, Heater Doesn't work
- 15 amp lighter fuse keeps blowing, how do I fix it?
- Grrrr!!!!! Transmission problem and bad service now!
- Help me diagnos my engine problem (video example included)
- Front passenger side underpanel bent by snow
- Engine Power measurement???
- Lights Messed Up - tail & reverse
- Need authorization from Mazda to open transmission?
- Will not open transmission.
- Technical request
- Navigation wiring harness
- navigation wiring harness
- BigRed's Car Died after 15k
- Agency Power Exhaust Issue
- starting problems
- Check Engine Light...!! (HELP)
- Airbag light fix
- red KEY light on dash, keyless entry antenna location
- Help! passenger side air vent
- 8 has been sittin, now got issues. Help?
- Plug problems
- engine cranks, but wont start...
- Intermittent Detonation/Pre-ignition
- I searched a bunch, wierd shifter SQUEEK.
- Possible transmission problem? Gear going out...
- Exhaust Gaskets
- Help, car was running fine and then it felt like the gear wouldn't catch
- ABS light and traction control light on after coilover install
- 04 Rx8 died and wont start back up
- one highbeam wont work
- Hot start issues?
- radio problems!
- Screwed up my headlight from smoking it...need HELP
- Help! Voltage Problem? (P0428)
- Engine Compartment Steam/Smoke after moderate range trips
- battery wires
- Clutch master cylinder leaking
- new engine?
- Car flooded/ WOW
- power steering problem
- Throw-out bearing?
- car wont start :(
- Engine stutters at around 5k on 1st gear...
- How to get at the Fuel Injectors
- Flooded FIXED! however start/CEL Problem
- Clutch Problems ... Limp ... Squeak ?
- Check Engine Light and Engine Coolant Light
- Rattle and Clattering noise
- Rx8 problems after being parked all winter
- P0302 code fix
- Frame Damage
- Car wont start: no cranking.
- car started, revved and quit//won't start
- Not really a problem... more of an update yay
- Headlight bulb question...wrong bulb???
- Intermittent "Check Engine" light after cold start
- Rough Idle and loss of power during certain rpms
- Few Questions
- Hard to put in Reverse
- re hard start
- Engine Light is on
- Car won't start in an underground parking lot
- Clutch engagement "Chatter" and smell
- Can not shift into 2nd gear when I am in high RPM
- i really need help with some issues help please
- P0420 Code, odd
- Major and annoying pob with my 8. Please help.
- Squeaky clutch pedal
- clutch bracket
- Newly Rebuilt Transmission Doing Same Thing
- Diagnosis Wanted
- Intermittent speaker problem!
- Clutch bleed... HELP!!
- Puzzling Navigation System Issue
- Help with Cat please ! P0420 Catalyst system efficiency below threshold
- finaly mazda is fixing my trans
- Squeaking
- what connects to this...
- 2004 Ignition System Upgrade Questions
- Jump Starting 04 GT
- Car Died, all CELs Illuminated
- My engine died while driving.......
- Rotor failing!!!
- plz help with this noise from MT
- Check Engine Light P0610
- Trouble finding OEM parts
- i hurt my car now what?
- weird huge sound when engine cranks to start
- 2004 VR RX8 w/ Engine+Tranny(sueing Mazda) Problems HELP PLZ!
- How to tell if I have a Exhaust leak???
- Serious Problem, hard to identify
- EGI CONP 1 fuse
- Pioneer avic 900bt
- Tien basic coilovers
- 2 problems. Oil light and cd changer
- Rotated tires-codes u0121 & u0155 show up
- mid-high rpm grinding noise
- CAT failure
- Tranny Hard to go into Reverse ?
- REALLY bad problem with my 8!! (please, read)
- where to start???
- To reset the ECU fuel map or not?
- Alternator Good (Says Tech) but Charging CEL still on
- Maybe a problem?? Please help
- Cel po442
- Hard to shift problem.
- Rear leveling
- Help With MAF O Ring
- WTH is going on...
- Car runs horribly and dies, is it the fuel pump?
- Need a little help
- rearview mirror replacement/ windsheild replacement
- Input needed: CEL Code - P1686 - Oil Metering Pump
- Random jerky steering, sometimes violent
- Problem while driving(critical)
- RX-8 Clutch PRoblem .. Help pls
- missing at start up
- have a quick question
- Turn the key - Nothing happens
- Secondary Shutter Valve Switch Problem
- RPM drops
- ARGH New motor having problems!!!
- Clutch burnt smell???
- Burnt smell from clutch???
- HELP need to put gears back in place!
- Odd Noises
- Battery Problems
- Need help, rough idle check engine light flashing
- 04 Rx8 CEL light issue?
- No power below 4500RPM when cold
- SSV Acuator D:?
- Question about the car stop running when complete stop
- dashboard is moving
- Horn stopped working?
- navigation won't turn on
- little red house!!
- Starting the 8 after 3 months of winter storage... do I have water in the gas tank?
- Starting Issue
- Paint Chipping Covered under Warranty?
- car won't start :(
- Faint squeaking noise...
- Blinking Cel
- Rattling (buzzing) from rear view mirror and steering wheel
- Tranny Issues Again
- O2 sensor is stuck
- engine killed itself?!?!?!
- Quick question about engine noise...
- Alarm issues........
vBulletin® v3.7.5, Copyright ©2000-2012, Jelsoft Enterprises Ltd.
