View Full Version : Trouble Shooting
Pages : 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30
  1. MPG increased from 16 to 19.5 city!
  2. I have a few Trouble Codes, anyone know how to fix them?
  3. Battery issue?
  4. Caliper Slider Seized!!
  5. Broken Sun Visor- Does the warranty cover it
  6. TPS maxes out ~78%?
  7. Mazdaspeed Coilover Problems
  8. Small oil leak --- pan or sensor?
  9. Carbon??? New engine???
  10. P0093 Help!
  11. Crap happens without warranty: CEL: Bad o2 sensor
  12. Multiple warning lights, but they go away on restart
  13. Problem with my Cruise Control!!!
  14. Rx-8 W/New engine, AEM CAI, Runs like crap, help!
  15. vibrations??
  16. monkey cage light?
  17. Bent rear endlinks. Options?
  18. Check Engine Light!!!!
  19. big AC problem i think
  20. greddy turbo kit users with CEL
  21. Clutch or transmission???
  22. Coolant Expansion Tank
  23. 2004 rx8 is idling badly..need help..
  24. engine check after engine mods.
  25. my car= pissing me off
  26. Help!!! my 8 wont idle
  27. My car - Progession of a love affair.
  28. Please help check engine codes
  29. Reverse gear - "thud" ???
  30. clutch burnt??
  31. Reading the dipstick?
  32. Blown Rear Diff??
  33. Electrical Issue
  34. Dead tranny
  35. Cat breaking up at 63K - Preparing for battle with Mazda
  36. Replacement core
  37. check engine light...please help!!!
  38. Oil Cooler Line Leak Need Help ASAP
  39. Sunroof Rattle TSB didn't help....
  40. Help!-Coolant Resevoir building up pressure and over flowing
  41. Loss of power due to bad coils
  42. Overheating
  43. trouble codes 3!!!
  44. Whistling sound
  45. Transmission surge
  46. PWR Window inoperable on driverside
  47. Rubble/Growling Engine Noise
  48. Strange noise when turning off the car!
  49. Motor type noise when ignition off
  50. Code p0442
  51. Gas Overflow at the pump....
  52. question about battery warranty
  53. Exploding Clutch!!!
  54. HELP... car won't start... just went from bad... to worse... bwaaaa
  55. Remote is dead...what can i do?
  56. lose of power / 2 different readings
  57. Engine not starting, after tranny fluid change
  58. car starts and dies
  59. 4th gear problem
  60. please help
  61. ABS , Brake, and DSC dash light come on while driving
  62. what kind of ecu should i get?
  63. Cigarrette Lighter socket question.
  64. MS and AEM CAI warning to all!!
  65. 2 high pitched sounds....exhaust leak?
  66. Engine Warning Light
  67. ticking noise coasting in neutral
  68. AC belt breaks, replaced, car won't star now
  69. Battery light
  70. big issue with mazda p2004 and p0302
  71. How Can i Fix the ssv?
  72. Squirrel in engine!!!
  73. BP Invigorate fuel additive
  74. Synthetic Tranny and Diff Fluid
  75. '09 GT 5th to 6th gear shift grinds
  76. Security sensor stopping the engine from starting??
  77. CEL went off
  78. I need a diagnostician. Can't boost and misfires...
  79. My Clutch Died
  80. My 8 weird problem~
  81. running rough
  82. Self diagnosed as COILS-Agree or Disagree
  83. 1st noise question
  84. need help ...too lean?
  85. Tie rod/toe link replacement and now bearing???
  86. Aftermarket O2 sensor or Stock O2 sensor?
  87. Q's for ppl with high flo cats and MIdpipe***not regarding noise or cel light***
  88. Sucking in air noise after turn off
  89. Help Please: P0300, P0171, P0302, P0171, P0506
  90. possible sychnro death?
  91. ARRG! Broken caliper bolt, need help finding part number.
  92. Hard gettin into reverse
  93. 09 varible red zones in tachometer not going off
  94. Idle problem...
  95. A/C Question (Problem?)
  96. Tail End Electrical Problems
  97. New Engine good or bad?
  98. Ghost in the Radio
  99. Spark Plugs Dying from Cold Starts
  100. 63k miles on my 8 should i worry??
  101. SSV Stuck Open? CEL RKE P0039? Greddy Turbo
  102. Problems with steering when braking
  103. cold weather
  104. RX8 Warranty help!!!!
  105. Rx8 NO POWER WONT START
  106. smoking!
  107. right turn only noise?!
  108. Illuminated Entry Issue- Lights Won't Turn Off
  109. Dealership Maintenance
  110. what a bad spark plug looks like!
  111. car wont's start, help!
