View Full Version : The Do It Yourself Forum
Pages : [1] 2
  1. DIY: Painting brake calipers
  2. DIY: Oil cooler opening mesh & grille replacement
  3. DIY: MP3/Factory Head unit removal/install
  4. DIY: Radar Detector hard wired installation
  5. DIY: Shock Sensor Install
  6. DIY: Aldehyde (Cabin Air Filter) Installation
  7. DIY: How to replace rear 6x9 speakers
  8. DIY: Side-marker "Clear Corner Lights" Installation
  9. DIY: How to add AUX-IN to Tape Module
  10. DIY: Removing bumpers
  11. DIY: Fog Light Rewire
  12. DIY: Eyelids for less than $10
  13. DIY: RX-8 Oil Change for dummies
  14. DIY: RX-8 Logo Wheel Center Install Photos
  15. DIY Rotor Rear Fog light in the making
  16. DIY: Clutch Pedal Extension
  17. DIY: Code your NEW key yourself
  18. DIY: Painting the Engine Cover & Related Items
  19. DIY: Best Route for Amp Power
  20. DIY: $10 billet grille
  21. DIY: Silvered Fender Vents on Winning Blue
  22. DIY: Aluminum Strakes Installation
  23. DIY: Lighted sunroof switches!
  24. DIY: Switched LED Maplights
  25. DIY - Trunk button relocate....
  26. DIY : B-Pillar installation
  27. DIY: Custom Sub Box Install- pics and plans
  28. DIY: Fiberglass Speaker Enclosures
  29. DIY: 3rd brake light RX-8 logo mod
  30. DIY: Hood struts from scrap!
  31. DIY: Noise Insulation for the RE Short Ram Intake
  32. DIY: Painting brake calipers
  33. DIY: Lowering Springs Install
  34. DIY: Trunk lighting for spare tire owners.
  35. DIY: Installing Chrome Exhaust Tail Shrouds EASY & Quick
  36. DIY: Hand made side strakes
  37. DIY: Installing Rotary Accents
  38. DIY: Fuel Door Install
  39. DIY: Installing Rotary Accents
  40. DIY: Tire Valve Cap Replacement
  41. DIY: Secure your oil bottle
  42. DIY: Removing "orange peel" from your factory clearcoat.
  43. DIY: Heatshield/Exhaust rattle fix.
  44. DIY: Mazdaspeed Knee Pad install
  45. DIY: Leather Parking Break Install
  46. DIY: MazdaSpeed StrutBar install (and IPT cover)
  47. DIY: Quick and dirty upgrade to the Bose system.
  48. DIY: Disabling the Door Open chime
  49. DIY: Spark plug change.......
  50. DIY: Optima Red top 75/35 install mod
  51. DIY: Custom install, 2-way system
  52. DIY: (Sorta) Noise reduction for HF cat
  53. DIY: Aftermarket flywheel
  54. DIY: "Start Engine" button...
  55. DIY: Thanks
  56. DIY: Rear Bumper Removal
  57. DIY: Audio/Video for RX-8 using Nav screen
  58. DIY: Camera Mount for in-car videos.
  59. DIY: Lineage Grounding Wire Install
  60. DIY: Front License Plate Reposition (stock front bumper)
  61. DIY: Transmission and Differential fluid replacement
  62. DIY: Mazda OEM RCA-Input Install
  63. DIY: Radio Removal / Add an AUX Input
  64. DIY: Foglight bulb swap
  65. DIY: Throttle body bypass mod
  66. DIY: DSC Disable Mod
  67. DIY: Polish your factory wheels, $70 each.....
  68. DIY: Get Rid of Brake Squeal and Low Speed Snapping Noise
  69. DIY: Front License Relocation (EVO plate holder)
  70. DIY: oilcooler and condenser protection
  71. DIY: SS Clutch Hose Install
  72. DIY : Easy way to get rid of squeeking brakes in 60 seconds
  73. DIY: Center console “slanted button” fix
  74. DIY: The_Bean’s $14.99 Leather Parking Break (modified version)
  75. DIY - cabin electrostatic carbon filter
  76. DIY: K&N Typhoon/FilterCharger Install
  77. DIY: Removing the gauge cluster
  78. DIY: Easy MOD for colder AC
  79. DIY: Car wash on a budget
  80. DIY: Racing Beat Sway Bar Install
  81. DIY: Code your own key / remote
  82. DIY: (S-)Video into NAV (AV Electronic video switcher) Install
  83. DIY: Leather e-brake handle for cheap
  84. DIY: Make your own 2005 key combo!