  112. Rear Window Exploded! Window defogger to blame?
  113. Flooded engine....please help!!!
  114. Transmission Replaced and Same issues
  115. Spark Plugs
  116. just installed my foglights, but now the car has rouch idles
  117. broken petcock:(
  118. CEL - P0610 - Help Needed!
  119. Air Bag/Front Seat Belt Pretensioner System Warning Light
  120. Car wont start
  121. Shifter vibration @4,000 and up
  122. heater help
  123. Fuel Pump O-Ring Gone bad. Fuel drippy-Drippy on Driveway
  124. stuck shifter after clutch replacement
  125. Whizzing Sound - Do I Need a Capacitor?
  126. DRL & Highbeams Both Out
  127. Getting strange knocking from rear brakes....
  128. Clutch pedal.... and a few other things
  129. Rough Engine Vibration and CEL
  130. no audio display.
  131. Clutch Creak
  132. Belt issue?
  133. RX-8 Bogs Down When I Put My Foot Down
  134. Temp. light comes on--but only at highway speeds
  135. Mis-Fire problem
  136. Help finding a part number
  137. new LSD here i come...
  138. Crazy Oil Light
  139. Only one head light?
  140. Grinding Hollow Sound, when letting off the foot of the gas
  141. No power and ... no power?
  142. 8 or more cranks to start
  143. Hesitation at 6K plus
  144. Mysterious Stall When Driving
  145. battery problem with my 05 rx8 6spd
  146. p0107
  147. mazda warranty?? and engine no start again
  148. Stuck Valve (secondary stuck valve) and PCM memory question
  149. clicking/ticking sound when cornering hard to the right
  150. RX8 jumping around
  151. WTF huge loss of power
  152. Eratic RPM's When Engaging Clutch
  153. lack of power/funny noise at 4.2k rpm...
  154. water on the engine oil
  155. Trans front seal leak?
  156. Shift Problem 2006 RX 8
  157. CEL- Code 0456 - Question.........
  158. I really need advice....
  159. AC Compressor Fail
  160. Cranks normally but not starting - wet distributor cap?
  161. Warm console issue
  162. heating issue
  163. Engine Bad Or Cat
  164. Power Steering
  165. Power Steering Loss After Slide
  166. squeeky, please help out
  167. HELP! Flashing Security Light
  168. Smart Key (credit card style) problem: buttons on remote don't function...
  169. Serviced my 8 today...died @ Wawa
  170. car wont start please help !!!
  171. strange issues when shifting
  172. are my engine/diff mounts B/O? what else can go wrong...
  173. HELP! no headlights WTF?
  174. car pc problems , please help!!
  175. Belts question
  176. Poor low-end power
  177. Can anyone Please please help! Mazda tells me i need a new ENGINE!!! HELP!
  178. Taking Car to Dealership
  179. Screeching noise...
  180. Need some help!
  181. What the heck is this?
  182. Won't drive normally
  183. Oil leak
  184. car turned off
  185. Front end clack sound.
  186. Cut 02 wires on catylatic- car won't start need help
  187. Neutral Switch part number?
  188. Coolant leak?
  189. Brakes Clicking/Snapping
  190. Water Pump repair - over priced dealer help
  191. tranny fluid leak
  192. CEL Glitch?
  193. MS Cold Air Intake
  194. Let's play: Good Coil Pack, Bad Coil Pack
  195. OEM Fog light fog up.....
  196. cold night - engine wont turn over
  197. Broken Tail light mounting screw
  198. Idling issue finally fixed!!
  199. my rear Rotor lost compresion totaly
  200. 2005 RX-8 Won't Start
  201. Idle dropped, almost stalled out?
  202. Trouble getting the car to turn over
  203. Loose windows...
  204. Loose door handle
  205. Intake screens
  206. release bearing
  207. Wierd rattling noise at high rpm while traveling..
  208. Red light stall
  209. Noobie Oil refill question
  210. New Engine, New Engine...
  211. Car wont start...cranks. No fire.
  212. random missfire. help!!!
  213. Cold Start Potential Issue
  214. Sounds Weird
  215. hissing noise
  216. New rx8, brakes issue?!
  217. Power Steering Issue: EPS b1342
  218. Strange problem with car.
  219. RPM Dropping = Engine Stalling
  220. sensor problems
  221. Obd 2 P0610
  222. Are my coils bad? (picture inside)
  223. Shifting problem
  224. Does synthetic oil void your warrenty
  225. power surge went from 4800 to 6800 rpm
  226. Sudden drop in gas mileage
  227. Agency Power rattling tip HELP
  228. water leak in car
  229. Rpm goes up and down by it self
  230. Losing power
  231. 04 GT taking along time to start
  232. Coolant Fill Leak
  233. Midpipe+ 02 sensor spacer= no CEL?
  234. Grinding sound coming from new clutch
  235. Help car spurdding and cel blinking
  236. TPMS Air Valve Question
  237. P2503 - Think my Alternator is Dead?
  238. hmm...the flood issue or ECU
  239. raidator light??
  240. Misfire?
  241. Werid RPM's After Throttle Body cleaning
  242. Coolant tank empty
  243. Centerforce Dual Friction= FAIL!!!!!!!!
  244. Synthetic Oil question... different one, though.
  245. noise when clutch pedal is out
  246. 18 degree cold weather
  247. Engine vibration and power steering
  248. Rear window seal
  249. Help - vibrations when accelerating
  250. need a lil help