  85. DIY: JIC Coilover Install
  86. DIY: Under the Dash “Holster” Mount
  87. DIY: Cover That TPMS Light!
  88. DIY: Kuda Phonebase install
  89. DIY: Radiator Screen Install
  90. DIY: Brake rotor and pad replacement
  91. DIY: Cabin air filter replacement
  92. DIY: Mazdaspeed body kit
  93. DIY: Replacement clutch parts list
  94. DIY: RX-8 Shop Manuals
  95. DIY: Valentine1 hardwire and concealed display
  96. DIY Custom Switches:
  97. DIY: RP (AFE) Short Shifter install.
  98. DIY: Easy removal of the air filter box
  99. DIY: Installing the Beltronics RX75 Pro Plus Remote Radar Detector
  100. DIY: Deflooding in under 5 mins
  101. DIY: Custom Leather Shift Boot
  102. DIY: Illuminated Shift Knob
  103. DIY: DLS Customs oil cooler grilles, fog light strakes and AC condenser grille inst.
  104. DIY: HID Fog Lights
  105. DIY: Extra Bottle of Oil Under The Hood
  106. DIY: Washer Fluid Level.
  107. DIY: Start Button, Front & Centre!
  108. DIY: lil benny's custom fiberglass enclosure
  109. DIY: brake squeal fix
  110. DIY: Shock Sensor Upgrade - What the instructions don't tell you
  111. D.I.Y Whole navigation System!
  112. DIY: AutoExe Member Brace
  113. DIY: Disabling Fast Flashing Indicators with LED Bulbs
  114. DIY: Gauge on the A pillar
  115. DIY: 2005 Key Rattle Fix
  116. DIY: Rear window rattle fix!!
  117. DIY Ipod mounting bracket
  118. DIY: Painted Rear Bumper "Grille"
  119. DIY: Trunk Keyhole Camera Installed
  120. DIY: Evo Ver. 2 Gauge Pod
  121. DIY: Leak testing turbo
  122. DIY: Make your front Rotary Accent glow!
  123. DIY: Matching Stereo Volume Knob
  124. DIY: Trunk Open Warning Light
  125. DIY: cup holder insulation
  126. DIY: Rear rotor light
  127. DIY: footlamp rewire
  128. DIY: footlamp rewire Part 2 (with OEM kit)
  129. DIY: brake pad replacement
  130. DIY: Turbo Timer Install
  131. DIY - Foglights and running lights
  132. DIY: Home made Cold Air Intake
  133. DIY: Fog Lamp thread as .PDF file
  134. DIY: Greddy turbo intake heat protection
  135. DIY: Powered Sunroof after removing key (delayed)
  136. DIY: HKS turbo timer install
  137. DIY: Removing Scratches from Clear/Colored Plastics & Resins (headlights, etc.)
  138. DIY: Blitz SUS power intake
  139. Diy: Install An Additional Oil Cooler
  140. DIY: Make your own engine grounding kit.
  141. DIY : Replacing Front Wheel Studs
  142. DIY: how to use the search function of the rx8club.com forum
  143. DIY: door lock with aftermarket alarm
  144. DIY: tranny fluid change (auto)
  145. DIY: Blinder X-treme Laser Jammer Install
  146. DIY: Moto IHF1000 Bluetooth handsfree and Cellular Power Amplifier Install
  147. DIY: HAM radio install
  148. DIY: Rattle Hunt
  149. DIY: Fix/prevent aluminum door sill plates from falling off
  150. DIY: Calibrate your dipstick
  151. DIY: Defi controller installed in ashtray.
  152. DIY: Brake Cooling Ducts for Track Use
  153. DIY: false floor fiberglass enclosure
  154. DIY: Axial flow shifter silencing
  155. DIY: how to change halogen(nonHID)lights
  156. DIY: Installing Racing Beat oil cooler & AC condenser screens
  157. DIY-auto up and down windows
  158. DIY: Installing Parking Lights
  159. DIY: License Plate Light Swap
  160. DIY Index...
  161. DIY Section – by Category and Alphabetically
  162. DIY: Datalogging AFR in the eManage (blue) Support Tool
  163. DIY - Gas Pedal Mod for Heel-Toe
  164. DIY - Cell Phone Mount
  165. DIY: max oil out, oil change.
  166. DIY: PCM Removal
  167. DIY: Getting RX-8 on Rhino Ramps
  168. DIY: Dual clear side marker/ blinker mod.
  169. D.I.Y: Replace A/C Condenser
  170. DIY: How to clean the MAF.
  171. DIY- How to get rid of the blue LEDs in the instrument cluster
  172. DIY: Radar Detector Mount Bracket
  173. D.I.Y. Auto exe front an rear strut braces i think more indepth
  174. DIY- Brake Cooling Ducts
  175. DIY - Illustrated cluch pedal adjustment
  176. DIY: Side marker with blinker
  177. Diy: Sirius In The Ashtray Smokers Beware
  178. DIY Radiator Fan Switch...
  179. DIY: custom fiberglass subwoofer enclosure guide
  180. DIY: the CORRECT way to remove the maplight / sunroof switch unit
  181. DIY: instrument cluster diagnostics mode
  182. DIY: Coolant Change
  183. DIY: Backup Camera
  184. DIY: hooking up your sunroof to an aftermarket alarm
  185. DIY: Aftermarket Homelink / auto-dimming mirror
  186. DIY - Fix Front Seat Belt in rear buckle
  187. DIY ....Chrome Rotary's... and more
  188. DIY: Parrott CK3000 Bluetooth kit with Quick Connect harness for Mazda Bose
  189. DIY: Bluer Low-Beam HID Bulbs
  190. DIY: Valet 561t remote start install
  191. DIY: How To Jump Start Your RX-8
  192. DIY: Gutting out your Catalytic Converter
  193. DIY color sanding and buffing
  194. DIY: CF Center Console Overlay
  195. DIY : AT Cooler install
  196. DIY: Fix Your Illuminated Shift Knob
  197. DIY: How to clean the MAF.....
  198. DIY: front shock/coilover install
  199. DIY: Rear shock/coilover install
  200. DIY: Moton Club Sport coilover install
  201. DIY: TPMS for wheels
  202. DIY install instructions for frt air dam
  203. DIY: Fender Vents/Strakes Removal
  204. DIY : Remove/Replace Rear Combination Light(Tail Light)
  205. DIY: Installing Side Aero Flares
  206. DIY : How to install Stainless Steel Line and bleed to your Rx8
  207. DIY: Rear Rotary Accent Light version number 5
  208. DIY : Replace your Radiator (aftermarket or OEM, both the same)
  209. DIY: TCS on/off timer
  210. D.I.Y. Alignment
  211. DIY: Ghetto Fix to Sliding Center Compartment
  212. DIY: Ebay Spoiler Install
  213. DIY: Converting an H9 bulb to fit H11 fog light socket.
  214. DIY: Motor Mounts installation tips
  215. DIY: Coil Packs installation tips
  216. DIY: front plate relocation the cheap and EZ way!!
  217. DIY: Beeps (not horn) when remote lock/unlock?
  218. DIY: Replace Your (Heavyweight) Car Mats
  219. DIY: Flex-a-lite Variable Fan Speed Controller
  220. DIY: Hood Ventilation Mod
  221. DIY: Remote Turbo System
  222. DIY: Replacing Stock HID headlights/Parking Lights
  223. REQUEST!: Racing beat plug wire install
  224. DIY: Heater-Core Bypass Mod
  225. DIY: Clutch Replacement
  226. DIY: Better Flowing Intake Box (Similar to RB Intake Box)
  227. DIY burnt out coil replacement
  228. DIY: Headlight Auto Level Sensor Rebuild (aka Headlamp, leveling)
  229. DIY: Wiring a 4 channel LOC
  230. DIY: Better Looking OEM Rear Diffuser
  231. DIY RX8 Service Manual
  232. DIY paint Oem rims
  233. DIY: GPS "hard wire" install
  234. DIY: Stock Looking/Mounted Buttons
  235. DIY: Chargespeed Fender Vents Install
  236. DIY: emblem painting
  237. DIY: De-Flood procedure - more flooding for this guy!!!
  238. DIY: LED in Coinbox
  239. DIY: TB by-pass/in-line coolant filter
  240. DIY lambo-Suicide doors
  241. DIY: In Depth Shift Boot Change
  242. DIY program your own key Cont.
  243. DIY : with Mazda Zoom Power Engine Cleaner (Engine Cleaning, Seaform)
  244. Diy Rear Fog Light
  245. DIY : Prosport gauge install ( lotek Pod )
  246. DIY: Installing AEM CAI and Siebon hood
  247. DIY: Stock Air Filter (Box)
  248. DIY: Spark Plug Change.
  249. DIY: how to remove humidity from headlights
  250. DIY: Fender Rolling
